Like Tree9Likes
Old 09-29-2011, 01:40 PM
  #21151
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by KingdomRacer View Post
A smaller spur can have a smoother feel versus a larger spur which has more of an aggressive feel (acceleration), is it not?
And, I did agree that if same FDR is reached then it "should not" have an effect but actual testing showed me different. The evidence of this lies in your statement not taking into account on how you reached the same FDR.
Like I hinted before, I don't see it as much of a need since the Pro 4 came.
If you get too small a pinion your mesh gets all screwed up. Even though they are the same pitch the closer you can get the gears to be 1:1 the better the mesh. Sometimes you need bigger spurs to get the right FDR without going too small on the spur. Sometimes you need to go the other way as well.
Larger spurs will have a little more rotating mass but unless you are going from metal to plastic or something like that it should be impercievable.
Casper is offline
Old 09-29-2011, 01:44 PM
  #21152
alvinsmith75's Avatar
Trader Rating: 38 (100%+)
Default Setup Guide
This is the guide I have. Several people were interested in it so I just posted it here. I find it very helpful.
May be good for the front page.
File Type: pdf
alvinsmith75 is offline
Old 09-29-2011, 01:51 PM
  #21153
photobrat's Avatar
Trader Rating: 33 (100%+)
I dropped the new flex chassis (using RC8 rear brace) and a pro4 4600 in my SCTE and drove it for the first time with this new setup last night and I seem to have lost my steering both on and off power but REALLY badly off power. Diffs are 5-5-3, running Aaron Lane's JBRL setup otherwise, with Gridirons all the way around. Is this a consequence of the lessened weight?
photobrat is offline
Old 09-29-2011, 02:11 PM
  #21154
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
You sure there is no binding in the front diff ? Whats the track like you were running on ? Were your tires right for the surface ?
You should get better steering with the lighter weight on and off power , having the rear end stiffer might have a little to do with it . I also found that with the BCE chassis the RC8 brace was not needed as the 7075 is stiffer than the stock 6061 chassis and flexes less already .
I bet its not needed with the TLR chassis either ........
BashemSmashem is offline
Old 09-29-2011, 02:27 PM
  #21155
photobrat's Avatar
I'll check the diff, but I'd just opened it up and cleaned it the night before, and I believe it was smooth. High bite track when wet, low bite dry, hard packed clay, slightly rough these days. The track was varying last night, but even high bite, no good on the steering. Same tires I was running before and had great steering. Could/would droop affect the steering?
Old 09-29-2011, 02:38 PM
  #21156
Casper's Avatar
Yes droop can dramatically effect steering as it controls to an extent weight transfer.
Casper is offline
Old 09-29-2011, 02:40 PM
  #21157
SaladFork's Avatar
Added... Thx Alvin~
SaladFork is offline
Old 09-29-2011, 02:46 PM
  #21158
dtr
dtr's Avatar
Originally Posted by mjealey View Post
My 3800 and the Tekin 4600 have ran very hot after 10 minutes with anything larger than a 14 tooth. I do not see how a larger tooth is ran. That is with no timing, current limiter at 80%, ect.... I have also done all of the lightening mods too and mine is considerably lighter than stock.
Is the no binding in your driveline? Have you checked bearings, diffs?
dtr is offline
Old 09-29-2011, 02:47 PM
  #21159
dtr
dtr's Avatar
Originally Posted by KIK View Post
Anyone know the size of the pin in the dog bone? The end of driveshaft that rides in the outdrives.
12x3mm
dtr is offline
Old 09-29-2011, 03:06 PM
  #21160
R/C Tech Elite Member
JayL's Avatar
Does the Bump chassis have a hole for the Losi torque rod?
JayL is offline
Old 09-29-2011, 03:13 PM
  #21161
KIK
KIK's Avatar
Trader Rating: 26 (100%+)
Originally Posted by dtr View Post
12x3mm
Thank you!!! Anyone else having the issue of the front center dogbone pin wearing but not the others? I know it's at a more of an angle than the others but they are not even showing the slightest wear.
KIK is offline
Old 09-29-2011, 03:14 PM
  #21162
photobrat's Avatar
Thanks Casper. So now the silly question, I completely disassembled and cleaned my SCTE, so took out the droop screws to drop the arms in the ultrasonic cleaner. Wasn't sure if full droop was all the way down or all the way up when I put them back in. I went all the way up, so the arms have full travel. Yes, no?
Old 09-29-2011, 03:18 PM
  #21163
dtr
dtr's Avatar
For me it's the front center outdrives that show the most wear; still awaiting the hardened ones. Alreay swapped the front and rear, hope this will last till the package arrives. The pins look OK though.
dtr is offline
Old 09-29-2011, 03:26 PM
  #21164
Trader Rating: 99 (99%+)
I have been noticing people with handling issues after changing to a non stock chassis and adding tuning kit.
My truck after a month of tweaking handles like a dream now, my question is are the gains by adding the tuning kit and changing chassis that noticeable and beneficial.
isarctard is offline
Old 09-29-2011, 03:31 PM
  #21165
losi_racer's Avatar
Trader Rating: 25 (100%+)
Brandon are we talking about FF?
that track has a huge amount of bite especially when wet. Ive tried 7-5-2 ,5-5-2.5-3-2,3-3-2 with aaron set up. 3-3-2 was the best, all the rest didnt allow the truck to rotate at all because of the bite that track has.
currently im running 3-3-2, -1 camber all around, 28 F+R ride height, Black spring up front with 30 wt losi shock oil, orange rear 30 wt oil. full droop front with bottom shock end unscrewed two turns, rear 101.5, and rear shocks are center on arm, also battery foward.
ive done a lot of testing out there latley, this is why my results havent been the best last couple times but this is what ive came up with is best , last time i was out i TQ and won . i wanna play with my shock oils a tad but other then that im happy . your more then welcome to drive my truck any time you want to see if you like it
losi_racer is offline
