Like Tree9Likes
Old 10-30-2011, 08:53 PM
  #23596
Finally got my electronics in and got to run it this weekend! The 4000 Pro4 was ballistic along with the RX8. I only had the set of tires that came with the truck, could not grind enough off of my Split Six wheels to get the wishbones on the truck. It did not matter, the truck was ballistic and handled so good! I used the Truhe base setup except for the adjustable toe blocks "Waiting on the TLR Kit", and a set of RCShox Dual Rate pistons. The truck never was upset and always jumped nose level. It also has a 8ight heritage, the thing jumps forward off of jumps. I was able to win with it and had a blast power sliding it through the corners! Can't wait to get a good set of indoor tires on the truck! Way to go Losi, except on one point!
Now I do not have a issue with buying the stuff to get the truck tuned in so multiple sway bars and springs I understand buying. But why would Losi include a setup on the roller that does not match the base setup in the back of the book? Not that the base setup "On the Truck" is that far off, but seems odd they do not at least include the equipment they recommend for a base setup.
Anyway this truck is great and the best truck on the market! I can not wait till I get to try this truck on the outdoor tracks!
Jammin_Xtream49 is offline
Old 10-30-2011, 09:03 PM
  #23597
Cult Racing's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Krafcik View Post
front page is back - with tekin and no mention of viper.
if you actually looked viper has their esc on there and they dont have the new tekin pro 4 on there.
Cult Racing is offline
  #23598
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 105 (100%+)
Originally Posted by ozace View Post
I think i have found the perfect street basher.
scte-E with 3660 4650 4 pole motor, 2s lipo packs and 2.8 wheels with proline street rubber. Wheelies on demand, great ground clearance for rough street running and uber fast. The body needs a trim for the big rubber but boy does it work well for the non racers out there.
Why would you want a 4WD to wheelie? Thats what 2WD SCT's are for...
These are pretty heavy trucks... I would wander what is wrong if it is does wheelies on demand...
thecman26 is offline
Old 10-30-2011, 09:32 PM
  #23599
alport78's Avatar
Originally Posted by alport78 View Post
HI,
Which is the smallest pinion that I can use with 40t spur to set proper gear mesh? I'm considering to use 11t pinion.
Any answers?
alport78 is offline
Old 10-30-2011, 10:09 PM
  #23600
Any answers?
Im pretty sure the lowest is a 11, but why are going that low?
Old 10-30-2011, 10:11 PM
  #23601
blown up diffs lol
Old 10-30-2011, 11:06 PM
  #23602
alport78's Avatar
I'll use 3800kv motor with 3s and buggy tires. I calculated 11t pinion is the right one to achieve 40mph top speed on that setup. The diff ratio for scrte is 3.88 and the spur is 40t. did I calculated something wrong
alport78 is offline
Old 10-30-2011, 11:20 PM
  #23603
Not all of us race, i just want explosive performance out on the street and this machine gives it all
Nothing has broken so far and it just brings grins
ozace is offline
Old 10-31-2011, 05:45 AM
  #23604
Originally Posted by StPete40 View Post
Is anyone still racing racing the SC4X 4.5 now that the Pro4 motors have been out for awhile? If so, are you still competitive?
I am still running my SC4X 4.5. I bought a Pro 4 4600 but I can't see why I should change it yet. My truck works great with this motor and I'm not getting passed by anyone with a 4600 in theirs.
losi b is offline
Old 10-31-2011, 05:56 AM
  #23605
Toiffel's Avatar
Trader Rating: 52 (100%+)
Nice backup motor !!! Some guys would kill to have one of those in their pitbox....... lol......
Toiffel is offline
Old 10-31-2011, 06:51 AM
  #23606
Trader Rating: 19 (95%+)
What is the latest status on the diff housings? Feels like these parts have been on backorder forever now. Id like to build some new diffs up with different oils. Are there any other company replacements that could be substituted?
Also, I threw my front center drive coupler pin right through the plastic sleeve this weekend. Is this why some people were buying those machined sleeves? The part was clearly worn out and was apparently wearing its way thru the plastic for a while. When I tried to rebuild it, the standard pin wouldnt even stay in, it was about 1 - 1.5 mm too short. I had to cut a new longer pin from an old stock 1.9 swaybar until I can order a new shaft assembly.
RedDevil13 is offline
Old 10-31-2011, 07:13 AM
  #23607
The diff cases came in and passed QC and should ship out to the BO's today or tomorrow. There are not too many on BO at thsi time so they are around.
hacker07 is offline
Old 10-31-2011, 07:28 AM
  #23608
BashemSmashem's Avatar
Were they changed at all to help with the way the metal inserts were loosening and making the diff leak ?
BashemSmashem is offline
Old 10-31-2011, 07:32 AM
  #23609
No they were not. They fit very tight from the get go so not much else can be done past a complete re-design and that isnt going to happen at this point. Just have to glue the inserts in and it works well.
hacker07 is offline
Old 10-31-2011, 07:34 AM
  #23610
Benny 13's Avatar
id like to get my hands on the new diff gears and cases..... how will one find who has these updated parts???
Benny 13 is offline
