Like Tree9Likes
Old 10-25-2011, 07:18 AM
  #23296
larlev's Avatar
Originally Posted by stevepowling
It's all personal preference. I wanted to try it to see what it was like and felt a difference so I stuck with it.
I agree...I just had faster laps with bladders
larlev is offline
Old 10-25-2011, 07:20 AM
  #23297
stevepowling's Avatar
...and I had faster without
stevepowling is offline
  #23298
lowroad's Avatar
Trader Rating: 79 (100%+)
dude, nice.
lowroad is offline
Old 10-25-2011, 07:25 AM
  #23299
lowroad's Avatar
I have tried emulsion and feel the hype is unjustified. Build your bladders with zero rebound and you will get excellent landing and handling shocks. IMO
I can see emulsions on a lighter vehicle, but our Fat Girls like bladders....kidding of course
If team drivers used 4 different tires in all 4 corners....most would do it also thinking it will make us faster.
I love you.
lowroad is offline
Old 10-25-2011, 07:27 AM
  #23300
Originally Posted by Littlejohn Dsgn
Nice work, I was about to drill out my arms, but now I will just pick up a couple sets and cut them to length.
I thought they looked smaller in dia. so I went on lunsfords site they are by alot.!!! the old ones are 3.5mm with is .1378 in dia. and those are .124 in dia.
that would be alot of slop. imo
I would think you would have alot of play in the arms, and would be more prone to rip the arm apart?? but I might be completely wrong please let me know how it works out.
Mike1977 is offline
Old 10-25-2011, 07:30 AM
  #23301
larlev's Avatar
Originally Posted by Speedy S
The setup I have now are with the bladders in the shocks. I havent tried emulsion yet but everyone is saying so much better than bladder. My setup seems to be pretty smooth and everything. I cant complain about it but I thought I would ask and maybe try it sometime.
Steve is exactly correct...it's all personal preference. Too many times we see guys doing things because the next guy does it. You be the judge on what works for you. If you run faster with a certain setup...keep it.
There are a lot of blanket statements on what works best, I've learned it's best to do what works for me...if your a racer let the clock decide.
larlev is offline
  #23302
Originally Posted by Mr.juarez
hey lowroad..
i just put some hinge pins i had from my revo into the scte arms and they fit perfect, so i think. they are slightly on the free side, but most people are drilling the arms anyways. mine arent drilled so they fit fine. i have never bent or broke a stock revo pin in 3 years and they are about 1 inch longer over the scte one. With that said lunsford makes the ti hinges for revo, so just get them at 8 dollars a set and cut them the right length for either stock or the snr hinge pin holders since they are thicker.
http://www.lunsfordracing.com/mm5/me...Code=TRUC-TRRE
sorry my comment was meant to be with this also.
Mike1977 is offline
Old 10-25-2011, 07:31 AM
  #23303
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
like i said they are a bit free, but people are drilling the arms anyways. it would be great if you can tap the ti rods and make them like the stock ones with 2 nuts on the outter hubs.
please let us know how it turns out
Mr.juarez is offline
Old 10-25-2011, 07:32 AM
  #23304
larlev's Avatar
Originally Posted by lowroad
I love you.
Hahahahahahahahaha....me too honey.
larlev is offline
Old 10-25-2011, 07:35 AM
  #23305
Littlejohn Dsgn's Avatar
Trader Rating: 47 (98%+)
Hmm I see that now, free is one thing loose is something else, might do some more looking around still.
Littlejohn Dsgn is offline
  #23306
Anyone out there switch from a 5 5 3 to 3 3 2 diff fluid set-up? I had this truck working pretty good outdoors but now on a tight indoor track I'm having trouble getting around the 180's. I've gone to the thinnest front sway bar and moved the hubs all the way forward and this helped free up steering but overall made it feel loose. I'm thinking I should start with lighter diff fluid and tune from there. Any thoughts or suggestions? Thanks.
Mototech is offline
Old 10-25-2011, 07:38 AM
  #23307
+1!
Old 10-25-2011, 08:08 AM
  #23308
Originally Posted by KingdomRacer
I bought this a long time ago and for the cheap price it isn't a bad item for an agitator because that is all it is.
I would not call this an ultrasonic cleaner, that is a different apparatus all together.
For guys looking for a real ultrasonic cleaner, I suggest going to HarborFreight, I own the model with a timer and it works great!
can i use motor spray or brake cleaner on it? i think it says you cant use flamable liquids.
psionic is offline
Old 10-25-2011, 08:31 AM
  #23309
Jenzorace's Avatar
Trader Rating: 17 (100%+)
Default Center diff outdrive wobble
I see everyone is more worried about upgrading their diff pins than worrying about the outdrive wobble. Whats it take to fix the wobble?
Jenzorace is offline
Old 10-25-2011, 08:53 AM
  #23310
Speedy S's Avatar
Trader Rating: 22 (100%+)
I agree. Im gonna try it and and check the lap times. But I have to find out what is needed to change to emulsion shocks from bladder shocks?
Speedy S is offline
