Will the HD balls solve this? What about the plastics? Is there a solution for the ends?
We have had good luck with the HA balls we are testing prior to there release. Stock plastics are working well with them.
I've got a lot of slop on the balls and ball ends on my truck - front and rear. So much so that the wheels can go from +/- 1* of caster/camber/toe. Makes setups a pain. I'm using Lunsford Punisher links with the stock ball ends and plastics (actually new, but still stock style). And there's slop around the balls.
I git my Chris pins today and I want to know do I still use the tiny shim on each end of the pins with the bushings he sent?
Thanks Chris for the super fast service. They came the same day my kit was delivered.
Just started putting my diffs back together and they feel kind of notchy when I turn them. They are new never been used. Will this go away after I break them in? Or did I over tighten the spur gear?
They should feel better after a break in period.
I am assuming they spin but you can just feel the gears mesh.
