Like Tree9Likes
Old 09-14-2011, 07:27 PM
  #20116
Do I need to fill it up as much as it came from stock or can I go a bit less? Thanks for the reply btw.
mdavis1432 is offline
Old 09-14-2011, 07:29 PM
  #20117
Asharus's Avatar
Trader Rating: 42 (100%+)
I don't think it needs to be packed with grease at all, just enough to lube the ring/pinion.
Asharus is offline
Old 09-14-2011, 07:31 PM
  #20118
This is what I thought orignally. My 1/8th scale Mugens I just lube the ring and pinion and throw it out there. Thanks guys. Going to get greasy now!!
Old 09-14-2011, 08:02 PM
  #20119
10sctrel0v3r's Avatar
Originally Posted by nitrobandit
Does anyone have any feedback on the OFNA diff gears that has been running them for a while now. My original losi gears are toast and I have a set of OFNA gears gears here waiting to go in. Wondering if I should swap to the OFNA's or wait on getting a set of the new Losi replacements. I want the best setup that will last without rebuilding for a while.
Thanks!
my ofna gears have been holding up great, just make sure you have your mesh set right and your good to go
10sctrel0v3r is offline
Old 09-14-2011, 08:20 PM
  #20120
Suspended
Trader Rating: 4 (64%+)
hey guys what do yours thin of the new scte rtr comming up next to buy would it be any good with the brushless combo in it i am think of buying it or buy a sc 4x4 is a 2800kv fast at all
zenbonzakura is offline
Old 09-14-2011, 08:25 PM
  #20121
Briguy's Avatar
Trader Rating: 125 (100%+)
I`ve never been a fan of RTR electronics . If your new or don`t plan to race then might be the way to go . If you plan to race , but the roller and put electronics you want in it .
Briguy is offline
Old 09-14-2011, 08:35 PM
  #20122
Trader Rating: 50 (98%+)
Some use Mobil 1 synthetic oil in there, but I just used what I had handy (Losi Smart Diff Grease). I'm sure any type of grease would do, such as AE Black Grease, etc.
I used to run greese on my ring and pinion gears. However over the past year and a half i started to run them dry. I have not seen any accelerated wear this way. But i also pull my cars down for maintance quite often.
micrors4guy is offline
Old 09-14-2011, 08:49 PM
  #20123
Pvd brett's Avatar
the stock electronics look a lot like the castle creations 4pole system. It even says its a 4pole motor. Same design.... same type of motor. Sounds like a 4pole castle with the stickers ripped off. A lot of people have run the castle system with good luck and good temps. Completely up to you on this one. The rtr comes with everything the roller has + electronics so if your on a tight budget that would probably be suitable for you as far as electronics. Everybody already knows the truck is awsome enough to have its own religion so no worries there
Pvd brett is offline
Old 09-14-2011, 09:01 PM
  #20124
KingdomRacer's Avatar
I have found this to be the same here too. I don't do a lot of things no more like when I was a newb.
KingdomRacer is offline
Old 09-14-2011, 09:51 PM
  #20125
losi_racer's Avatar
Trader Rating: 25 (100%+)
rebuilt my scte tonight with the tlr chassis, new bearings,diff,shock etc. The chassis looks awesome, my servo didnt come in tonight so its not 100% complete but i cant wait till sat to race it
losi_racer is offline
Old 09-14-2011, 10:21 PM
  #20126
skengines's Avatar
Trader Rating: 226 (100%+)
What do you guys think of this ring/pinion gear? Probably about 60 packs on it before it started clicking on me. I tried shimming the ring/pinion which helped but there was some bind so I ended up putting in a new ring/pinion and it's smooth now.
I did add two shim before rebuilding the rear diff so I hope it will last a while.
Attached Thumbnails Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-dscf6149.jpg   Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-dscf6150.jpg   Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-dscf6151.jpg
skengines is offline
Old 09-14-2011, 10:37 PM
  #20127
Trader Rating: 16 (100%+)
those are SHOT!!
SupermaxxRich is offline
Old 09-14-2011, 10:53 PM
  #20128
Trader Rating: 76 (100%+)
I pulled these out of my rear diff today. I have never had ring pinion gear ever go bad on me ever so this was a surprise. i have new one of right to compare
Chase1472 is offline
Old 09-14-2011, 11:00 PM
  #20129
That one definately wasnt ever re shimmed after running the car some...ring and pinions in all cars should always be shimmed after breaking them in, breaking the case in, all of that. Then, they will last for a very long time.
hacker07 is offline
Old 09-14-2011, 11:23 PM
  #20130
skengines's Avatar
Neither have I...
Hopefully with the new shims in place they will last a long time.
