Like Tree9Likes
Old 11-18-2011, 03:22 PM
  #24496
10sctrel0v3r's Avatar
Originally Posted by namewasdallas View Post
Does anyone know if they make a Cvd dust boot or drive shaft boot to keep dirt off these parts and grease at the joints???? I was looking at Team Durango's boot's but im not sure of the size and if they would work. Just seems like a great upgrade for a couple bucks.
This is a picture of what im talking about
http://www.team-durango.com/part-inf...artNo=TD310022
i believe there are some covers or boots for the truggy that will fit. LOSA3537
10sctrel0v3r is offline
Old 11-18-2011, 04:18 PM
  #24497
Originally Posted by DBARB View Post
Do the shock standoffs work on the carbon fiber towers?
Sure do.
hacker07 is offline
Old 11-18-2011, 05:03 PM
  #24498
Originally Posted by D.a.v.e View Post
You had me excited for a few min.. Seems they are backordered as well?
Looking at that picture I wonder if they came out with different screws or if the bushings are on the screws for the picture?
http://www.nitrohouse.com/advanced_s...001e59&x=8&y=9
Bummer.
Pm me. I have a bushing I'll send ya.
Brian
losi b is offline
Old 11-18-2011, 06:01 PM
  #24499
namewasdallas's Avatar
Does anyone run their truck on a rough, loose/dusty low/medium bite track? trying to find what I should run for diff fluids front/center/rear. I'll prolly end up running the 7/5/3
namewasdallas is offline
Old 11-18-2011, 06:35 PM
  #24500
omenwolf's Avatar
Trader Rating: 37 (100%+)
here is what I run on most of the time exactly what you decribed. I am running 7500f 10000c 1500r and it fits my driving style.
http://www.youtube.com/watch?v=OMJWGkkudvs
http://www.youtube.com/watch?v=cWy-8-BVD0M
omenwolf is offline
Old 11-18-2011, 08:44 PM
  #24501
Chad Smith's Avatar
Ok if anyone can help me out. I know it was probably already answered a thousand times but bear with me. I am switching from a AE 4x4 to this truck. My current electronics is a Hitec, .10 speed servo with 130-135 oz of torque cant remeber exactly. A LRP SXX v2 tc spec esc and a tekin 5.5 motor. Will these electronics work ok in this truck? Is there any mods to do right out of the box. For example, screws backing out that need loctite, things not built right etc. Thanks in advance for the help.
Chad Smith is offline
Old 11-18-2011, 10:12 PM
  #24502
DBARB's Avatar
Ok so I am running the TL servo arm and I switched to the inside hole but the nut hits my Spektrum 6040 servo case when I turn all the way to the right, is anyone else having this problem?
DBARB is offline
Old 11-18-2011, 10:18 PM
  #24503
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 106 (100%+)
Have ya tried screwing it up from below and putting the nut on top?
thecman26 is offline
Old 11-18-2011, 10:22 PM
  #24504
omenwolf's Avatar
Try the TLR 22 servo arm, it works perfect.
omenwolf is offline
Old 11-18-2011, 10:29 PM
  #24505
Grandturk's Avatar
Sanity check - the gold front springs - color actually looks brown to me?
Grandturk is offline
Old 11-18-2011, 10:38 PM
  #24506
bdechenzio's Avatar
Originally Posted by teknic View Post
Well I offed my Ofna and ordered a TEN-SCTE yesterday. Looks like I have a lot of reading to do...again!
I'm going to be putting a Novak Havoc Pro/Ballistic 4.5 combo in it and it seems that a 15-16t is a good starting point? Just wanted to confirm.
Also, I thought I had read a while back that the "newer" versions of the trucks are coming with the hardened pins. Is that accurate?
Thanks in advance!
I have the same set up, and I'm going to second the suggestion to look at the tekin 4 pole, or any 4 pole for that matter (tenshock just put out a new sensored that I'll be trying out shortly, viper just put out a new sensorless that seems like it'll be pretty hot if you dont mind sensorless...). Just seems the 4 poles are stronger, lighter, and have less heat issues.
Good luck with whatever you choose
Brad
bdechenzio is offline
Old 11-18-2011, 10:57 PM
  #24507
Josey Wales's Avatar
Talking KA-LEEEEEN
JUST GOT DONE WIRING UP THE RX8 AND PRO 4, IVE BEEN SLOWLY GETTING ALL THE ELECTRONICS FOR THE LAST 4 MONTHS, THIS SCTE HASENT EVEN SEEN PAVEMENT IT WILL BE MY FIRST TIME RUNNING IT AT THE TRACK THIS SUNDAY CANT WAIT TO SEE HOW THIS THING HANDLES DURING THE TESTING AND TUNING PHASE IM COMING FROM A SLASH 4X4 ULTIMANTE SO I HOPE TO SEE A MAJOR DIFFERENCE HOPE THIS SET UP WAS MONEY WORTH SPENDING!!!!!!!!!!!!
Attached Thumbnails Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-img_0602.jpg
Josey Wales is offline
Old 11-18-2011, 11:02 PM
  #24508
omenwolf's Avatar
A friend is sending me an RX8 with a scx4 5.5 to tru out and see if i like it. Not too sure going from a 4 pole to a 2 pole is gunna end well but we will see. I have a 14t 17t 18t 20t and all the goodies so im thinking of trying the 17t with low timing any thoughts?
omenwolf is offline
Old 11-18-2011, 11:06 PM
  #24509
omenwolf's Avatar
Night and Day bud you wont be dissapointed.
Nice wiring too.
omenwolf is offline
Old 11-19-2011, 12:16 AM
  #24510
DBL15's Avatar
looks great mate but why the slicks? are you running it on a onroad track or something?
DBL15 is offline
