Like Tree9Likes
Old 10-20-2011, 04:57 PM
  #22936
rcguy76559's Avatar
Trader Rating: 22 (100%+)
Originally Posted by nitro0619
This was my thinkin also. Been workin on the truck setup to get my lap times down. Only things on my ride that differ from the few guys faster than me is that 4600 and an aftermarket chassis. Still torn on the chassis too
light truck works good for small tight tracks heavy works better on 8th scale tracks
rcguy76559 is offline
Old 10-20-2011, 06:48 PM
  #22937
StPete40's Avatar
Trader Rating: 45 (100%+)
Originally Posted by Cult Racing
not trying to start a fight over chassis again but here is the jammin lightened chassis:
http://www.amainhobbies.com/product_...t-Chassis-SCTE
Anodized black? That is going to end up looking like crap after 1/2 a pack?
StPete40 is offline
Old 10-20-2011, 06:58 PM
  #22938
Bondonutz's Avatar
Trader Rating: 48 (100%+)
Agreed
It does match Ed tho, I bet he gets ones.
Bondonutz is offline
Old 10-20-2011, 07:02 PM
  #22939
What size drill bit is needed to drill the shock caps? Tried searching and came up empty.
Mototech is offline
Old 10-20-2011, 07:09 PM
  #22940
DoogieLee's Avatar
Trader Rating: 42 (100%+)
http://www.gmksupply.com/html/gmk0108.html
DoogieLee is offline
Old 10-20-2011, 07:18 PM
  #22941
SoCal Jared's Avatar
Originally Posted by rcguy76559
only differents is more top end 4600 vs 1410 with the proper gearing for track.
SoCal Jared is offline
Old 10-20-2011, 07:26 PM
  #22942
Originally Posted by DoogieLee
Thanks. What size would you recommend?
Mototech is offline
Old 10-20-2011, 07:40 PM
  #22943
Trader Rating: 46 (98%+)
Originally Posted by larlev
Not unless you have money to burn....won't win you races alone
the 4600 might not win you races, but the 1410 has cost me one. battling for the lead and we went side by side around the last 180. we spun each other sideways and backwards. he kept moving on for the win and i had to wait formy 1410 to come back to life after rolling backwards.
nitroal is offline
Old 10-20-2011, 08:14 PM
  #22944
Toiffel's Avatar
Trader Rating: 52 (100%+)
Can anyone recommend a good setup for a tight/small track/clay/hard packed/indoor...
Currently running Aaron Lane setup, and it works great on my big track, but on the smaller one, it pushed like a dump truck...
Thanks in advance,
Toiffel is offline
Old 10-20-2011, 08:51 PM
  #22945
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
hey the nano techs 6000 65-130c 2s pack are back in stock!
http://www.hobbyking.com/hobbyking/s...dProduct=17265
Mr.juarez is offline
Old 10-20-2011, 09:04 PM
  #22946
rcgod's Avatar
Trader Rating: 33 (100%+)
Thanks in advance,
Biggest difference between that setup and most others is the rear shock location on the lower arms. Try running on middle on arms instead of outer and if you start traction rolling reduce droop. If you still need more off power steering move rear hubs forward.
rcgod is offline
Old 10-20-2011, 09:16 PM
  #22947
Trader Rating: 23 (100%+)
+1 and the emulsion shock setup if u havent already
nitro0619 is offline
Old 10-20-2011, 10:46 PM
  #22948
wcrase101's Avatar
Originally Posted by wcrase101
I been bouncing back and forth between both the 4000 and 4600 tekin motors, would like the 4600 but wondering how low it has to be geared, the elite motor mount will only let you gear down to a 13 tooth pinion. How low has anyone had to gear using this motor?
I will do the 4000 if I have to but would like a little extra rip. there have been times were I wished the 3800 castle had a little more on the top end.
last time I tried to gear the castle for a little more top end (16 tooth pinion) I fried my dean conector from both sides.
Originally Posted by Asharus
13 is the lowest I've geared it at. I'm planning on running 13T on most small to medium tracks and maybe bump up to 14-15 for large 1/8 scale tracks.
thanks thats what I was nervous about if I ran into a situation where a 12 tooth was needed I would be in a bad spot!!
I would just get a 13t and turn down the epa on the remote if you have too.
the real thing is I need more top end than I was getting with my 1410, just a little bit tho. no need to knock back the throttle with EPA my figure knows when to stop pulling the trigger. lol. I race on big tracks and small tracks so I will be using a range of gears to make it right for all the tracks.
wcrase101 is offline
Old 10-20-2011, 11:14 PM
  #22949
rcguy76559's Avatar
I run 16t with my 3800 just need a tad more top end I tryied 17t and i lost way to much on bottom end. But I never tried to change throttle profile on rx8 I always run 3. What do u guys run?
Old 10-20-2011, 11:59 PM
  #22950
wcrase101's Avatar
I'm not sure but I can tell you my rx8/1410 didn't like the 16 tooth pinion thats for sure. I am using about medium punch, no timing on mine. no lipo cut-off.(well set-up for one cell close as I can get to no cutoff) funny thing was not the motor or esc was hot, not even the battery. but I sure melted both sides of the deans connector on the negitive side
how long did you run that 16 tooth in it and have you had that problem at all??
still wondering what went wrong
