Like Tree9Likes
Old 11-09-2011, 01:07 PM
  #24046
Bondonutz's Avatar
Trader Rating: 48 (100%+)
Originally Posted by chucko
need some help. last weekend running my pro 4 4600 RX8 I over used my two 2 cell lipos. spinning the tires and driving like a mad man and they went to the gods in never ever land. I have a ten shock 401 4000 and one 3 cell left. can I run the ten shock on threes. ? just need to get through one night of racing tell my new batteries show up. Thanks any one ?
Heres what your looking at geared 40/13, really high RPMS, it will get HOT but be plenty fast
Differential Ratio: 3.888888888888889
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 40
Pinion Tooth Count: 13
Total Voltage: 11.10
Motor KV: 4000
Tire Diameter (inches): 4.25
Tire Ballooning (inches): .10
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 3.08 : 1
Total Ratio: 11.96581 : 1
Tire Circumference (inches): 13.98 inches (355.09 mm)
Rollout: 1.17:1
Total Motor Speed: 44400 RPM
Vehicle Speed: 49.12 mph
(78.91 km/h)
Effective KV Value: 4000
KT constant: 0.34 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
Bondonutz is offline
Old 11-09-2011, 01:26 PM
  #24047
scoobie1's Avatar
What size setscrew are you guys using for the droop screw tabs on the TLR chassis?
scoobie1 is offline
Old 11-09-2011, 01:40 PM
  #24048
R/C Tech Elite Member
JayL's Avatar
http://www.amainhobbies.com/product_...Droop-Screw-12
lol
JayL is offline
Old 11-09-2011, 01:54 PM
  #24049
Default Racers Rides
A little off topic for a second.
I got my truck in the "Racers Rides" section of the October issue of "Extreme RC Cars", page 128 top right titled "Photo Ready". I feel like a proud dad showing off pictures of my kid to the world.
Brian
losi b is offline
Old 11-09-2011, 01:59 PM
  #24050
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
Very cool!
Post a scan of the page.
ChrisAttebery is offline
Old 11-09-2011, 02:20 PM
  #24051
namewasdallas's Avatar
Can someone that Owns a Tekin Pro 4 4600kv tell if you can spin the shaft on the motor by hand super easy???
Mine spins super easy like there's no magnets inside and my castle 3800kv deff wasnt easy to spin like this...
namewasdallas is offline
Old 11-09-2011, 02:24 PM
  #24052
porkchop's Avatar
its fine
porkchop is offline
Old 11-09-2011, 02:28 PM
  #24053
10sctrel0v3r's Avatar
yes you can. i was very surprised by this also since i was coming from a novak with the 14mm rotor. it was very hard to spin but the tekin is a lot smoother and faster.
10sctrel0v3r is offline
Old 11-09-2011, 03:54 PM
  #24054
Casper's Avatar
Trader Rating: 34 (100%+)
You can use the 8ight chassis droop screws or some 4-40 button head screws work as well.
Casper is offline
Old 11-09-2011, 04:33 PM
  #24055
JayL's Avatar
Am I correct in remembering Hacker07 said losa6045 fits and is an upgrade?
http://www.amainhobbies.com/product_...ering-Link-Set
JayL is offline
Old 11-09-2011, 04:55 PM
  #24056
Originally Posted by ChrisAttebery
Very cool!
I don't have a scanner but here's the picture that they used;
losi b is offline
Old 11-09-2011, 06:52 PM
  #24057
BmainStar's Avatar
Fits?? It is the rod ends for the TLR torque Rod!
BmainStar is offline
Old 11-09-2011, 07:14 PM
  #24058
I need help from someone that owns a rx8 I just wired in my rx8 and Pro 4 motor but I'm trying to Calibrate the ESC to the transmitter and im having a serious issue. I think its the hpi transmitter as I had issues trying to do it with my MMP esc.
Anyways here's what im doing, I turn on transmitter, Turn on rx8, Hold Mode button till it beeps, Let it find nuteral then beep, then throttle till beep, then brake till it beeps.
But after it finds the brake I let go and all the lights on the ESC are glowing and from what I seen on Tekin's rx8 setup, there's no radio singnal. I just don't get how that can be when it notices my brake and throttle input..
Trims were set at Zero, I tryed messing with them in different spots no luck, I also tried doing throttle reverse like tekin said and still nothing..
Can someone help me out PLEASE i want to try this pro 4 4600
Old 11-09-2011, 07:38 PM
  #24059
Trader Rating: 19 (95%+)
without digging out my manual, I recall the RX8 being different than the castle speedos. I dont recall what order you do them in, but dont assume it is the same as your MMP. make sure you read the manual.
You may also have to increase the neutral deadband area in the RX8 if your trigger is sloppy. It may not be able to locate a true neutral.
RedDevil13 is offline
Old 11-09-2011, 08:05 PM
  #24060
DBL15's Avatar
your doing it right mate
i would say your controller is not returning to netural points and its causeing your problems
DBL15 is offline
