Like Tree9Likes
Old 11-08-2011, 12:43 PM
  #23986
Trader Rating: 33 (100%+)
Originally Posted by Cory29NT
Hey guys! Here's a short course body I just painted. Its up for sale on flebay!
dang.. thats a nice body!!!!!!!!!!!
dgrobe2112 is offline
Old 11-08-2011, 01:55 PM
  #23987
R/C Tech Elite Member
JayL's Avatar
running a tekno pinion 13T but the shank is so long the pinion only gets half overlap with the spur gear.
What are GOOD pinions with shorter/short shank?
JayL is offline
Old 11-08-2011, 01:58 PM
  #23988
AbstractZen's Avatar
I run the Losi pinion's with a Robinson Racing adapter so they fit the smaller shaft on the Castle 1410.
AbstractZen is offline
Old 11-08-2011, 02:00 PM
  #23989
Grandturk's Avatar
Novak pinions
Grandturk is offline
Old 11-08-2011, 02:48 PM
  #23990
Asharus's Avatar
Trader Rating: 42 (100%+)
My Robinson racing and losi pinions fit fine
Asharus is offline
Old 11-08-2011, 02:49 PM
  #23991
SuperSmoove's Avatar
I agree, Novak pinions are the best. I ran E 1/8 buggy HARD for 2 years and they were almost impossible to cut teeth marks in. Very good steel is used and seem to have a hard coating on them.
SuperSmoove is offline
Old 11-08-2011, 03:03 PM
  #23992
Trader Rating: 19 (95%+)
hypothetical question. Say you have your SCTE dialed on the track, everything feels great, you love the setup. This truck is based on the 8ight platform, so if you had an 8igth-e, could you theoretically use the same setup on it? if not why and what is different?
I have an RC8Be, so its different than the Losi 8ight (though I dont really know what the differences are besides gear ratios), but I was just curious how the setup changes transfer across classes with similar designs.
RedDevil13 is offline
Old 11-08-2011, 03:09 PM
  #23993
Novak are by far the cheapest options also. They have (3) packs from 9t all the way to 20t
http://www.amainhobbies.com/product_...n-3-Pack-91011
http://www.amainhobbies.com/product_...-3-Pack-121314
http://www.amainhobbies.com/product_...-3-Pack-151617
http://www.amainhobbies.com/product_...-3-Pack-181920
Old 11-08-2011, 03:12 PM
  #23994
Casper's Avatar
Trader Rating: 34 (100%+)
Tires are different. CG is different. The F/R balance is alittle different.
You can transfer how setup changes effect the two different platforms but setups will vary. It is kind of like trying to run an 8ight setup on a 8ight-T. (A little more drastic) but you get the idea. There are enough diffences you need to set them up a little different from each other.
Casper is offline
Old 11-08-2011, 03:29 PM
  #23995
thats kinda what I thought, thanks for the confirmation. I'll just keep tinkering with the rc8 until something works.
Old 11-08-2011, 04:39 PM
  #23996
BDRMBULLY's Avatar
Trader Rating: 40 (100%+)
Originally Posted by lowroad
Here she is:
http://www.ckhobby.com/shop/?control...ry&path=13_108
Be in stock in the next week or so
i had there older version the thing hauled ass but i blew it up cause i had a seized bearing one thing i dont like is that the wires are built into it. my wires crossed in the casing some how thats why it stoppped working. i re shrink wrapped them and i think it works now but im runnen a pro 4 4000 instead.
the price is nioce for the motor being sensored now but does the sensor wire plug in or is it built in like the motor wires?
BDRMBULLY is offline
Old 11-08-2011, 04:46 PM
  #23997
lowroad's Avatar
Trader Rating: 79 (100%+)
So did your wires cross in the casing or did a bearing seize? I'm confused.
In any case, you can see the sensor port, it plugs in like any other motor. I'd probably prefer solder tabs as well, but for less than half the price of the tekin, I won't complain much. The viper systems wires are hardwired like this too, for the record.
lowroad is offline
Old 11-08-2011, 05:13 PM
  #23998
BDRMBULLY's Avatar
i had a seized rear hub bearing causing my tenshock to reach between 180 to 205 at one point. then it stopped working, i then opened her up to notoce wires crossed in the case , then seperated them and added heat shrink to the 3 wires. i think shes good to go again but would rather not use it but when i did on a 8th scale track that motor was a can of whoop ass. i have tyhe pro 4 4000 and was unable to get the 4600 but now i think ill buy the shocker 4600 instead of the pro 4 4600.
Old 11-08-2011, 05:17 PM
  #23999
lowroad's Avatar
Interesting. I heard of bearing issues on the first run of tenshocks from others too. I had a 4000kv non-sensored shocker, and I did regular maintenance on the bearings. Hopefully that's been addressed, though I don't know. I'll probably just throw some avids or something in this one before anything else.
lowroad is offline
Old 11-08-2011, 05:32 PM
  #24000
omenwolf's Avatar
Trader Rating: 37 (100%+)
Originally Posted by Integra
You Semi Stripped the hole using a 4-40, a 5-40 is the proper size and will not strip.
Nope it was the stock screw right out of the box
Tapped deeper with the 3mm countersunk with cone washer holds alot better than the stock losi 5-40 ever did.
omenwolf is offline
