Like Tree9Likes
Old 10-28-2011, 06:47 AM
  #23491
Asharus's Avatar
Trader Rating: 42 (100%+)
Originally Posted by XXXDad View Post
Make sure when you thred the thredded rod into the plastic... you go till they bottom out ,all the way.... if not your crack them<
Really? I havent checked mine for cracking but I didn't do this. I just made sure it was halfway in to give an even amount of support between the rod and the rod end.
Asharus is offline
Old 10-28-2011, 10:07 AM
  #23492
Default tapered angle
Originally Posted by dtr View Post
What angle are these tapered to? 45?
the angle is 60 degrees included
m2cracing is offline
Old 10-28-2011, 01:35 PM
  #23493
10sctrel0v3r's Avatar
has anybody tried a torque rod in the front also?
10sctrel0v3r is offline
Old 10-28-2011, 02:41 PM
  #23494
Ran the truck today for the first time. Corners great, but on the blown out jump faces, it nosed over every time. My battery is back and my rear ride height is 29mm, front is 27mm. Should I try moving the battery forward so there is less weight in the rear? It seems the rear still bottoms out on the jump face when I increase my ride height. Also, is it possible to fit a 21t pinion with the stock mount?
MMor101 is offline
Old 10-28-2011, 02:59 PM
  #23495
BmainStar's Avatar
No 21 t wont fit stock mount.The jumps themselves could be part of the problem,try to let off as you approach the jump and then pin the throttle and don't let up until you come to land.or just keep it pinned from start to finish. If this is your first 4x4 sct it takes some drive time to figure out the characteristics of this type!Look at the jumps closely, and do not run drag brake or push control on your speedo! Cheers!
BmainStar is offline
Old 10-28-2011, 03:05 PM
  #23496
vasidudu's Avatar
I think this is what you require.
This also.
Not sure though... Anybody on this?
Saw it in the thread somewhere but can't seem to find it now...
I am trying to see myself as I would like to gear up on my CC MMP 2400 Kv.
Best,
V
vasidudu is offline
Old 10-28-2011, 03:10 PM
  #23497
BmainStar's Avatar
This also.
Best,
V
Hey V ,also check the Elite r/c mnt for the SCTE
Old 10-28-2011, 03:19 PM
  #23498
vasidudu's Avatar
Did already, a bit too much for me at $70/75.
Here?
Best,
V
vasidudu is offline
Old 10-28-2011, 03:30 PM
  #23499
BashemSmashem's Avatar
This also.
Best,
V
Wont work , the hole spacing is wider on the 8ight mount .
The Elite mount is expensive but worth it IMO as it wont flex/strip like the stock mount can .
BashemSmashem is offline
Old 10-28-2011, 03:46 PM
  #23500
For a more blown out track, I would consider making sure your truck is flat or even a little rear lower..so go to 28mm front and rear or even go 29f, 27r.
hacker07 is offline
Old 10-28-2011, 04:37 PM
  #23501
vasidudu's Avatar
Thx for the info...
Was going to order the losi one...
Any other alternative to go above 19T pinion?
Best,
V
vasidudu is offline
Old 10-28-2011, 04:41 PM
  #23502
R/C Tech Elite Member
JayL's Avatar
Is there a tool available to remove the shock cartridge or just pliers?
JayL is offline
Old 10-28-2011, 04:45 PM
  #23503
The kit comes with 2 plastic tools for doing this ....
Old 10-28-2011, 05:05 PM
  #23504
JayL's Avatar
hmm, I have one tool for the cap and one tool that holds the shock body, the cartridge that holds the o-ring is smaller than the body...am I missing a tool or using one wrong?
JayL is offline
Old 10-28-2011, 06:15 PM
  #23505
Trader Rating: 70 (100%+)
Has anyone else managed to strip the holes in the rear diff (gear housing)? not the actually diff itself, but the housing around in.
Somehow, the two short screws just fall out now.
Krafcik is offline
