Like Tree9Likes
Old 11-06-2011, 04:54 PM
  #23881
bigs's Avatar
Trader Rating: 46 (100%+)
I just put the 9mm carbon shock towers on and plan on using the stock shocks will this be a prob ?
bigs is offline
Old 11-06-2011, 05:09 PM
  #23882
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
Originally Posted by KIK
Ten-T and the 810 are the same.
got it. thanks.
RC*PHREAK is offline
Old 11-06-2011, 05:26 PM
  #23883
Originally Posted by RC*PHREAK
ok. i thought so. so there are 3 different chassis for this platform (SCTE, ten-t, 810)?
Only two, the one for the 810 and TEN-T are the same although we updated it for the 810 slightly in the back.
Originally Posted by Integra
I personally wouldn't call the Current Stock Gears "Smooth"
Ryan, When are the new gear's arriving btw ?
Working on it...
9mm may be a bit thick...
hacker07 is offline
Old 11-06-2011, 05:34 PM
  #23884
New body time! The old one was a bit frail. Any advice on what a good strong Corr body is that will fit?
jasonwipf is offline
  #23885
in rebuilding my diffs i see the steel bushings inside the housing are loose.which has warn out the shim washers under the side gears.
i glued them in to solve this.
im wondering if losi has addressed this and are they updating the diffs?
auto2 is offline
Old 11-06-2011, 05:41 PM
  #23886
RC*PHREAK's Avatar
gluing them in won't prevent the washers from wearing out. those inserts are very hard and the washers aren't.
Old 11-06-2011, 05:53 PM
  #23887
bigs's Avatar
Working on it...
they are the snr shock towers. they are 9mm I think they were sold if you planed on running the 1/8 schocks. please help
bigs is offline
Old 11-06-2011, 05:57 PM
  #23888
We are not considering any type of diff case change at this time. Some glue those inserts in place, some do not, I do personally. I find it helps with slight leakage from the case wearing over time.
hacker07 is offline
Old 11-06-2011, 06:17 PM
  #23889
retsoorkcuf's Avatar
Default nosediving
I was at the track today and my truck nosedived like crazy big small no matter what size jump .anyone have a cure.. I think it's in my suspension set up..32 rear wt 35 front with stock springs and two stage pistons . any ideas
retsoorkcuf is offline
Old 11-06-2011, 06:45 PM
  #23890
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 112 (100%+)
4mm maybe?
thecman26 is offline
Old 11-06-2011, 06:51 PM
  #23891
bigs's Avatar
Originally Posted by thecman26
4mm maybe?
no they are 9mm The are sold on snr graphite.com
bigs is offline
Old 11-06-2011, 06:55 PM
  #23892
KingdomRacer's Avatar
Yes, 9mm taller but I think some on here think you meant thickness which is not the case.
It would be better to use the lower mounting holes for the stock shocks, the 9mm taller (upper) holes are meant for 1/8 scale shocks and IMO work best with the 8 2.0B shocks.
KingdomRacer is offline
Old 11-06-2011, 06:56 PM
  #23893
Ive just done some searching and couldnt find out what all is needed to be done when changing over to diff fluid as far as sealing. I know you have to get all the grease out and such but does anything else has to be done? If some one could point me in the right direction that would be great!
I also broke my first part on my scte today a rear hub. Im actually suprised that broke i have put this truck through hell.
naterpatater77 is offline
Old 11-06-2011, 06:57 PM
  #23894
thecman26's Avatar
Yeah your probably right...
Old 11-06-2011, 07:02 PM
  #23895
bigs's Avatar
Sorry I should have said 9mm tall
bigs is offline
