Like Tree9Likes
Old 10-19-2011, 04:35 PM
  #22831
ScottKelly911's Avatar
Originally Posted by pizza View Post
ok i watched the emulsion shock video. i will try that. what weight shock fluids would you reccomend for a starting point?
Just a reminder for the new guys, the swaybars often come from the factory a little too tight. On the swaybar mounts there are two little screws that hold each side together. Wel in-between them there is a very small set-screw. Back the set-screw out to where the end of it is flush or slightly stcking out. This will free up the swaybar quite a bit. This was a source of binding that i couldnt find for the life of me until Ryan showed me. Loosened them and viola, no more binding.
ScottKelly911 is offline
Old 10-19-2011, 04:42 PM
  #22832
jmc23's Avatar
Default carbon parts
Originally Posted by jmc23 View Post
HERE'S A COUPLE PICS OF SOME CARBON FIBER SPLASH GUARD'S IM MAKING. IF ANYONE IS INTERESTED PLEASE FOLLOW THE LINK TO MY EBAY PAGE. THANKS GUYS........GREAT PRICE TOO....
http://cgi.ebay.com/ws/eBayISAPI.dll...m=300601653197
these are a great add to a great truck. 19 sets left.
jmc23 is offline
Old 10-19-2011, 04:48 PM
  #22833
rcgod's Avatar
Trader Rating: 32 (100%+)
Originally Posted by AEracer888 View Post
is the mamba max pro a good setup for this car? i need a motor and esc that will run 3s and is reasonably priced
Yes. That esc will work well, but you might have problems with the bec. Then again you may be one of the lucky few that don't.
rcgod is offline
Old 10-19-2011, 04:54 PM
  #22834
AEracer888's Avatar
im new to electric, what is the bec?
AEracer888 is offline
Old 10-19-2011, 04:57 PM
  #22835
namewasdallas's Avatar
So I got my TLR Kit in the mail today, Are they suppose to come with a screw to make them emulsion style?????? Because mine have a tiny hole for it but no screw.
Also I'm doing the Aron Lane setup but which front block plastic thing do I use as there is multiple ones but I didnt see it on the setup sheet. I'm talking about the angel pieces
namewasdallas is offline
Old 10-19-2011, 05:14 PM
  #22836
porkchop's Avatar
there is no screw when you tighten the shock cap down the body and bladder seal it.
look up how to do 22 shocks and you get figure out
porkchop is offline
Old 10-19-2011, 05:27 PM
  #22837
can someone tell me which number angel pieces to use for what angels for the front and rear sup.
Old 10-19-2011, 05:34 PM
  #22838
KIK
KIK's Avatar
Trader Rating: 26 (100%+)
This was the first round of our winter series. Unfortunately, a Durango took 1st but the rest are Losi's
http://www.youtube.com/watch?v=KhTzzfTpD20
KIK is offline
Old 10-19-2011, 05:43 PM
  #22839
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
0 degree will give you stock settings .....
BashemSmashem is offline
Old 10-19-2011, 05:44 PM
  #22840
Bondonutz's Avatar
Trader Rating: 48 (100%+)
"Adjustable hinge pin braces"
This has ben covered NUMEROUS times, 0-0 F/0-0 or 1-0 R
Bondonutz is offline
Old 10-19-2011, 05:55 PM
  #22841
rcgod's Avatar
Bec is the internal circuit in the speed control that drops battery voltage down to around 6.0v to power the receiver and servos and anything else you might have plugged into the receiver.
rcgod is offline
Old 10-19-2011, 05:58 PM
  #22842
Lap Traffic's Avatar
It is a "Battery Eliminator Circuit" it lowers the voltage and uses the same battery that powers the motor to power the servo.
Lap Traffic is offline
Old 10-19-2011, 06:12 PM
  #22843
Trader Rating: 41 (100%+)
I see that someone has asked about using orings in the shock caps instead of cutting the bladders,Has anyone tried this yet? if so,how did it work out?
Thanks,
rifraf is offline
Old 10-19-2011, 06:34 PM
  #22844
Toiffel's Avatar
Trader Rating: 52 (100%+)
Anyone find the Robinson pinions are very noisy ?? I checked diffs, shimmed and re shimmed, and found the noise is coming from the center diff, bearings are good, mesh is set properly, swapped for a new spur, only thing I can think of is that the pinion itself is noisy....
Toiffel is offline
  #22845
EASY KILLER!!! not everyone is a seasoned racer, isn't that what these forums are all about. relax. most people including myself do not have time to look through 1500 pages to find one simple answer, thats why we ask the "seasoned racer" for help.
pizza is offline
