Like Tree9Likes
Old 10-02-2011, 02:55 PM
  #21331
blktransam's Avatar
Trader Rating: 59 (100%+)
well just bought one thursday and ran it yesturday for the first time at LRT raceway in Waterloo IA for the annual Roat and Race...truck is f-ing dialed! ended up qualing 3rd and won the main, truck was on rails and was very easy to drive. only issue I am having is when I hit the brakes sometimes it makes like a grinding noise? everything feels smooth when rolling it by hand....and brakes r not locking up so I am not running to much brake?
blktransam is offline
Old 10-02-2011, 03:21 PM
  #21332
tobamiester's Avatar
Trader Rating: 341 (100%+)
Two weeks of running with mine (which I love btw) and mine is doing the same. I'd be interested in peoples opinions also. thanks
tobamiester is offline
Old 10-02-2011, 03:24 PM
  #21333
SaladFork's Avatar
It's the diff gears slipping on hard brake. You can shim the gears to mesh better and eliminate a little slop on the drives. Or dial your brakes down till you don't hear that.
SaladFork is offline
Old 10-02-2011, 03:28 PM
  #21334
Gotcha. Yeah I shimmed the center before I ran yesterday and it did the same thing. Did the same to the front and rear diff today and haven't tested it yet. Hoping that fixes the issue and maybe a little less brake programmed, like you said. cheers.
Old 10-02-2011, 03:41 PM
  #21335
retsoorkcuf's Avatar
just save yourself a lot of trouble and turn your brakes down I had same problem and shimming was a pain to get close and when I thought I had it right it still made the noise I was to the point were another shim would bind the gears and without would grind so I just turned the braking down a little and no noise and have been running that way for months with no problem I was running way to much brakes in the first place my rear end was coming off the ground when I hit the brakes all the way not good!
retsoorkcuf is offline
Old 10-02-2011, 03:50 PM
  #21336
Originally Posted by rbcts View Post
Hi guys,
What version of the pro4 is everyone using and gearing? Also does anyone know who has them in stock?
Thanks!
I ran 14t yesterday and the Pro 4000 was dialed on my 1/8 scale track. CL 70 Throttle Profile 3 Timing Profile 1
Lon_L is offline
Old 10-02-2011, 04:11 PM
  #21337
Trader Rating: 20 (100%+)
Originally Posted by Kevin_M View Post
Where can i find a carbon fiber chassis?
http://www.snrgraphite.com/
TeamOSG is offline
Old 10-02-2011, 04:21 PM
  #21338
Kevin_M's Avatar
Originally Posted by TeamOSG View Post
thanks
Kevin_M is offline
Old 10-02-2011, 04:42 PM
  #21339
SaladFork's Avatar
Looking for a front diff case, anyone know where to find one in stock?
Old 10-02-2011, 04:52 PM
  #21340
KIK
KIK's Avatar
Trader Rating: 26 (100%+)
I had the same thing happen on mine and I just kept running it. 3 quals later it was the rear diff gears and not the ring and pinion.
KIK is offline
  #21341
blktransam's Avatar
thats the problem I am not running too much brake, I tried turning them down to where it would barley stop the truck and same thing...will look into it some more idunno....when u say shim the diff are you talking the spider gears or the ring/pinion?
Old 10-02-2011, 05:13 PM
  #21342
Doug D's Avatar
Trader Rating: 61 (100%+)
Lon - What kind of temps on the motor were you seeing?
Thx
Doug D is offline
Old 10-02-2011, 05:15 PM
  #21343
Doug D's Avatar
Salad - Do you still have all those broken MMPs? LMK Thx.
Doug D is offline
Old 10-02-2011, 05:32 PM
  #21344
Pvd brett's Avatar
just finished a 3day event yesterday and posted a 3rd place overall with the first race with this truck. I was running an rx8 with pro4 4000kv and it was blazin a trail! super fast. after a lot of tuning to run on a blue groove dry track the truck was dialed. The first main would have gotten a 2nd place finish but my battery died on the last lap, dialed the current limiter back to 85% and had my dad plug me in and set me on the track.
posted 3rd place in every main and came home with the 3rd place overall so im stoked.
Pvd brett is offline
Old 10-02-2011, 05:39 PM
  #21345
SaladFork's Avatar
I have three of them a BEC and another one which is iffy (I took it apart), need to boot it up and try it.
