Hey fellas, I haven't searched through this thread to see if this has been brought up or not, but, I've gone through the diffs on my scte, including a full set of complete brand new diffs, and they seem to be the worst meshing diffs I've ever had the displeasure of building or rebuilding! I've found that filing the sharp casting edges off the gears help, but they still aren't nearly as smooth as any of the numerous diffs I've built before. Has anybody had this issue, and/or figured out a solution to this?
Nice, thanks for the heads up! So is Losi gonna hook us up with these, or am I, and everybody else gonna need to shell out a bunch more cash to replace all six of the diffs I have for this thing?
Between all new gears going into RTRs and no new part# to differentiate between new and old versions, I'd guess it will be January before anyone that has already bought this truck will see new gears. I've owned the truck for six months and everything wheres out eventually. Why not earmark some of those for replacement parts so we can get our hands on them?
There really is nothing "wrong" with the current gears. They work fine and all of use have had good luck with them. Most all gear failures were due to the first batch bad pins. The current gears work fine. Let them break in a little and they should smoothen out on there own just fine. The new replacement gears are just higher quality. Another sign Losi is always working to improve there product. Again nothing really wrong with the current gears.
Finally got to run the truck today and it ran pretty well. Using a MMP/3800 geared at 15/40 it came off at over 170*F on both motor and esc. The esc fan does not work so maybe that could contribute to the higher temps. Should I gear down to a 13 tooth or stay where it's at. Other than that there were no issues at all. Truck feels very planted and very easy to drive.
Terry
Terry
I would say how is the connection of the battery, alot of people seem to have issues with the Deans plugs. I know I've replaced a couple of deans cause of bad connection/solder joint.
Check your driveline to make sure everything spins freely and that you dont have a bad bearing somewhere as well.
I just wanted to give an update as I was down in QC and they are checking in Fr/Rr gearbox sets and I know some of you were looking for them so they should be back in stock within the week at your local shops.
I have had my Losi for 2 weeks now and haven't gotten to drive it yet because my LHS don't have shit for parts so I have to order everything online and im waiting on a dumb reducer for the mod 1 pinion to work with my older version Castle 3800kv. Everyone keep your fingers crossed my Parts come into today so I can drive this truck
its killing me...
see below
We will not be replacing gears for all those using the truck for months and even years now just because we made a new mold. It was time for a new mold, thats all. The old gears work great and since we fixed the pins, I have heard very little of any issues with the diffs. Parts wear out and that includes gears inside diffs, so if you have some that have worn, you may want to pick some new ones up. Whether you get the existing ones or the latest mold ones, both work great.
They will be available. They old gears were fine. The old mold wore out and the new one is better. Call it a process improvement. Just because something was good enough before does not mean it could not be better. There is nothing functionally wrong with the current gears. They fit, work and hold up to abuse. The new ones have a litle better finish on them and seem to mesh just a touch better. Great. A benefit ot all the replace them. That does not mean Losi needs to hand out new gears to everyone? Just because something was improved does not necessarily make the thing it replaced defective.
We all spend too much on our toys. If it was not R/C cars it would be jet ski's or paintball or bars or pick another vice.
For cryin out loud! One more comment. I'm asking for the opportunity to buy them! Not asking for them to be given to me because I said anything is broken. Pimp them, pump them up on the forum, and then sell them! Don't talk about them for 4 months while you put them all in an RTR box for some kid to buy that doesn't know the difference between Losi and Traxxas.
Sorry got you confused with TheRevolution post.
