Like Tree9Likes
Old 10-19-2011, 01:37 PM
  #22816
ok i watched the emulsion shock video. i will try that. what weight shock fluids would you reccomend for a starting point?
pizza is offline
Old 10-19-2011, 01:50 PM
  #22817
jwemail's Avatar
i run the lane set up with 30wt front and rear, black springs front, and orange springs rear. i run on a tight indoor high bite dirt track,
jwemail is offline
Old 10-19-2011, 01:51 PM
  #22818
Asharus's Avatar
Trader Rating: 42 (100%+)
FYI u need the 4 pistons in the rears to run the lane setup
Asharus is offline
Old 10-19-2011, 01:55 PM
  #22819
lbckevin's Avatar
Trader Rating: 96 (99%+)
Losi 30wt
lbckevin is offline
Old 10-19-2011, 02:08 PM
  #22820
Buster661's Avatar
Originally Posted by lbckevin View Post
Losi 30wt
I run Lanes setup as well with 27.5wt. I run outdoors mostly on a medium sized 1/10 & 1/8 scale track.
Buster661 is offline
Old 10-19-2011, 02:11 PM
  #22821
dtr
dtr's Avatar
Originally Posted by Divey View Post
Have you guys noticed the hinge pins in the rear arms are tight. Tight to the point where the suspension does not rebound back up. I had to drill them out some to get them to move freely.
You might have tightened the long srews that hold the rear hinge pin brace and the bumper, you have to back it up half or three quarters of a turn from full, that helped for me.
Originally Posted by StPete40 View Post
I'm running in-door carpet. Is the 4600 going to yield a better setup? Having heat issues now with all that traction and starting/stopping.
The 4600 is the only Y wind pro4 motor, so geared for the same speed it should run cooler then the others.
dtr is offline
Old 10-19-2011, 02:17 PM
  #22822
rcgod's Avatar
Trader Rating: 32 (100%+)
Even when new my hinge pins bound in the arms. Drill or ream them. You still have to check them occasionally as dirt get in there.
rcgod is offline
Old 10-19-2011, 02:18 PM
  #22823
Is there a big difference between the lane and Casey peck setup? And thanks for all the input on the shock fluid
pizza is offline
Old 10-19-2011, 02:38 PM
  #22824
Divey's Avatar
Trader Rating: 109 (100%+)
Originally Posted by BDRMBULLY View Post
i find the holes dont line up properly like the a arm twisted. time for a new set of arms or ream the holes larger and drive it like you stole it.
This is exactly how mine were. I drilled them out with a drill and now they move freely. Also the sway bar link where the ball end goes into the plastic was tight which was also causing binding. After reaming that out with the hinge pins it super smooth.
Divey is offline
Old 10-19-2011, 03:22 PM
  #22825
jwemail's Avatar
oh yea the (stock) 3 piston front and 4 piston rear, sorry, the only thing i did differently was move the rear shocks on the tower to the outermost hole.
jwemail is offline
Old 10-19-2011, 03:33 PM
  #22826
AEracer888's Avatar
is the mamba max pro a good setup for this car? i need a motor and esc that will run 3s and is reasonably priced
AEracer888 is offline
Old 10-19-2011, 03:58 PM
  #22827
Trader Rating: 62 (100%+)
new losi scte guy. last weekend at track broke rear dogbone that goes between diff and wheel axle. are there any upgrades for these? any help would be great. started with a slash 4x4 and cant believe what the difference is in the 2 trucks. im sure it may have been brought up before but if any one can help thanks.
buckeyenut73 is offline
Old 10-19-2011, 04:05 PM
  #22828
Casper's Avatar
Trader Rating: 34 (100%+)
No upgrades I am aware of. I would not say this is common. How are your outdrives? I would just replace but make sure you use some black grease on the CV joint before you put it back in. Did it breat at the outdrive or the axles size?
Casper is offline
Old 10-19-2011, 04:11 PM
  #22829
how many people throw a nitro motor into the scte roller? I just about finished my 810 to Scte conversion.
Mattpar is offline
Old 10-19-2011, 04:32 PM
  #22830
casper it broke at outdrive side. any online store have best prices on losi stuff? lhs is a joke with inventory, but i guess tmaxx's are still cool.lol
