Like Tree9Likes
Old 09-14-2011, 01:45 PM
  #20071
so is the this new set screw for the CV driveshaft thing out yet.. thats #5 already.. pin keeps flying out of the sleeve...
bustanut666 is offline
Old 09-14-2011, 01:50 PM
  #20072
stevepowling's Avatar
Originally Posted by Brushless420
I think the Spektrum s6040 is a great servo. However its a power hog and has issues if your not running a separate BEC or a Cap.
Yup, that's what I had to do. Using a Spektrum cap, seemed to solve my glitching issues with the servo and under hard braking. Although, the receiver I'm using only has one aux port...
Going racing this weekend for the first time in a few years and will be renting a PT...do the PT's work in a servo port or does it have to plug into the aux port? (Sorry, never used a PT before.)
And sorry this is way off topic, hahaha
stevepowling is offline
Old 09-14-2011, 01:52 PM
  #20073
Trader Rating: 21 (100%+)
same thing happened to my buddys truck saturday the pin came out of the front cv where it attaches to the input shaft of the front gearbox. is this an issue with all of the versions of the truck ive got two third release trucks and is this something i need to worry about?
250r is offline
Old 09-14-2011, 01:58 PM
  #20074
jwemail's Avatar
i think they go in a hole in your body like a hole the size of a bodymount hole, and its held in with a body mount clip. no need to plug into your receiver, they are rechargable.
jwemail is offline
  #20075
slash24's Avatar
Originally Posted by lowroad
yes, but the ace has more torque and no glitching. someone has a new one for sale in the section cheap too.
what exactly do you mean by glitching?
slash24 is offline
Old 09-14-2011, 02:01 PM
  #20076
Asharus's Avatar
Trader Rating: 42 (100%+)
You can plug it into any port on your receiver.
Asharus is offline
Old 09-14-2011, 02:24 PM
  #20077
Bondonutz's Avatar
Trader Rating: 48 (100%+)
Remember when you were younger and ever rode a bicycle with kink or a bad spot in the chain ?
Thats a "glitch" but in RC it's electrical depending on the source. The need for the cap in this application is the servo draws a bit of juice and it interups the internal BEC of the ESC and causes problems for the receiver and the Cap levels out the voltage so it doesn't hiccup/glitch.
Bondonutz is offline
Old 09-14-2011, 02:25 PM
  #20078
lowroad's Avatar
Trader Rating: 79 (100%+)
glitching...twitching...cutting out...acting weird..cussing at imaginary bats like a crazed homeless person on the corner. Something many experience with the savox unless using an external bec or a capacitor plugged into the receiver. Some don't have any issue, some do. I did. Tried the caps, still had a slight issue. Got a different servo (ACE/XP 1313), no issues. Just my .02
lowroad is offline
Old 09-14-2011, 02:27 PM
  #20079
lowroad's Avatar
That's house transponders like they loan at the track if you don't own one. Normal transponders plug right into the receiver.
lowroad is offline
Old 09-14-2011, 02:44 PM
  #20080
Briguy's Avatar
Trader Rating: 125 (100%+)
Being house transponders are no longer being made , tracks are buying and loaning out personal transponders .
HTs don`t have a wire to plug in as PTs do .
Briguy is offline
Old 09-14-2011, 02:56 PM
  #20081
Thanks again for the help guys!
Old 09-14-2011, 03:23 PM
  #20082
SaladFork's Avatar
I got my 65-130C 6000mah Nanotechs today. All three came perfectly balanced and in storage mode. I charged one up and ran one down in the SCTe, flawless. These are my 2nd batch from them, no issues with any of them in the Losi.
SaladFork is offline
Old 09-14-2011, 04:16 PM
  #20083
jwemail's Avatar
oic, i thought ht's was what he was talking about. opps. my local track still uses ht's, its like the twilight zone sometimes in good'ol wis. lol
jwemail is offline
Old 09-14-2011, 04:26 PM
  #20084
Trader Rating: 50 (98%+)
you going to scr sunday with mike?
micrors4guy is offline
Old 09-14-2011, 04:48 PM
  #20085
Integra's Avatar
XP1015 , good servo
I Disagree
I think the Spektrum s6040 is a great servo. However its a power hog and has issues if your not running a separate BEC or a Cap. I did a little reasearch and found a servo that I believe is the best of both worlds. Great specs and low amp draw. It the ACE DS1015. It has 201 oz of torque at 6v and a transit speed of .10 at 6v. No glitching issues and no bec required to run it. This is the same servo as the Associated XP series 1015. Just rebranded.
Ace/XP's have been known to pull upwards of 10+ amps under load, and for what its worth, they have Significantly more Tq then 200 Oz and again are significantly faster then .10
Integra is offline
