Like Tree9Likes
Old 09-16-2011, 02:13 PM
  #20266
SupermaxxRich's Avatar
Originally Posted by SC_RAGE View Post
Any ideas for sway bars. Tight indoor clay track. I had this written down but lost it.
Mine were VERY tight the first time I put them on. After some of the anodizing wore off they were smooth as butter...
SupermaxxRich is offline
Old 09-16-2011, 02:21 PM
  #20267
Im also building a nitro scte. Should be a fun outdoor beater.
SC_RAGE is offline
Old 09-16-2011, 02:55 PM
  #20268
Oh they are lots of fun...I built one for the RC madness race and then it got rained out...love it though.
hacker07 is offline
Old 09-16-2011, 03:23 PM
  #20269
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Saw one run the other day at Revelation Raceway. Looked awesome. Wish nitro SC would take off. Actually I don't cause I don't need yet another car and I don't need to race yet another class
SEF is offline
Old 09-16-2011, 03:28 PM
  #20270
http://www.ebay.com/itm/LOSI-SCTE-CO...item415d3d0dcb
Everything to make a nitro scte....
SC_RAGE is offline
Old 09-16-2011, 03:29 PM
  #20271
Trader Rating: 19 (100%+)
I had some problems with the aluminum shock caps not fitting as well (the old ones). I had a set that fit the shock body but still leaked shock oil as a sieve. Put the plastic caps back on and they stopped leaking.
Edumakated is offline
Old 09-16-2011, 03:31 PM
  #20272
Jenzorace's Avatar
Trader Rating: 17 (100%+)
Cs took care of me. Sending shock bodies.
Jenzorace is offline
Old 09-16-2011, 04:29 PM
  #20273
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
what motor? i got a like new os 18tz laying around that i wounldnt mind messing with
Mr.juarez is offline
Old 09-16-2011, 06:20 PM
  #20274
Gas Rat Racin's Avatar
Anyone have a pic of their SCTE with a flow tec body on it?
Gas Rat Racin is offline
Old 09-16-2011, 06:23 PM
  #20275
rcguy76559's Avatar
Trader Rating: 22 (100%+)
what shims you guys using to take the play out of axle so the wheel don't slide side to side?
rcguy76559 is offline
Old 09-16-2011, 06:25 PM
  #20276
picco007's Avatar
Trader Rating: 98 (100%+)
Yes, I'm also wanting to know if you do have the flow tek body on what mounting holes did you use? I had mine painted before mounting it and now I can't seem to like it up....I know there are dimples but which ones to use is the question.....please help....
picco007 is offline
Old 09-16-2011, 06:34 PM
  #20277
Trader Rating: 46 (98%+)
it's the front hole in the rear and the center hole in the front. i'll post my pics in a min.
nitroal is offline
Old 09-16-2011, 06:36 PM
  #20278
Is there such a thing as a shim kit for this truck that would include shims for everything difs, axles, pinions, and etc.? If not someone should put one together or at least get a list of part numbers needed so a guy can have all the shims on hand he may need.
Old 09-16-2011, 06:37 PM
  #20279
here ya go. a little dirty since i haven't had time to clean it since my last race.
nitroal is offline
Old 09-16-2011, 06:42 PM
  #20280
LAYMAN123's Avatar
Ready to try out the new pro4 and tlr chassis! See if 250 will show up in lap times!
LAYMAN123 is offline
