Like Tree9Likes
Old 10-20-2011, 09:16 PM
  #22951
Trader Rating: 19 (100%+)
Originally Posted by rcgod View Post
Biggest difference between that setup and most others is the rear shock location on the lower arms. Try running on middle on arms instead of outer and if you start traction rolling reduce droop. If you still need more off power steering move rear hubs forward.
+1 and the emulsion shock setup if u havent already
nitro0619 is offline
Old 10-20-2011, 10:46 PM
  #22952
wcrase101's Avatar
Originally Posted by wcrase101 View Post
I been bouncing back and forth between both the 4000 and 4600 tekin motors, would like the 4600 but wondering how low it has to be geared, the elite motor mount will only let you gear down to a 13 tooth pinion. How low has anyone had to gear using this motor?
I will do the 4000 if I have to but would like a little extra rip. there have been times were I wished the 3800 castle had a little more on the top end.
last time I tried to gear the castle for a little more top end (16 tooth pinion) I fried my dean conector from both sides.
Originally Posted by Asharus View Post
13 is the lowest I've geared it at. I'm planning on running 13T on most small to medium tracks and maybe bump up to 14-15 for large 1/8 scale tracks.
thanks thats what I was nervous about if I ran into a situation where a 12 tooth was needed I would be in a bad spot!!
Originally Posted by Cult Racing View Post
I would just get a 13t and turn down the epa on the remote if you have too.
the real thing is I need more top end than I was getting with my 1410, just a little bit tho. no need to knock back the throttle with EPA my figure knows when to stop pulling the trigger. lol. I race on big tracks and small tracks so I will be using a range of gears to make it right for all the tracks.
wcrase101 is offline
Old 10-20-2011, 11:14 PM
  #22953
rcguy76559's Avatar
Trader Rating: 22 (100%+)
I run 16t with my 3800 just need a tad more top end I tryied 17t and i lost way to much on bottom end. But I never tried to change throttle profile on rx8 I always run 3. What do u guys run?
rcguy76559 is offline
Old 10-20-2011, 11:59 PM
  #22954
wcrase101's Avatar
I'm not sure but I can tell you my rx8/1410 didn't like the 16 tooth pinion thats for sure. I am using about medium punch, no timing on mine. no lipo cut-off.(well set-up for one cell close as I can get to no cutoff) funny thing was not the motor or esc was hot, not even the battery. but I sure melted both sides of the deans connector on the negitive side
how long did you run that 16 tooth in it and have you had that problem at all??
still wondering what went wrong
Old 10-21-2011, 12:27 AM
  #22955
BmainStar's Avatar
Originally Posted by snwchris View Post
Mechanical Eng background and use of Solidworks to layout helps alot.
But yea correct about the average joe
Yup! For you it`s just playin and tinkering then? I do machining for a living and just like a mechanic, all the cars he works on are dialed an his is a heap to get him to work LOL Every one is like bro you could make this and that ,but at the end of the day don't even want to look at a machine .. Do want to mill a chassis from scratch some day just to do it,from a solid so the kick up and side kicks are milled in and not stamped..Just for tinkering sake !.Cheers!
BmainStar is offline
Old 10-21-2011, 12:52 AM
  #22956
rcguy76559's Avatar
Been running 16t for 2 months now on 2cell. I have enough power everywhere with this heavy scte but could use more top end on the 120ft straight. Motor temps 160 esc 120. Never had any problem with connectors or wires.
Old 10-21-2011, 01:33 AM
  #22957
vasidudu's Avatar
Originally Posted by Mr.juarez View Post
hey the nano techs 6000 65-130c 2s pack are back in stock!
http://www.hobbyking.com/hobbyking/s...dProduct=17265
Yep,
Got 3 of these and they are great.
Although they are 2P (balancing is not as precise as 1P), they are screaming on my MMP 1415/2400Kv.
Looking into 3s now, what would you recommend with MMP 1415/2400Kv?
Have a good WE,
V
vasidudu is offline
Old 10-21-2011, 04:07 AM
  #22958
Default Lightening scte
So would it be fair to say that most people that race the truck have lightened it up? And to the people that have lightened it up are not disappointed in the outcome as far as performance.
Mike1977 is offline
Old 10-21-2011, 05:23 AM
  #22959
Toiffel's Avatar
Trader Rating: 52 (100%+)
Thanks, yes I've tried the shock positions, it helped but still not where I want it, did the emulsion shocks last night, and going to shorten the wheelbase.... I think I might have dialed out too much brake, and I'm just coming in way to hot into the corner.....
On another note, continued my center diff noise hunt, I still can't figure out what it is, I thought it was the spur-changed-still noisy, swapped the robinson pinion-still noisy, diff gears brand new, bearings in good condition......played with mesh and nothing....
Toiffel is offline
Old 10-21-2011, 05:27 AM
  #22960
rcguy76559's Avatar
i run heavy setup for large track and light setup for small tight track
Shorter wheel base will give less on power steering because u have more weight transfer to rear of truck but, shorter wheel base will turn sharper.
Old 10-21-2011, 05:44 AM
  #22961
Toiffel's Avatar
yes, my problem is not on power steering, it's off power push.....
Toiffel is offline
Old 10-21-2011, 06:20 AM
  #22962
slash24's Avatar
Default Suspension squeek
So i took my truck apart this week to clean out my diffs and put fluid in them. after i put my truck back together i noticed a squeek in the rear of the truck when I jounce the truck. has anybody else had any problems with this? it is not a performance problem, just one of those things you know is there and want fixed. can anybody help?
slash24 is offline
Old 10-21-2011, 06:21 AM
  #22963
rcguy76559's Avatar
run 3k front diff oil maybe softer front spring lower ride height in front. lighter front sway bar Could be tires. what tires you running?
Old 10-21-2011, 06:24 AM
  #22964
Asharus's Avatar
Trader Rating: 42 (100%+)
BBQ are you sure it's not the normal SCTE noise? If you're trying to get it to sound like your old SC10, it's not gonna happen, lol. You should hear mine, I bet it's a lot louder than yours, lol.
Asharus is offline
Old 10-21-2011, 06:27 AM
  #22965
Toiffel's Avatar
I went from 7 in the front to 5-it helped-, lighter front sway bar to no sway bar front-helped, and yes the biggest difference I noticed was tires, rebars and anything similar pushed too much, went to grid irons much better, but still pushes....
Toiffel is offline
