Like Tree9Likes
Old 10-03-2011, 03:38 AM
  #21391
ScottKelly911's Avatar
Originally Posted by big chris View Post
I have the Pro 4 4000 on my newest Losi 4x4 and it was reaching 180s in temps after 5 minutes with a 15T and 16T. What pinions are you guys running? I am using a Novak Kinetic ESC and 2s 65C batts. The ESC stays about 120-130. Could the ESC be a big factor in the heat of the motor? I'm planning on getting a RX8 but LHS was out of them.
If you're running timing, I'd turn it down quite a bit or drop a couple of teeth on your pinion. I went from running a 16T on my CC 1410 3800kv motor and dropped all the way down to a 13T on my Tekin Pro4 4600. dropping the tooth count on my pinion dropped my temps considerably and allowed me to still run a little bit of timing.
Originally Posted by lbckevin View Post
We had a fun night of racing at OCRC tonight. There were several fast guys in attendance from rctech...
In the mains...it was the Losi SCTE, in the top 6 out of the ten drivers...
Casper took the win with a Tekin Rx8 and Tekin 4600
Kevin (me) took second with a Tekin Rx8 and Tekin 4600
Scott Kelley took third with a Tekin 4600 and a XERUN 120amp speedo Fixed
Hacker07 ( Ryan ) took 4th , after his car shut off , while in second, but ran great..
Ryan runs Viper speed control and a Viper 550 motor.
Kevin, I had a blast running with you, Ryan and Casper tonight. Man, you are FAST! We all obviously know how fast Ryan and Casper are, but you're right there with them and you ran strong all night long! I was glad to finally put in a good showing after how poorly I did in the qualifying heats. Good seeing you tonight, hopefully I'll get to run with you more often. BTW, glad you liked running that Nano-tech 65-130c 6000mah bat, hard to believe how good of a battery that thing is for the price! Thanks for showing me how to look up my MAH on my charger too, can't believe i couldn't figure that out
Originally Posted by hacker07 View Post
Turns out I have a loose terminal for my battery connection...DOH!
DANG IT!!!!! Well that's a lot better than the esc like you originally thought! Good seeing you tonight Ryan, thanks for your help as always!
Originally Posted by wcrase101 View Post
is shoe goo just good for preventive maintence for a body or will it fix a body too. if it will fix bodies do you put it on over the body or under the paint? or is it best to use on the underside of body directly on the plastic?
does it dry clear and paintable if applied directly to the underside??
any help from the guys that have used this would be greatly appreicated!!!!
got a few weak spots on the scte body I need to touch up!!
It's both a preventative measure as well as a mending tool. I use drywall tape in the high stress areas, then Shoe Goo over it in several thin coats. This builds strength in the high stress areas and will prevent premature cracking. But as the body does get worn and does crack, you can use a piece of the drywall tape to hold the body together where the crack is, then use Shoe Goo again to fill and mend it and add strength back to that area. It works VERY well. The drywall tape really adds to the strength as well, not just the Shoe Goo but they should be used together. You can use Shoe Goo without using the drywall tape, but you can't use the drywall tape without using the Shoe Goo. Hope that helps!
ScottKelly911 is offline
Old 10-03-2011, 05:37 AM
  #21392
Trader Rating: 20 (100%+)
Originally Posted by xxxtruck View Post
Just put the bump chassis on mine and left the stock losi chassis braces. Is there anything I need to change.
any one
xxxtruck is offline
Old 10-03-2011, 05:38 AM
  #21393
is there some better shock bodyes coming out just changed oil and noticed blue coming off inside shocks
CASPER could you answer this
xxxtruck is offline
Old 10-03-2011, 05:43 AM
  #21394
Bondonutz's Avatar
Trader Rating: 48 (100%+)
Originally Posted by xDIEGOx View Post
I have a question for the guys that have owned this truck for a bit.
If you had the chance to buy the SCTE again, would you? Or would you go with something else?
Definitely, I own 2 now and couldn't be happier.
I've owned all the SCT's except the Durango and the AE4WD, the Durango is a sweet ride but parts availibilty and prices made me shy away and the AE is over engineered and looks troublesome to wrench on IMO.
Bondonutz is offline
Old 10-03-2011, 06:24 AM
  #21395
any one
Perhaps it would be quicker to use the search function, all of this info has been covered many times before.
In short you should run the brace that best suits the track you are on. There are a number of choices, some will require drilling a new hole, but I would suggest you run the truck with the current braces and only get other ones if you find it flexes too much for you in it's current state.
Starlite033 is offline
Old 10-03-2011, 06:26 AM
  #21396
Hacker has posted a number of times that they are developing Hard Anodized shock bodies. I haven't seen any dates for their release yet though.
Old 10-03-2011, 07:42 AM
  #21397
racerx1920's Avatar
Trader Rating: 215 (100%+)
Originally Posted by nv529 View Post
General question, what is the weight of the your truck with everything in it race ready?
mine is right at 6lbs according to my bathroom scale
racerx1920 is offline
Old 10-03-2011, 08:31 AM
  #21398
Divey's Avatar
Trader Rating: 109 (100%+)
subbed
Divey is offline
Old 10-03-2011, 08:42 AM
  #21399
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
Hope this helps ..... I do this to every body I run as it makes them last much longer .
It all goes on AFTER the body is finished , lay the fiberglass drywall tape down then squeeze out some shoe goo and then spread it out to cover the tape . I have found thinner coats to work better than putting it on thick as it flexes with the paint better . You also dont want to take too long spreading it out and moving the tape around as it can soften the pain while its wet .
It does dry clear and I use it on the outside as well when repairing cracks . You really need the drywall tape if you are repairing as the shoe goo by itself wont last long .
Come on over and check mine out if you are at CCX next saturday , hopefully I will be at RaceEm on Sunday but I'm not sure yet .
BashemSmashem is offline
Old 10-03-2011, 08:51 AM
  #21400
rcgod's Avatar
Trader Rating: 32 (100%+)
I have weighed several at our track. Stock with 550 motor 6.8#
I have mine down to 5.9#
rcgod is offline
Old 10-03-2011, 08:52 AM
  #21401
Casper's Avatar
Trader Rating: 34 (100%+)
You can use just show goo to protect the paint where the body might rub (under the body mounts and where the side nerf bars rub the sides of the body. For places you are looking to add strength the dry wall tape trick scott talked about works awesome. If you know were the body will crack I would add it up front. IT works for repairs as well but not as good as if it was there from the get go to prevent the crack in the first place.
Like already answered we are testing Hard Anodized shocks right now. They are working awesome and should be relased soon although I am not aware of an offical date yet.
Casper is offline
Old 10-03-2011, 08:53 AM
  #21402
SaladFork's Avatar
Oh SNAP! Getting close guys!
SaladFork is offline
  #21403
Casper's Avatar
Just saw a couple things on Losi's site that might make a few poeple happy.
http://www.losi.com/Products/Feature...rodId=LOSB3590
http://www.losi.com/Products/Feature...rodId=LOSB3591
Casper is offline
Old 10-03-2011, 08:55 AM
  #21404
lowroad's Avatar
Trader Rating: 79 (100%+)
seriously feelin that esc.
lowroad is offline
Old 10-03-2011, 08:58 AM
  #21405
lowroad's Avatar
are the diff screws longer like the HPI replacements? Grease looks like my finace's make up container
lowroad is offline
