Like Tree9Likes
Old 10-13-2011, 06:10 PM
  #22186
Originally Posted by NitroLuver View Post
dumb question but how are you guys mounting the pro-4 motors? I looked at mine and in order for it be mounted with the solder tabs vertical I have to use larger screws(but they don't fit the losi mount(do I need to rotate the front of the case or what?
Mine points toward the outside of the body at about a 45 degree angle. It's a good question, I need to get some other screws to rotate vertically.
coffee is offline
Old 10-13-2011, 06:21 PM
  #22187
DBL15's Avatar
Originally Posted by vasidudu View Post
thx there.
so i am cool running 17T 19T pinions for a starter on a mid size 1/8 track?
thx for the input,
V
edit: hey DBL15, was in coolangatta last summer (winter for you)
will probably be here again this Xmas
QLD rocks!
very nice place place hey i live about 15 mintues away from there
our winter would be a summers day for you wouldn't it
yeh i think you would be fine with the 19T depending on track size even up to a 20 on a 1/8th track
DBL15 is offline
Old 10-13-2011, 06:22 PM
  #22188
Trader Rating: 46 (100%+)
Originally Posted by Integra View Post
Correct. Rotate away.
yea I just loosened the screws and rotated the front plate, initial tests suggest this thing has some power, off to the track..will report temps and stuff later
NitroLuver is offline
Old 10-13-2011, 07:23 PM
  #22189
larlev's Avatar
thx bondonutz and saladfork
always great to have expert advice.
waiting on my 19T then
best,
V
I ran 20t on outdoor track....19 or 20 will be perfect. Temps will be well within normal range. set 0 timing, low start power, no punch for the 2400.
larlev is offline
Old 10-13-2011, 07:24 PM
  #22190
larlev's Avatar
Originally Posted by m2cracing View Post
m2C Racing is pleased to announce the release of our new 8 hole tapered
shock pistons for the sct E truck.
made of delrin for durability and precistion machined with .006 clearance from the shock body.
The .006 clearance is best we have found and makes the shocks silky smooth.
attributes of the tapered pistons:
more turn in
allows the truck to settle much quicker over the jumps
is great in the whoop sections of the track.
The 8 hole piston come with .8 mm hole to allow you to run basicially the same wt shock oil
you may have to adjust up or down for you particular driving style.
part no. m2c7125
www.m2craing.com
What makes these different (handling wise)from 2 stage pistons that are out? Just curious
larlev is offline
Old 10-13-2011, 07:42 PM
  #22191
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 105 (100%+)
Originally Posted by larlev View Post
What makes these different from 2 stage pistons that are out? Just curious
Looks like the only difference is that M2C racing made them...
thecman26 is offline
Old 10-13-2011, 08:11 PM
  #22192
KingdomRacer's Avatar
Originally Posted by mjealey View Post
What motor and ESC combo are you running? That is some pretty high gearing and I doubt it will work (temps) on 2s. Highest I have been able to run is 15t. I would probably advise against that gearing!!! When I run on a huge 1/8 track I run a 15t, other than that usually a 13t!
I run a 40/17 on an 1/8 scale track with no probs whatsoever w/1410 on 2s.
I do however cut back when I put in the 4600kv in and only run 42/15 with that.
KingdomRacer is offline
Old 10-13-2011, 08:30 PM
  #22193
Buzz3's Avatar
Over 1 million views. Pretty cool, congrats to Losi for making us a toy that gets this kind of attention.
Buzz3 is offline
Old 10-13-2011, 08:54 PM
  #22194
Factory Seal's Avatar
Trader Rating: 29 (100%+)
X2....WOW!....thats Freakin Awesome!.....
i never even noticed the count was so high...........
Factory Seal is offline
Old 10-13-2011, 08:58 PM
  #22195
ChefDementia's Avatar
Trader Rating: 19 (100%+)
Switching to a Sc4x 5.5 for a couple days since I sold my 4.5, what pinion should i start at? 15, 16, or other/
ChefDementia is offline
Old 10-13-2011, 09:09 PM
  #22196
Cult Racing's Avatar
Trader Rating: 42 (100%+)
Just got these today: Losi Bolt on hexes (sorry for the dirt, ran it last night and havent had the chance to clean it yet.)
Cult Racing is offline
Old 10-13-2011, 09:14 PM
  #22197
Integra's Avatar
15 was what I used to run or even as high as 17 If you got a Big Enough heat sink/Fan combo
Integra is offline
  #22198
thecman26's Avatar
lookin good! I may need some of those too!
Old 10-13-2011, 09:31 PM
  #22199
here they are - http://www.amainhobbies.com/product_...heel-Hex-Set-2
Old 10-13-2011, 09:38 PM
  #22200
thecman26's Avatar
Just added them to my wish list..
I try to limit myself to one order a week!
But my next order... Will have those on it!
