Like Tree9Likes
Old 10-24-2011, 02:17 PM
  #23236
Trader Rating: 70 (100%+)
Originally Posted by Potoczak
No you only fill the inner gear case.. The outer case should have some grease on the gears to keep them smooth.
Ok, so i cleaned the grease off the outer gears, how much should i replace it with? What grease?
Krafcik is offline
Old 10-24-2011, 02:26 PM
  #23237
What is a good diff oil set up to start with??
goompa is offline
Old 10-24-2011, 02:27 PM
  #23238
Divey's Avatar
Trader Rating: 119 (100%+)
I went to my local auto store and got the stickiest/tackiest grease I could find. Something that will stick on the gears and not be flung off. And just a small amount is needed. It goes a long way.
Divey is offline
Old 10-24-2011, 02:38 PM
  #23239
Great - thanks
Krafcik is offline
Old 10-24-2011, 02:41 PM
  #23240
Next question:
Trying to install the STEERING DRAG LINK from SNR.
How do you get the stock one out? I can't seem to get any of my hex wrenches to fit. What size is that?
Krafcik is offline
Old 10-24-2011, 03:33 PM
  #23241
SaladFork's Avatar
Chris you can always send your truck out to someone who can work on it for you.
SaladFork is offline
Old 10-24-2011, 03:37 PM
  #23242
eddomak's Avatar
Originally Posted by vasidudu
Hi there Casper,
Do not really feel like buying another whole set of screws (have that for my 8IGHT 2.0 and have barely used it).
What is the losaxxxx ref of these 4 screws that fix the motor mount from under the chassis?
Have used one from my 8IGHT 2.0 set but not the exact fit.
Thx for your input.
Best,
V
Hi, last time I asked this question it took a while for an answer as well. The part number is LOSA6262 which are 8-32 1/2. The 5-40 1/2 is too narrow a diameter.
eddomak is offline
Old 10-24-2011, 03:42 PM
  #23243
vasidudu's Avatar
Hi there eddomark,
Good to see u here again.
Thx for the losa6262 ref.
Though it seems it is also the part used with 8IGHT 2.0
Thx for your input, that manual is really bad compared with 8IGHT 2.0,
Best,
V
PS: was in Sydney last August, in Warroonga
vasidudu is offline
Old 10-24-2011, 03:44 PM
  #23244
SoCal Jared's Avatar
I was planning on picking up some bulk white lithium bearing grease or something of the sorts from Wallyworld. Any suggestion on what that sticky/tacky grease would be? I do notice that the losi and AE grease comes right off.
SoCal Jared is offline
Old 10-24-2011, 03:50 PM
  #23245
Trader Rating: 18 (100%+)
Default Tuner kit question~!!!
Any sugestions on where to set up the front and rear hinge pin sets???
Thanks for any feedback!
bot5024 is offline
Old 10-24-2011, 03:51 PM
  #23246
That is a great idea, but i thought i'd give it a try.
Krafcik is offline
Old 10-24-2011, 04:48 PM
  #23247
Cult Racing's Avatar
Trader Rating: 42 (100%+)
some new competition for the losi scte probably next year, another belt driven truck
http://www.youtube.com/watch?v=KdjNk...&feature=feedu
Cult Racing is offline
Old 10-24-2011, 04:52 PM
  #23248
StPete40's Avatar
Trader Rating: 45 (100%+)
Looks like an erector set.
StPete40 is offline
Old 10-24-2011, 04:53 PM
  #23249
lowroad's Avatar
Trader Rating: 79 (100%+)
ew.
lowroad is offline
Old 10-24-2011, 04:54 PM
  #23250
Divey's Avatar
http://www.teamfasteddy.com/team-fas...ission-grease/
I have something real close to this. Even the same red color. The one I use is called "Red "N" tacky #2" from Lucas Oil. I have used the Team Chase for my baja and it sticks to the gears just like it.
Divey is offline
