Like Tree9Likes
Old 09-16-2011, 11:52 AM
  #20251
Jenzorace's Avatar
Trader Rating: 17 (100%+)
Thanks casper!
Jenzorace is offline
Old 09-16-2011, 12:19 PM
  #20252
Moogumby's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Moogumby View Post
Ok i have looked but found no real info. ...
so im tryign to fit my %50 trinity motor but it has that little lip. are people actually dremeling the lip or dremeling the motor mount piece?
if so what bit did you use and where did you dremel?
Originally Posted by SaladFork View Post
Speed Passions V10 and the Fusion 3's have the same issue. I left the lip and mounted them. Just make sure it's even.
Anyone else have a solution? I relly dont wanna try to make sure the motor mount peice is straight.. my eye isnt that good lol
Moogumby is offline
Old 09-16-2011, 12:36 PM
  #20253
I'm pretty sure someone earlier on just took a little material off of the motor mount so the motor would fit properly.
mavrick0 is offline
Old 09-16-2011, 12:46 PM
  #20254
Jenzorace's Avatar
Default Tuning kit
OK Now im pissed.. The tuning kit shock caps wont fit the shock bodies... Do i have to buy special shock bodies for these caps??? What the hell did i wait so long for this kit for?????? The measurement inside the threads is .590 on the new ones the old ones measure .605..... BULLSHIT!!!!!!
Old 09-16-2011, 12:51 PM
  #20255
RC*PHREAK's Avatar
Trader Rating: 141 (100%+)
RC*PHREAK is offline
Old 09-16-2011, 12:53 PM
  #20256
Casper's Avatar
Trader Rating: 34 (100%+)
Those caps should thread right on. No different bodies required for them. Stupid question but all 4 of them don't fit and you are using stock Losi shock bodies? Contact HH CS and they should be able to help you out.
Casper is offline
Old 09-16-2011, 01:07 PM
  #20257
Jenzorace's Avatar
Right! None of them fit.. Horizon hobbies customer service right?
Old 09-16-2011, 01:13 PM
  #20258
Any ideas for sway bars. Tight indoor clay track. I had this written down but lost it.
SC_RAGE is offline
Old 09-16-2011, 01:15 PM
  #20259
Casper's Avatar
That is quite odd. Yeah horizon hobby Customer service.
follow what they guys run on these setup sheets.
http://www.losi.com/Products/Support...rodID=LOSB0127
Casper is offline
Old 09-16-2011, 01:21 PM
  #20260
BmainStar's Avatar
Originally Posted by SoCal Jared View Post
Wow, great night tonight practicing with the SCTE at WCRC.
Tuning kit was dialed and new springs helped alot.
Good to hear Jared!!!Your sig cracks me up,I tell people all the time (sometimes yell)LOL STRIAT or CALL THE STRIAT . It`s funny cuz if there new they look at you like yer crazy! And some people are jus introvert R/C Nerds with no social skillz that wouldn't yell at a FLY!!Anyway just built my TLR chassis headed to the track tonight to dial her in
BmainStar is offline
Old 09-16-2011, 01:26 PM
  #20261
Jenzorace's Avatar
After further inspection all 4 caps fit one of my shocks. So its the 3 shock bodies that must be oversize..
Old 09-16-2011, 01:39 PM
  #20262
SCUBA STEVE's Avatar
Trader Rating: 89 (99%+)
If that was the case you'd have different bladders, o-rings, pistons ect that would not fit correctly niether .... There must be a bur in the threads or something goofy like that going on... there are no two sets of losi shocks that close together in size but yet for different models to get'm mixed up.....
SCUBA STEVE is offline
Old 09-16-2011, 01:59 PM
  #20263
Originally Posted by Asharus View Post
Ryan, I know that we've had conversations regarding this already, but I'm still having trouble picturing in my mind what you mean by the shaft binding. I know that it has an awkward angle coming from the pinion shaft to the center diff, but do you mean it binds when it's pushed all the way into the pinion? In my mind, the driveshaft/cv joint will be more straight the further away it's from the center outdrive. Sorry, this would probably be more clear to me if I had the truck in front of me.
If you take the front drive shaft in your hand and put angle in it and it rotates freely, thats a great start. What happens is that when you place it onto the pinion output shaft, you can actually put it on so far that the shaft hits the cv joint ever so slightly. This casues binding and the hole oblonging and the pin going through the plastic.
Something must be going on here...I havent seen this yet although stranger things have happened. CS will take care of you regardless. Please allow them to help.
hacker07 is offline
Old 09-16-2011, 02:03 PM
  #20264
Asharus's Avatar
Trader Rating: 42 (100%+)
Ok now I understand, the pinion shaft is what's hitting the CV joint on the inside, thanks.
Also, regarding the shock caps. I think it's just user error. I know it was pretty difficult for me to thread that on at first as well. Just use some elbow grease and back it off if it's not straight, it has to be perfectly aligned when you're initially threading it in. Good luck!
Asharus is offline
Old 09-16-2011, 02:09 PM
  #20265
Thankyou casper. will do. Got this thing 90% back together. Cant wait to run it again. Been awhile.
SC_RAGE is offline
