Like Tree9Likes
Old 10-06-2011, 02:00 PM
  #21661
Pvd brett's Avatar
sway bar kit is a must have
Pvd brett is offline
Old 10-06-2011, 02:21 PM
  #21662
BmainStar's Avatar
Originally Posted by Casper
I don't think I have actually broken any parts on my truck. I have worn out drive shafts and outdrives and I keep shock o-rings and diff parts for rebuilds on hand but suspension wise I really have not had a failure. I had a screw come out of the caster block and a nut back off on the rear hinge pin but that is it. I would keep things like diff gaskets and such on hand and what ever you need to tune the car (shock and diff oils.)
Same here! The only thing I have bent or broken is the steel turn buckle,got spun on the strait and plowed into and jumped into the gate wall at our track a few times causing the bend.Other than that I have not broken a thing!!!(oops rear bumper doesn't count cuzz it is a bumper) LOLBen running since late Feb too!!!
BmainStar is offline
Old 10-06-2011, 02:24 PM
  #21663
omenwolf's Avatar
Trader Rating: 37 (100%+)
Originally Posted by Littlejohn Dsgn
Broke the rear bumper supports on the first race with the truck, no hard landing, I did get smashed into by a new driver but that was a direct hit in the back. No big deal no ones only 8 bucks. Cut down the new bumper so its not so wide maybe that will help.
Just not much meat to the plastic around the hing screw points.
hey Scott the one you got should have had the bigger bosses for the screws im surprised you broke it. but any kind of direct hit by one of theos truggys will do it. i have some more on the shelf waiting for you along with those carbon tower we talked about. The only one i broke was at rise those 1/8th jumps are killer.
omenwolf is offline
Old 10-06-2011, 02:37 PM
  #21664
FangsCPO's Avatar
Sway bar kit?? Doesn't it already come with sway bars and different weight swaybars. I could've sworn mine did. Hmmmm.
FangsCPO is offline
Old 10-06-2011, 02:38 PM
  #21665
Casper's Avatar
Trader Rating: 34 (100%+)
Rear bumper was updated and should last a lot longer then the first gen of kits.
Casper is offline
Old 10-06-2011, 02:42 PM
  #21666
FangsCPO's Avatar
Originally Posted by namewasdallas
Cool im getting one for a good price online, I just hope i dont have issues with the BEC or w.e. We will see.
What are some good Option Parts to make this truck Handle. I just orderd front and rear set of racing springs for $35.00 all different lb. springs to find what works best.
I'm going to pick up the TLR kit as well, But is there anything else that will really make a difference?
You mentioned issues with the BEC. If you are referring to the MMPro, than I would strongly recommend you get the external Castle BEC for it. The best $20 you'll spend and you'll have one less thing to worry about.
The springs are a good purchase but really out of the box, this rig is top notch. If I was you, I would take it out to the track, try it out and see what you think. Than ask the other racers for their suggestions. Good Luck!
FangsCPO is offline
Old 10-06-2011, 02:46 PM
  #21667
We have started to slot our bodies a little to make sure they don't restrict chassis flex and are liking this little change so yeah I would say having a stiffer body can effect performance if not just slightly. Different bodies will produce different downforce as well if you have a high speed track.
Casper, I am building up my SCTE and would like to know where you slot the body. I will be going with a TLR chassis.
oldschoolnewb is offline
Old 10-06-2011, 02:53 PM
  #21668
Casper's Avatar
Pull the front holes back and the rear holes fwd a few mm. Does not take much but takes some stress off the body and allows the chassis to flex a little more. Worth trying.
Casper is offline
Old 10-06-2011, 02:57 PM
  #21669
porkchop's Avatar
porkchop is offline
Old 10-06-2011, 03:05 PM
  #21670
How do I know if I have the most recent kit? Aside from the chassis, what are the best lightening mods?
MMor101 is offline
Old 10-06-2011, 03:06 PM
  #21671
Casper's Avatar
There is a serial number on the battery tray. Odds of getting a first or second batch are extrememly low as those sold out quite quickly.
Casper is offline
Old 10-06-2011, 03:13 PM
  #21672
porkchop's Avatar
so if i looking at a brand new truck in my hands how do i tell what run is is by the numbers?
porkchop is offline
Old 10-06-2011, 03:18 PM
  #21673
Casper's Avatar
I don't know the answer to that. Sorry
Casper is offline
Old 10-06-2011, 03:30 PM
  #21674
SaladFork's Avatar
One Viper VX4R 5200kv 4 pole.
SaladFork is offline
Old 10-06-2011, 03:38 PM
  #21675
Casper's Avatar
So what is powering that?
Also you put the battery in the other way and you can run shorter battery wires!
Casper is offline
