Like Tree9Likes
Old 10-23-2011, 10:55 AM
  #23146
84 GT 5.0's Avatar
Trader Rating: 26 (96%+)
Originally Posted by thecman26
Does anybody happen to know the dimensions of the pins in the cvds?
Mine look quite a bit worn down and I recently dropped the $95 for the tool to replace them.. Might as well use it!
what is this pin tool you speak of?
84 GT 5.0 is offline
Old 10-23-2011, 11:31 AM
  #23147
Divey's Avatar
Trader Rating: 119 (100%+)
Just to be sure if my motor is hot and esc 20-30* cooler I am under geared. Running the mmp/3800 geared at 12/40. It originally had a 15t pinion but it would get hot so maybe a 13 or 14t pinion. This is running on my track non stop the whole pack which is not long. I have not timed it yet but maybe 12-14 minutes.
Terry
Divey is offline
Old 10-23-2011, 11:40 AM
  #23148
namewasdallas's Avatar
Terry
I run the same exact setup, Im running a 16t and it temps at 145-155 and esc 128. I ran a 13t and it temped lower on both. I would gear up with a 13-14t pinion and call it a day.
I'm also running the castle fan on my 3800kv, Idk how much of a difference it makes
namewasdallas is offline
Old 10-23-2011, 11:42 AM
  #23149
rccrazy316's Avatar
when i win im going racing in this. yee haaaw
Attached Thumbnails Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-redneck-wins-lottery.jpg
rccrazy316 is offline
Old 10-23-2011, 11:48 AM
  #23150
Divey's Avatar
Ok, I will try that. I have no fans as the esc fan broke and I never had one for the motor but from testing it on my sc10 4x4, the esc dropped from 165-170*F to 150*F so they do make a difference. Nothing against using fans but I believe if your gearing/setup is right a fan is not needed. Also because anything I try to do to protect them they just end up breaking. One fan did last me over 4 months and that was because I did a direct connect so it stayed on the whole time. Thanks
Terry
Divey is offline
Old 10-23-2011, 12:14 PM
  #23151
afaberc's Avatar
Wow first day testing with my new chassis and tekin motor...... all I can say is wow it handles way different in a good way and has tons of power
afaberc is offline
Old 10-23-2011, 12:49 PM
  #23152
Bondonutz's Avatar
Trader Rating: 48 (100%+)
Another option for Team decals, we had this company make ours and they used some pics we sent for their website.
http://www.ajcustomvinyldecals.com/customorders.htm
Bondonutz is offline
Old 10-23-2011, 12:56 PM
  #23153
Trader Rating: 99 (99%+)
I'm looking for front/rear CV driveshaft sleeves. I know I have seen a few options out there but can't seem to locate the pages. Any help finding them would be appreciated.
isarctard is offline
Old 10-23-2011, 12:59 PM
  #23154
rcgod's Avatar
Trader Rating: 33 (100%+)
Anyone tried the m2c tapered pistons yet? Went from my regular setup of #3f/27.5 #5r/30 to them last night with 27.5f 25r and really liked them. Truck seemed to go thru the rough stuff better, but did seem a little lazier overall. Our track is mostly smooth and high bite so I think they would work well on rougher tracks. Still need to do some more tuning but overall I was impressed.
rcgod is offline
Old 10-23-2011, 01:04 PM
  #23155
Trader Rating: 86 (99%+)
Originally Posted by Doug D
Salad - Will Viper be coming out with a sensored 4 pole motor? If so, any price point, release dates, etc. I might have missed the answer amongst the melee in this thread recently. Thx.
I don't believe any price point or release date has been set but there is one in the works, I believe in order of release it will be the copperhead system, then a 1/8th scale specific esc, then after that the sensored sct setups. I'm not affilliated with viper so I'm just repeating what I have heard from pretty good sources ...
WideOpenThrottle RC is offline
Old 10-23-2011, 01:45 PM
  #23156
Trader Rating: 23 (100%+)
http://www.rctech.net/forum/r-c-item...e-sleeves.html
nitro0619 is offline
Old 10-23-2011, 02:05 PM
  #23157
Grandturk's Avatar
I'm pushing a lot in very tight - 180* - corners. Feels like push is coming on or off power. I have 5000 in the rear diff. Could this be too heavy?
Grandturk is offline
Old 10-23-2011, 02:16 PM
  #23158
way to heavy. try 3000 weight or 2000
cm.stites is offline
Old 10-23-2011, 02:40 PM
  #23159
KingdomRacer's Avatar
Originally Posted by ChefDementia
This is for the guys looking for an ultrasonic parts cleaner, Integy INDI Sparkle Parts Cleaner
I bought this a long time ago and for the cheap price it isn't a bad item for an agitator because that is all it is.
I would not call this an ultrasonic cleaner, that is a different apparatus all together.
For guys looking for a real ultrasonic cleaner, I suggest going to HarborFreight, I own the model with a timer and it works great!
KingdomRacer is offline
Old 10-23-2011, 02:41 PM
  #23160
Lucid's Avatar
yes
I never go above 3k in the rear
Lucid is offline
