Like Tree9Likes
Old 09-15-2011, 04:21 AM
  #20131
Trader Rating: 71 (100%+)
Default sc10 4x4 wheels compatible with scte?
Looking into picking a SCTE, but I have a lot of new mounted tires for my sc10 4x4 - anyone know for sure if they are 100% compatible (offset?).
negatv1 is offline
Old 09-15-2011, 04:49 AM
  #20132
bigjerry's Avatar
Trader Rating: 54 (98%+)
How many people are venting the wheels or venting the tires
bigjerry is offline
Old 09-15-2011, 04:51 AM
  #20133
bigjerry's Avatar
0 offset
bigjerry is offline
Old 09-15-2011, 05:03 AM
  #20134
alvinsmith75's Avatar
Trader Rating: 38 (100%+)
Venting tires only here.
alvinsmith75 is offline
Old 09-15-2011, 05:12 AM
  #20135
lowroad's Avatar
Trader Rating: 79 (100%+)
stock rims are vented.
lowroad is offline
Old 09-15-2011, 05:14 AM
  #20136
slash24's Avatar
what are the advantages of venting tires?
slash24 is offline
Old 09-15-2011, 05:25 AM
  #20137
bigjerry's Avatar
If you wash your wheels and tires they get water in venting the rim wont sling out water. doing the tires it will sling out water
bigjerry is offline
Old 09-15-2011, 05:34 AM
  #20138
dtr
dtr's Avatar
Originally Posted by hacker07
ring and pinions in all cars should always be shimmed after breaking them in, breaking the case in, all of that. Then, they will last for a very long time.
Ryan, what shims do you recommend for this purpose? I see there's a kit for the 8ight, but i bet they're different size.
dtr is offline
Old 09-15-2011, 05:37 AM
  #20139
dtr
dtr's Avatar
If you wash your wheels and tires they get water in venting the rim wont sling out water. doing the tires it will sling out water plus it help on bouch
It's the same with dirt, without holes in the tires the dirt that got in can't get out and cause heavy bouncing in the end.
dtr is offline
Old 09-15-2011, 05:51 AM
  #20140
bigjerry's Avatar
DITTO
bigjerry is offline
Old 09-15-2011, 06:03 AM
  #20141
Asharus's Avatar
Trader Rating: 42 (100%+)
I'd like to know as well.
Asharus is offline
Old 09-15-2011, 06:04 AM
  #20142
Asharus's Avatar
if you wash tires religiously like I do, vent the tires. two holes with a leather punch should suffice.
Asharus is offline
Old 09-15-2011, 06:14 AM
  #20143
slash24's Avatar
oh ok well that makes since. what about if you had no vent at all? so water and dirt cant get in to start with?
slash24 is offline
Old 09-15-2011, 06:19 AM
  #20144
Chassis droop screws
Keep an eye on your chassis where your droop screws hit the stops. The small screws will chew down the chassis over time and cause premature wear. You can prevent this by installing 4-40 x 4mm Droop Screws (part#LOSA6253) I highly recommend you use a tap set on the screws. If you screw up the holes it's impossible to fix. USE THE TAP!!! http://www.horizonhobby.com/Products...rodID=LOSA6253
This is on the front page of this thread first post. When doing this mod are we talking about making new holes for the droop screws? My stock locations are already oversized and the 4-40 droop screws I bought wont fit. Am I missing something here?
mdavis1432 is offline
  #20145
lowroad's Avatar
these are really just basic RC questions, and not to be a dick, but don't really belong in the SCTE thread. But you want some sort of tire venting to prevent ballooning, aid in traction, etc..
lowroad is offline
