R/C Tech Elite Member
I will cut them for length when I get the stock...
Hi everyone,
Went through another pack this sunday.
Was not able to drive on our 1/8 track as it is being re-built.
So had to practice on the side (nice mix of dry short grass, sand, gravel, dirt etc...).
The thing is amazing; I was used to driving 4*4 1/8 buggy but this thing really has me wondering: 1/8 or 1/10?
The build is far stronger than my previous 1/10 (Tamyia and HPI).
If I had to buy another kit I would do it again no problem.
Have a good week,
V
Edit: anybody could remind me the part number for the motor mount if I am willing to go above 19T? Thx
Have a good week,
V
+1, elite RC motor mounts are good as gold!
hm, titanium bar stock eh...? I also wonder if I could harden the stock hinge pins myself to prevent this from happening again?
So, by itself? Not worth it. But if you are going CF for weight savings, then yea include that in the list of items.
Gah, I already ordered a set, thanks though. I think I am going to experiment with hardening them. It looks like they got sheared off clean at both ends by the aluminum hinge pin braces. That seems odd.
If you make them harder they will break easier because they may become too brittle .
I thought about that, but I'm not exactly sure. Don't we harden outdrives to keep them from keying and harden diff pins and washers to keep from wearing? and isn't titanium harder that steel or no? Maybe because of the direct force on the hinge pin instead of cyclindrical type wear like on a diff pin is why you say that? I'm no metallurgist, that's why I'm asking.
From soft to hard: aluminum, brass, T6 aluminum, bronze, titanium, mild steel, and stainless steel
gotcha, bashem is almost certainly correct then. hardening will more than likely just make em brittle. crap. Come on lunsford. My buddy snapped a pin yesterday on his too. same race and everything. Different jump.
If its a steel hing pin then you could try hardening them (thats if its a high carbon steel) however it will make them brittle and probably no good to use. If the force was being applied on top of the pin then maybe but the way the force would be applied I would expect them to break very quick.
If you are using Titanium you should not have to harden them, the titanium alone should be strong enough.
Im no metalurgist either but there are many different grades of titanium just like many grades of aluminun and steel...
