wait, does this mean the roller doesn't come with a 23t horn? Then again, the lastest Spektrum servos are Savox and are 25t so i guess i shouldn't be concerned.
as it turns out the lastest spektrum servos have 25t (sourced from savox) so i don't need to worry.
I am normal...just lucky
shock eyelets too tight
When servicing or setting my shocks the lower eyelet is stuck to the arm so strongly, that I have to force it with a screwdriver to remove from the hole where it was mounted. The screw holding it moves freely. What can be the root of this problem and how could I solve it? My buddies also have the same trouble.
I tried searching the thread for clues, but came up empty handed.
Hold the tire and push the arm down (away) from the shock after you remove the screw. Obviously with the top of the shock still attached to the shock tower....
When you tighten the screw onto the ball, I think the arm is compressed and indents itself around the ball, which makes it difficult sometimes to release the shock bottom.
You are certainly right that there is heavy compression on the arm, I can see it slightly bent where the head of the screw sits.
has it been a while since you serviced the shocks? i found that the first time i serviced it was when it proved to be most difficult to remove. after that, a quick punch of the tire away from the shock frees it up with no issues for me.
Anyone running the gens ace 40c with the pro 4 4600? If so how are they working? Thanks
I had done it 3 or 4 times, but the last one was almost two months ago, I only had the chance to run it once since that, so it is sitting on the stand since that. Maybe if I remove the screws and let is rest that way for a few days, it will ease up.
I won't be able to test it in the scte until next weekend.
Hey everyone!! I just got my brand new Ten SCTE running. What a kick and half. I am so glad I bought this truck. My friend has a Slash and every time he turns sharp it flips. Mine runs like it's on rails. What fun!!! What a great truck.
