Like Tree9Likes
Old 11-06-2011, 10:55 AM
  #23866
Originally Posted by RC*PHREAK
is the 810 chassis the same size as the SCTE chassis?
No Sir, its 27mm shorter.
hacker07 is offline
Old 11-06-2011, 11:03 AM
  #23867
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
ok. i thought so. so there are 3 different chassis for this platform (SCTE, ten-t, 810)?
RC*PHREAK is offline
Old 11-06-2011, 11:42 AM
  #23868
Default Diff's
I picked up my new SCTE this past week. I decided to rebuild diffs with 5-7-3 instead of grease before i run the truck for break in. After filling the f-c-r diffs with fluid the outdrives felt a little rough when i turned them by hand. I broke them all down again to ensure i put them together properly which they were. I also made sure i didnt tighten the screws in the casing to much either. Is this normal when the diffs are not broken in yet?
Borik is offline
Old 11-06-2011, 11:47 AM
  #23869
SCUBA STEVE's Avatar
Trader Rating: 89 (99%+)
QUOTE=Borik;9875918]I picked up my new SCTE this past week. I decided to rebuild diffs with 5-7-3 instead of grease before i run the truck for break in. After filling the f-c-r diffs with fluid the outdrives felt a little rough when i turned them by hand. I broke them all down again to ensure i put them together properly which they were. I also made sure i didnt tighten the screws in the casing to much either. Is this normal when the diffs are not broken in yet?[/QUOTE]
Yup, break'm in and you'll be good to go
SCUBA STEVE is offline
Old 11-06-2011, 12:27 PM
  #23870
Trader Rating: 23 (100%+)
Yea its weird howbthey feel notchy but once u run em they r smooth
nitro0619 is offline
Old 11-06-2011, 12:47 PM
  #23871
Integra's Avatar
I personally wouldn't call the Current Stock Gears "Smooth"
Ryan, When are the new gear's arriving btw ?
Integra is offline
Old 11-06-2011, 01:44 PM
  #23872
porkchop's Avatar
has any one had any luck with the tekin 4000 pro 4
and if so what are you gearing it at?
porkchop is offline
Old 11-06-2011, 01:52 PM
  #23873
StPete40's Avatar
Trader Rating: 45 (100%+)
I run it with an RX8. 43 tooth spur, 14 or 15 tooth pinion. I've been running it on carpet tracks all summer. Great power. Temps were topping out at 180 so I added a heatsink.
StPete40 is offline
Old 11-06-2011, 01:59 PM
  #23874
vasidudu's Avatar
Hi there,
I would like to try some more "punch" with my current setup (Mamba Max Pro SCT with 1415 - 2400 Kv). I am looking at 2 options:
1. go with 3s instead of currently 2s
2. go with higher pinion (21T - 23T) but will need this, which is USD 75...
Any of you could advise?
Thx,
V
vasidudu is offline
Old 11-06-2011, 02:11 PM
  #23875
StPete40's Avatar
Gearing up will make it faster, but probably not going to give you the punch you are looking for. 3s would do it, or trade the 2400 in on a 3800.
StPete40 is offline
Old 11-06-2011, 03:13 PM
  #23876
Trader Rating: 36 (100%+)
Default Help!!!
Hey guys,
I recently purchased a used scte on Tech, and discovered after a few runs on it that there was some leaking/wobbling in the rear diff. Found that the bearing that goes inside the diff case was missing, and the part of the case where the ring gear is situated was badly chewed up. Instead of the bearing are the pieces pictured below. I couldn't find these pieces in the manual provided with the kit, and was wondering where in the heck they came from? From what I can tell of the manual, only the bearing, diff, and ring gear should be in the rear diff case, correct?
Also, there was a fair amount of gunk (oil or grease I can't tell) inside the diff case. Is this normal, and is there a way to seal the diff so it doesn't leak? Lastly, is there a link available for a cleaning agent for all those diff parts?
Sorry for all the q's, but I'm new to this truck and trying to figure out what's going on.
Attached Thumbnails Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-dsc03626.jpg   Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-dsc03627.jpg
Stanford55 is offline
Old 11-06-2011, 03:44 PM
  #23877
dtr
dtr's Avatar
Well, those are the pieces of the bearing minus the balls. Some grease is necessary on the ring gear, most kits have more then enough. Brake cleaner and a piece of cloth are my tools for cleaning oil/grease. You can carefully sand the burrs on diff case and use a small amount of black grease or liquid rubber on the blue insert that is inside to stop the leaking.
dtr is offline
Old 11-06-2011, 04:14 PM
  #23878
Default Diff's
Thanks for the reply guys....I was hoping that was it. I'll be out at OCRC most likely Friday for the first run. Just look for the shiny new truck
Borik is offline
Old 11-06-2011, 04:20 PM
  #23879
Wow, I guess that explains it...never seen a shattered bearing before, but I suppose that given the weight/torque this truck has to sustain, perhaps that's normal. Thanks a lot for your help.
Old 11-06-2011, 04:39 PM
  #23880
KIK
KIK's Avatar
Trader Rating: 26 (100%+)
Ten-T and the 810 are the same.
KIK is offline
