Like Tree9Likes
Old 10-06-2011, 03:41 PM
  #21676
Briguy's Avatar
Trader Rating: 125 (100%+)
Turnigy Nanotech lipo .
Briguy is offline
Old 10-06-2011, 03:45 PM
  #21677
larlev's Avatar
He means what ESC...
Looking good Salad. Can't wait to get one
larlev is offline
Old 10-06-2011, 03:53 PM
  #21678
SaladFork's Avatar
Originally Posted by Casper
So what is powering that?
Also you put the battery in the other way and you can run shorter battery wires!
Early version of the Copperhead, we don't want to show a pic because it's changed. Copperhead will be here early next week.
Next week!
SaladFork is offline
Old 10-06-2011, 03:55 PM
  #21679
Casper's Avatar
Trader Rating: 34 (100%+)
Next week!
Sorry I had to ask. I figured it was something like that. Glad to see you Viper guys constantly working on new stuff.
Casper is offline
Old 10-06-2011, 04:02 PM
  #21680
StPete40's Avatar
Trader Rating: 45 (100%+)
Hey Salad, whatcha using those Streetfighters for? We have been thinking about trying them out on carpet.
StPete40 is offline
Old 10-06-2011, 04:54 PM
  #21681
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Questions?? 12 mm but it's not a shimming issue i have found...
Originally Posted by XXXDad
What shim size is the center sprocket side shim? I have some binding and need that shim only one came and i need a few more! Help!
Originally Posted by hacker07
I am pretty sure its a 10mm id shim if you are referring to the ones that go near the outdrives...it currently only comes iwth the TEN T/810 nitro spur. In doing a search on horizons website, I found something from CRC, CLN4740.
OK anyone having a problem with the center dif not spinning free? I found my outdrive on the plastic side is rubbing where it comes through the bearing. Enough to not even let it spin at all.. So new outdrives are ordered and I might open the hole a tad with my body reemer . That is if the new outdrives rubb. Man... I wonder if this is what was making my truck nose dive? Like I was hitting the brake. Must be... I hope it is, cauz its been real anoying having people look at me like drive like crap. Hhahahaha!! Dokey flipping over the tripples all the time looks a lil bad...
XXXDad is offline
Old 10-06-2011, 04:56 PM
  #21682
jvroffroadrc's Avatar
A while back i saw casper or hacker suggest a base setup for a small tight indoor track but i cant seem to find it now, i checked all the setups on hh website and cant seem to find anything that seems to suit my needs. Could anyone give me any thoughts on what to try in the diffs for a really small tight indoor track with hard packed clay that doesnt have many jumps but is pretty buppy all the way around even in the short straights. I am running 5 5 3 right now and it did seam to be ok but since a few new guys got some rangos the lap times have been going down every week and now it seems like they just kill me threw the turns. I have tried just about everything except changing diff fluid because it worked just about everywhere i ran at but now i have to do something to try and keep up. It seems like they can just power threw the corners were i have to let way off to keep my line on the inside. So anyone that can help me out with any ideas i would greatly appreciate it since i am at a loss. Thanks for any help in advance.
jvroffroadrc is offline
Old 10-06-2011, 05:21 PM
  #21683
namewasdallas's Avatar
I'll prolly pick up the castle BEC once I get the servo only if its causing issues.
I dont race at a legit track, but at my friends house we have a track and 5-6 of us get out there and race, and I also have a track at my old man's house that I run my stadium truck on to pratice. I'm thinking of running at a legit track next year as there's one thats 80 miles away on the weekends which is perfect for me cause my uncle lives out there and I can just stay there and not pay for a hotel room for the night.
I thought the truck Also came with swaybars at least one set mounted on the truck, If it doesnt I'll deff pick up a set of sway bars.
I'll pick up the outdrives when mine show wear those arnt as important to me right yet.
What's the deal with the diff's needing shims and such ? Will I need to buy the shim kit or w/e its called to fix this issue or has Losi taken care of it?
- What should I start with for Pinions 15-19t?
- What weight Shock Oil? I currently only have Losi 35wt. for My E-firestorm
namewasdallas is offline
Old 10-06-2011, 05:25 PM
  #21684
Trader Rating: 25 (100%+)
One Viper VX4R 5200kv 4 pole.
Did you just cut up the stock servo/receiver mount? Or is that something else?
Mitten is offline
Old 10-06-2011, 05:46 PM
  #21685
SaladFork's Avatar
I do testing out back behind the office, we live in the urban jungle. I have never ran them it's been raining all week.
Yea that is the stock servo mount with the receiver. I just hacked it up.
Old 10-06-2011, 05:49 PM
  #21686
Pvd brett's Avatar
Originally Posted by FangsCPO
Sway bar kit?? Doesn't it already come with sway bars and different weight swaybars. I could've sworn mine did. Hmmmm.
mine didnt, maybe u got a super special giddy up and go package or sum'm. I bought mine. it does come with stock ones but i bought the others
Pvd brett is offline
Old 10-06-2011, 05:58 PM
  #21687
SaladFork's Avatar
Gotta make sure Ryan can keep up with you.
Old 10-06-2011, 07:20 PM
  #21688
Arigato's Avatar
Salad,
The can looks a little longer than a 540, is that a 540L or a 550? What gearing are you going to run with that beast?
Arigato is offline
Old 10-06-2011, 07:21 PM
  #21689
Trader Rating: 41 (100%+)
How are you guy's running the wire that goes from the ESC mounted behind the battery to the reciever box? I can find a place that I am happy with...all suggestions will be appreciated..Thanks for your help.
rifraf is offline
Old 10-06-2011, 07:31 PM
  #21690
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
Underneath the battery tray are wire clips that will hold the ESC wire , some are too short so you may need an extension .
BashemSmashem is offline
