Like Tree9Likes
Old 11-07-2011, 08:21 PM
  #23956
JayRC66's Avatar
Smile
Originally Posted by ChefDementia View Post
How does that look with the wheels on, and how are the clearances with the tires and body?
Here is your answer....
Pressing down on the body
JayRC66 is offline
Old 11-07-2011, 08:32 PM
  #23957
kman16jr's Avatar
Trader Rating: 56 (100%+)
Well i think i fixed the rear diff issue,have to see on wednesday when i go to the track.the slack between the rear diff pinion and ring gear is minimal so it shouldnt skip.Im gonna buy a new set of pinion and ring gears anyway if the current ones give.
kman16jr is offline
Old 11-07-2011, 10:52 PM
  #23958
BmainStar's Avatar
Originally Posted by alvinsmith75 View Post
OK it is past time to change all my rod ends and hollow balls. I know Losi is supposed to be coming out with hardned balls but I need new ones asap. What is my best choice right now to replace all rod ends, hollow balls, and lighter turnbuckles?
I believe Salad Fork had posted a link to some Dubro airplane links awhile back that were a good replacement?For the Balls..
[QUOTE=JayRC66;9882652]Here is your answer....
That body looks cool! What I have done with a Baja body was cut the fenders almost all the way to the body,left bout 1/4 inch.Looks crazy and flys like a Byrd!!!Great practice or windy day body option..
BmainStar is offline
Old 11-08-2011, 05:18 AM
  #23959
vasidudu's Avatar
Questions?? Which 3s?
Hi there all,
What is the minimum "decent" C rate should I look at when buying a 3s?
Looking at this or that.
Anybody's feedback would be greatly appreciated.
Thanks,
V
vasidudu is offline
Old 11-08-2011, 05:30 AM
  #23960
AbstractZen's Avatar
Originally Posted by vasidudu View Post
Hi there all,
Thanks,
V
I personally wouldn't run anything less than 50c, but if memory serves, I think some guys on here have run less in their SCTE's. The 4x4 sct class in my area is pretty competitive though so good punch is important.
AbstractZen is offline
Old 11-08-2011, 05:31 AM
  #23961
vasidudu's Avatar
Yeah, I thought so but not easy to find a 3s 50C at decent price anywhere...
Thx anyway,
V
vasidudu is offline
Old 11-08-2011, 05:43 AM
  #23962
fullytwisted's Avatar
loving my SCTE with the Tekin pro 4 4 pole 4600 with a tringty 2s 5600 65c ..the thing just rips....and with the setups on the first page you can go wrong..
fullytwisted is offline
Old 11-08-2011, 05:45 AM
  #23963
Thx anyway,
V
Oops, my bad. Didn't notice the 3s in your original question. You can go lower in c rating since the voltage is going to be higher. 30c to 40c should be a good ballpark for 3s in my opinion, but I'm sure others will chime in as well.
Old 11-08-2011, 05:46 AM
  #23964
vasidudu's Avatar
Hey thanks for the update.
Appreciate the feedback.
Best,
V
vasidudu is offline
Old 11-08-2011, 06:42 AM
  #23965
alvinsmith75's Avatar
Trader Rating: 38 (100%+)
Hi there all,
Thanks,
V
Either one of those will be fine in the SCTE for 3s application.
alvinsmith75 is offline
Old 11-08-2011, 06:58 AM
  #23966
Getting ready to place an amain order. Could someone please link me to the screw I need to replace the motor mount screw. I am referring to the single button head screw that goes into the top of the motor mount and you use it to set the gear mesh. I want to replace it with a screw that takes a larger allen wrench.
Thanks in advance,
Alvin
Old 11-08-2011, 07:02 AM
  #23967
vasidudu's Avatar
Thx Alvin.
Greetings,
V
vasidudu is offline
Old 11-08-2011, 07:23 AM
  #23968
omenwolf's Avatar
Trader Rating: 37 (100%+)
Hi there all,
Thanks,
V
http://www.hobbypartz.com/98p-40c-50...-hardcase.html
omenwolf is offline
Old 11-08-2011, 07:27 AM
  #23969
omenwolf's Avatar
Thanks in advance,
Alvin
I would be careful there that screw strips easily, I semi stripped mine and i drilled it deeper and tapped it with a 3mm thread tap and ran a longer screw into it.
omenwolf is offline
Old 11-08-2011, 07:39 AM
  #23970
chucko's Avatar
ok:I need some help Please>>>> I was going around the track when all of a sudden the truck does flip turn and then lands upside down like it got hit with a rope across the track. the turn marshal flips it over. I go half a lap and it dies. could it be a bad servo ? I checked all my camber and toe settings everything is tight. the servo saver is tight what could it be other then my bad driving.. Thanks in advance
using a 6040 servo spectrum
pro 4 RX 8 2 cell 50 c 5000mah
chucko is offline
