Like Tree9Likes
Old 10-19-2011, 06:46 PM
  #22846
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 105 (100%+)
Originally Posted by pizza View Post
EASY KILLER!!! not everyone is a seasoned racer, isn't that what these forums are all about. relax. most people including myself do not have time to look through 1500 pages to find one simple answer, thats why we ask the "seasoned racer" for help.
+1 to that...
I Just got my SCTE! Cant wait to get it on the track!
thecman26 is offline
Old 10-19-2011, 06:57 PM
  #22847
Originally Posted by StPete40 View Post
There is a vid on youtube by Tim Bump showing how to do it without the bleeder hole. I haven't done it that way, though. On the stock shocks I cut the center of the bladder out, drilled a small hole in the side of shock cap and filled the body to the top with oil. Start by threading the cap on, tilt at a 45 degree angle with the bleeder hole facing up, and turn the shock body. The fluid will bleed out of the hole. Pump the shock a couple times and finish with the shaft completely compressed. If you get rebound, loosen the cap and pump the shock again. You may have to fiddle with it a little, but its not too hard.
thanks
psionic is offline
Old 10-19-2011, 07:22 PM
  #22848
10sctrel0v3r's Avatar
if any one is deciding on a motor for their scte....go spend the money on the 4600 pro4! its amazing. i still cant get over how much more power and speed it has then my novak 5.5
10sctrel0v3r is offline
Old 10-19-2011, 07:36 PM
  #22849
Trader Rating: 19 (95%+)
Adjustable hinge pin braces"
This has ben covered NUMEROUS times, 0-0 F/0-0 or 1-0 R
Originally Posted by thecman26 View Post
+1 to that...
No, that is why you use the search function to see if it has already been (or how many times) answered. Then the thread wouldnt be 1500 pages long.
RedDevil13 is offline
Old 10-19-2011, 07:57 PM
  #22850
thecman26's Avatar
I don't know if you realize this, but this is a hobby... For fun...
We don't get paid to do this... It is for fun only for the most of us...
So we could do withou all the pompous attitudes in here, its a remote controlled vehicle... Not brain surgery!
You complain about the length of this thread? Yet you make a post that adds nothing to this discussion? Think about it...
Old 10-19-2011, 08:21 PM
  #22851
AEracer888's Avatar
so if my esc has bec problems how to you fix that??
AEracer888 is offline
Old 10-19-2011, 08:29 PM
  #22852
thecman26's Avatar
Well they make external BEC's that some say fix the issues...
Before doing that I would try a glitch buster like this:
http://www.amainhobbies.com/product_...iver-Capacitor
Just put this into an open port of your receiver....
If not perhaps a call to the tech support line of the ESC manufacturer before trying the external bec... They may need to repair it, thats all...
Old 10-19-2011, 08:38 PM
  #22853
couldnt agree more!
barry1me is offline
Old 10-19-2011, 08:43 PM
  #22854
rcgod's Avatar
Trader Rating: 32 (100%+)
What motor and servo are you going to run? Personal transponder or motor fan? Bashing or racing?
rcgod is offline
Old 10-19-2011, 08:51 PM
  #22855
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Originally Posted by Toiffel View Post
Anyone find the Robinson pinions are very noisy ?? I checked diffs, shimmed and re shimmed, and found the noise is coming from the center diff, bearings are good, mesh is set properly, swapped for a new spur, only thing I can think of is that the pinion itself is noisy....
Your pinion set screw could be rubbing against the motor mount.
BDRMBULLY is offline
Old 10-19-2011, 09:01 PM
  #22856
i quit running robinson racing as they are very loud to run
barry1me is offline
Old 10-19-2011, 09:03 PM
  #22857
Amain sells the Spectrum receiver cap for $4.99. Not sure if it is the same capacity as the Novak one (it probably is). One way to check if your ESC is having issues supplying enough juice to the receiver is look at the light on the personal transponder. If it blinks/flickers when you turn the steering servo then the voltage from the BEC is dropping. Whether it does it enough to cause a problem you just have to run it and see.
kcobra is offline
Old 10-19-2011, 09:05 PM
  #22858
The Hot Bodies pinions work well with the SCTE. They are the shortest you can get so they fit very well with the SCTE mount. I am running the 13t HB pinion on my SCTE.
kcobra is offline
Old 10-19-2011, 09:06 PM
  #22859
thecman26's Avatar
+1 yeah, pretty much the same thing...
Old 10-19-2011, 10:33 PM
  #22860
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
Castle Creation pinions are also very short and work great on the stock mount and the Elite RC mount .
BashemSmashem is offline
