Like Tree9Likes
Old 10-05-2011, 08:15 PM
  #21601
Trader Rating: 15 (100%+)
I don't think the Integy station comes with the adapters you need. It does work on the SCTE with the correct adapters. I don't have the station near me but it should be the same adapters as the Blitz I had (both 4 mm thread axles) which would be the Type "C" adapters according to Amain...
http://www.amainhobbies.com/product_...-C-Adapter-Set
rcrules is offline
Old 10-05-2011, 08:39 PM
  #21602
thanks
psionic is offline
Old 10-05-2011, 08:40 PM
  #21603
stevepowling's Avatar
Even though it's not keeping with the scale look, have any of you tried running a wing on the body to help keep the truck level in the air while jumping (lexan wing, just like with stadium trucks)? I put one on my new practice body to give it a shot and see what happens.
stevepowling is offline
Old 10-05-2011, 08:49 PM
  #21604
DBL15's Avatar
Originally Posted by big chris
He said the compression of the O-ring leads to some binding of the outdrive. It's suppose to not leak unless you go a long time without a rebuild.
thanks mate must have missed that bit lol
ok i will stick with mine being in there as i dont change them around that much like most
DBL15 is offline
Old 10-05-2011, 08:53 PM
  #21605
lowroad's Avatar
Trader Rating: 79 (100%+)
Not only do I think that will look horrible and make the truck illegal, but a little lexan wing isn't going to do anything to stabilize a 6.5 pound truck I'm afraid.
lowroad is offline
Old 10-05-2011, 09:01 PM
  #21606
I didn't think it would do much but I figured it's worth a try. Going to try it out tomorrow and see what happens. No expecting much though.
Our SC rules up here are very loose, most tracks just run it as an open class and not worry about tech'ing trucks and such.
  #21607
Feint Motion's Avatar
Trader Rating: 24 (96%+)
lol
if you want a wing, get a stadium truck? lol
the scte just floats through the air, dont even see why you would even consider a wing. this isn't nascar lolol
Feint Motion is offline
Old 10-05-2011, 09:03 PM
  #21608
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Questions?? Shims
What shim size is the center sprocket side shim? I have some binding and need that shim only one came and i need a few more! Help!
XXXDad is offline
Old 10-05-2011, 09:06 PM
  #21609
Originally Posted by Feint Motion
lol
Sorry, I forgot not everyone in here is as helpful as Salad and Ryan.
Thanks for your input though.
Old 10-05-2011, 09:19 PM
  #21610
SaladFork's Avatar
I've messed with it, never noticed a difference honestly (I still sucked lol).
SaladFork is offline
Old 10-05-2011, 09:52 PM
  #21611
porkchop's Avatar
losi truck ordered now lets go racing boys
porkchop is offline
Old 10-05-2011, 10:01 PM
  #21612
I am pretty sure its a 10mm id shim if you are referring to the ones that go near the outdrives...it currently only comes iwth the TEN T/810 nitro spur. In doing a search on horizons website, I found something from CRC, CLN4740.
hacker07 is offline
Old 10-05-2011, 10:09 PM
  #21613
Trader Rating: 74 (100%+)
Ryan - any update on when the new center outdrives (with set screw to hold pin ) is going to be released?
bico1 is offline
Old 10-05-2011, 10:39 PM
  #21614
Moogumby's Avatar
Trader Rating: 32 (100%+)
i thought i would throw a pic of mine up.. using the ford raptor OSFM j-concepts body.
Moogumby is offline
Old 10-05-2011, 10:59 PM
  #21615
porkchop's Avatar
is dekotas nats set up posted any where?
porkchop is offline
