just got the tuning kit today and was wanting to know what would the same as the stock setting on the hinge pin holders
i am happy running that as well
some people are running 0's on the front
but on the back there running 0's and 1's nott sure which way sorry
but stock is 0's
Zeros all around for the front
for the rear you want 1 facing up in the front and zero in the back
thanks guys
Need help with TLR Tuning kit
Hello, I'm installing the tuning kit and I'm puzzled by the black plastic inserts for both the front and rear adjustable hinge pin holders. There are many little plastic pieces with 0,1,2 etc... on them and I'm just wondering how these affect performance and which # would be a neutral setting?
Thank You
Thank You
Need help with rear diff.
Hey guys i bought my buddies scte roller and i soldered up my tekin stuff and went for a test drive and noticed it works fine when im driving but when i tap the brakes the rear diff pinion chatters but again works fine when going forwards,If anyone has has this issue can you please let me know how to adjust this issue,thanks kevin.
Thank You
Thank You
Well i think i fixed the rear diff issue,have to see on wednesday when i go to the track.the slack between the rear diff pinion and ring gear is minimal so it shouldnt skip.Im gonna buy a new set of pinion and ring gears anyway if the current ones give.
[QUOTE=JayRC66;9882652]Here is your answer....
That body looks cool! What I have done with a Baja body was cut the fenders almost all the way to the body,left bout 1/4 inch.Looks crazy and flys like a Byrd!!!Great practice or windy day body option..
