Like Tree9Likes
Old 10-06-2011, 03:20 AM
  #21631
porkchop's Avatar
Originally Posted by DBL15 View Post
ok question guys
what does running thicker oil in the front do ? i see his set up 7 / 5 / 3
where as i am setting mine with 5 / 7 / 3
whats the pros and cons of heavy front oil ?
when you change your front diff
you lose off power steering
put you gain on power steering.
it helps pull the truck thought the turns as you get back on the gas.
droping your center diff is going to be less 4 wheel drive action in turn making the truck easer to drive and feel like you losen your slipper
think of it as a giant fluid filled slipper the bigger the number the tighter i just made my sliper
porkchop is offline
Old 10-06-2011, 03:22 AM
  #21632
porkchop's Avatar
@hacker07 what do we have to do to get pink bk bars for corr truck
i know it take like 15 years like did for st truck but i need some this year lol
porkchop is offline
Old 10-06-2011, 04:16 AM
  #21633
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Thumbs up Anyone else?
Originally Posted by XXXDad View Post
What shim size is the center sprocket side shim? I have some binding and need that shim only one came and i need a few more! Help!
Originally Posted by hacker07 View Post
I am pretty sure its a 10mm id shim if you are referring to the ones that go near the outdrives...it currently only comes iwth the TEN T/810 nitro spur. In doing a search on horizons website, I found something from CRC, CLN4740.
Thanks Hacker......
XXXDad is offline
Old 10-06-2011, 04:54 AM
  #21634
B.P.'s Avatar
Default Carbon Fiber Towers
Installed Xtreme Racing's 4mm Carbon Fiber Towers on my truck last week. Very Nice.
B.P. is offline
Old 10-06-2011, 05:34 AM
  #21635
namewasdallas's Avatar
Hey everyone, I'm new to this thread. I'm ordering the Scte today, I've done some research and this seemed to be the best truck out there winning races right now and i love the 1/8th scale chassis. I have a setup going into the truck and I want to get everyones advice.
Setup as follows-
-Mamba Max Pro
-Castle 2400kv, 3800kv, 4800kv. I have all 3 motors But my plans are the 2400kv for the extra torque it has over the other two motors.
-HPI 2.4ghz Transmitter/Reciever
- Servo???? Im not sure on servo's never bought one before But im thinking of going with Savox. Can someone point me in the right dirrection I have a $65.00 cap on Servo.
Upgrades- Carbon Front/Rear Shock towers.
- Aluminum Shock Caps so I can run them emulsion style
-Different Springs Front/Rear
- I have 35wt. Losi shock oil laying around is that to low a weight to use?
namewasdallas is offline
Old 10-06-2011, 06:17 AM
  #21636
stevepowling's Avatar
Originally Posted by SaladFork View Post
I've messed with it, never noticed a difference honestly (I still sucked lol).
Thanks for posting pics!
Originally Posted by BmainStar View Post
Not a bad question Bro!I think a rear wing would be more for adding downforce while at speed and not so much for mid flite leveling. On a bumpy track where the rear end is jumping around it may make it more stable tho!Cheers!!!
Thanks, I'll see how it goes tonight.
stevepowling is offline
Old 10-06-2011, 06:39 AM
  #21637
lowroad's Avatar
Trader Rating: 79 (100%+)
Salad, I'm not sure which is worse, the hideous cory hart bogus tattoo paint scheme, or the wing.
lowroad is offline
Old 10-06-2011, 07:23 AM
  #21638
Originally Posted by MercyRev View Post
Please let me know if anyone has had both Losi and AE 4x4
Just looking for honest opinion on pros and cons for both if you've ran both?
Thank you
Jason
I have both and race both. I turn my fastest laps with the AE but it is modified quite a bit from kit form. Unfortunatley the racers at my home track drive very rough and most of them run SCTEs. I got tired of being literally knocked off the track by the almost two pound heavier SCTEs so I bought one. Out of the box it is very easy to drive but becasue its heavy it can't carry the corner speed or jump as far as the AE. So if I manage to run and qualify well so that I can start up front for a race I'll run the AE. If I'm stuck back in the pack I'll bring out the Losi and give as good as I get.
Both have proven to be very heavy duty. The only DNFs that I can remember for either truck were electrical issues.
qwkpony is offline
Old 10-06-2011, 07:44 AM
  #21639
jmc23's Avatar
Default LOSI TEN SCTE CARBON FIBER SPLASH GUARDS
2 MORE SETS LEFT AND 20 MORE ON THE WAY. PRICE DROPPED TO A LOW 19.99. 1.2 MM CARBON FIBER SPLASH GUARDS FOR THE LOSI SCTE AND THE TEN-T. QUALITY PARTS MADE IN NY.
TO THE PEOPLE WHO BOUGHT THE OTHER SETS PLEASE POST SOME PICS AND LEAVE ME YOUR FEEDBACK...............THANKS JMC23
http://cgi.ebay.com/ws/eBayISAPI.dll...m=300601653197
jmc23 is offline
Old 10-06-2011, 07:49 AM
  #21640
Suspended
Does how thick and rigid the body is affect the handling of the truck. I just got my scte and I bought a desert rat carnage body also and the truck seems to lose the rear in the turns easier and nose dive with the carnage body.
MXRacer1 is offline
Old 10-06-2011, 08:19 AM
  #21641
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
It could by changing weight bias depending on how its designed and where the body is thicker or thinner .
That Carnage body is going to be different from a regular body because of the separate pieces and the velcro used to mount them .
BashemSmashem is offline
Old 10-06-2011, 08:40 AM
  #21642
Trader Rating: 19 (100%+)
Setup as follows-
-Mamba Max Pro
I have a brand new savox 1258tg i will let go for $55 shipped. Pm me if interested
nitro0619 is offline
Old 10-06-2011, 08:48 AM
  #21643
Casper's Avatar
Trader Rating: 34 (100%+)
On the diff build video. For the Ten Diffs LEAVE IN THE WASHER ON THE O-RING. The 8ight diffs you can get away with not running that thin washer but the TEN diffs hold up better with them.
We have started to slot our bodies a little to make sure they don't restrict chassis flex and are liking this little change so yeah I would say having a stiffer body can effect performance if not just slightly. Different bodies will produce different downforce as well if you have a high speed track.
Casper is offline
Old 10-06-2011, 10:17 AM
  #21644
Whats everyone have for Servo's in their SCTE's, Should I get one for speed or my torque? And would I have issues with my BEC I have a mamba max pro ESC and 2400/3800kv motor i plan on run?
I may possibly buy the Savox Nitro, I found the spec's would this work good to make this truck steer?
Specifications:
Speed @ 6.0V: 0.08 sec/60
Torque @ 6.0V: 166 oz-in / 12 kg-cm
Weight: 52.4g
Bearing: Dual
Type: Standard
Gear: Titanium and Aluminum
Case: Aluminum Heatsink
Output Shaft: 25T Spline (Futaba)
Case Size (LxWxH): 40.3x20x37.2mm
Anyways I just bought my SCTE for $299.99 shipped no Tax should be here 2-4 days I cant wait, I currently run a E-firestorm stadium truck and it the current setup is good for 65mph I've hit 70 with it on road.
Old 10-06-2011, 10:57 AM
  #21645
That servo will work decent , I like a little more torque but 166 is enough and its definitely fast enough .
