Like Tree9Likes
Old 09-14-2011, 04:59 PM
  #20086
Lucid's Avatar
Originally Posted by jwemail
oic, i thought ht's was what he was talking about. opps. my local track still uses ht's, its like the twilight zone sometimes in good'ol wis. lol
we still run them too, good thing because I have a voltage cap on my rec
Lucid is offline
Old 09-14-2011, 05:09 PM
  #20087
Trader Rating: 50 (98%+)
Originally Posted by Integra
I Disagree
Ace/XP's have been known to pull upwards of 10+ amps under load, and for what its worth, they have Significantly more Tq then 200 Oz and again are significantly faster then .10
I have been running ace servos for over 2 years with no issues at all. No brown outs or glitches. its stupid fast holds a line and flat out works.
micrors4guy is offline
Old 09-14-2011, 05:36 PM
  #20088
Integra's Avatar
My gear set's/Top cases Flat out Failed Every time.
and yes I have more then one.
Ill stand by my statement and say that Ace/XP or AE uses Sub par Brass gear's that just aren't up to the task, Not to mention the plastic bushing for the top case.(pretty sure that has been addressed) But did nothing for me when i couldn't finish a race due to Constantly Stripping out gear's or top cases. HITEC FTW !!!
That's my opinion and im stickin to it.
Integra is offline
Old 09-14-2011, 05:47 PM
  #20089
Asharus's Avatar
Trader Rating: 42 (100%+)
Originally Posted by lowroad
glitching...twitching...cutting out...acting weird..cussing at imaginary bats like a crazed homeless person on the corner. Something many experience with the savox unless using an external bec or a capacitor plugged into the receiver. Some don't have any issue, some do. I did. Tried the caps, still had a slight issue. Got a different servo (ACE/XP 1313), no issues. Just my .02
a buddy was having an issue with his savox 1258 in his tekin rs / spektrum rx equipped losi xxx-sct. i gave him my novak glitchbuster and it helped but did not eliminate the problem. then i told him to check the endpoints on his steering, which resolved it. it was probably going beyond the point where the steering rack locks and causing the servo to pull too much power from the BEC. i bet if he takes out his novak cap it will still be flawless
Asharus is offline
Old 09-14-2011, 05:52 PM
  #20090
Briguy's Avatar
Trader Rating: 125 (100%+)
Nope , even with endpoints set correctly he will still need a cap with the RS .
Briguy is offline
Old 09-14-2011, 05:58 PM
  #20091
Cult Racing's Avatar
Ya ya ya, I no another BCE chassis lol, I just came back from the durango to the losi about 3 weeks ago to give the dingo a try but still felt like the losi is a better truck and just won 2 races in a row last friday and sat night, and decided to get the BCE chassis again after how good it was last time and got it today.
Ya I know that people have built pics but im going to do it again for the people that are new and to just let people know what to do.
On the center diff/motor mount part (closes to the rear) you will need to use shorter screws because the stock ones are too long.
Like this (same ones as the four in the front and four in the rear
Everything else works perfect just need to trim the mud-guards a bit
On the front if you have the aluminum hinge pin holders its kinda hard to get them on so you will need to screw them all around just a bit and then go do all the screws and tighten them up all the way to get snug.
Same thing for the rear as the front.
DONE! Cant wait to hit the track on friday and see how much I like it lol.
Cult Racing is offline
Old 09-14-2011, 05:59 PM
  #20092
Asharus's Avatar
Fact? I was going to pick up a Ballistic 17.5, Tekin RS, Savox 1257 for my TC6, but with an Airtronics 92744 Rx. Bad idea? I don't need a cap on my Airtronics/Novak/1258, 1257 2wd setups. Does the RS have a weaker BEC?
Asharus is offline
Old 09-14-2011, 06:05 PM
  #20093
Briguy's Avatar
Yes , it is a fact . Not a weaker BEC , Savox servos draw a ton of power .
Briguy is offline
Old 09-14-2011, 06:06 PM
  #20094
I run a savox 1283 and no problems with rx8 and radiopost receiver.
Old 09-14-2011, 06:08 PM
  #20095
Briguy's Avatar
RX8 has a stronger BEC than the RS/RS Pro .
Briguy is offline
  #20096
Did not see that sorry lol
Old 09-14-2011, 06:12 PM
  #20097
Asharus's Avatar
Strange, I thought Tekin RS > Novak Havocs.
Asharus is offline
Old 09-14-2011, 06:24 PM
  #20098
The Juice's Avatar
Trader Rating: 25 (100%+)
I run a 1258 with the 92744 and novak and dont need a cap.
The Juice is offline
Old 09-14-2011, 06:27 PM
  #20099
slash24's Avatar
haha well that was a great mental picture. i can just see my truck going crazy like that
slash24 is offline
Old 09-14-2011, 06:29 PM
  #20100
Briguy's Avatar
We have customers that run Novak ESCs and need a cap .
Briguy is offline
