Like Tree9Likes
Old 09-04-2011, 03:29 PM
  #19246
Originally Posted by Lucid View Post
had a pretty good weekend of racing, I qualified 2nd and ended up taking 3rd in the main because my battery hit cut off 30 feet before the lap counter
oh well, at least I knew I was there.
Also I knew these trucks were heavy, but I puffed my protek 65c battery in that same main???
maybe the protek's are a little weak or something.
has anyone else puffed a 60-65c pack?
Hitting cut off is absolutely the worst thing you can do to a lipo pack. I would turn your lipo cutoff up and it should help out with that.
hacker07 is offline
Old 09-04-2011, 03:31 PM
  #19247
Trader Rating: 19 (100%+)
Originally Posted by Casper View Post
Outside most hole on the tower and outer most hole on the arm. There is an error on the setup sheet for numbering so it can get confusion giving the number on the tower.
Ryan mentioned using the middle hole on bottom of shock up front??
nitro0619 is offline
Old 09-04-2011, 03:34 PM
  #19248
Lucid's Avatar
hmmm so that could have been why my battery puffed?
theres 2 other Losi's at my track, one with a 60c and one with a 25c pack an neither of them have puffed.
I'll probably order an excelorin 60c 6000 pack for the mains
Lucid is offline
Old 09-04-2011, 03:44 PM
  #19249
DBL15's Avatar
Originally Posted by Super Coupe View Post
Good race last Thursday with a couple losi's battling for the lead. The kid in the white and black truck has only been racing for 9 months.
http://www.youtube.com/watch?v=X26FbgtQBgA
great video thanks for sharing it , i wish our races the back markers were that good that was awesome thanks for the video
most of our racers the back markers make or break your race
DBL15 is offline
Old 09-04-2011, 04:22 PM
  #19250
Also, the one who got second and was on his but half the race is Mike Dumas. Sponsored by Tekin. He also used to race on road. That was his 2nd race night with his Losi 4wd. Running it absolutely bone stock what I hear. Haven't changed his oils or anything.
twigman08 is offline
Old 09-04-2011, 04:39 PM
  #19251
larlev's Avatar
The SCTE is a heavy truck but as has been discussed a lot on here the weight is not really a bad thing and helps the truck race in many ways. My point is don't be obsessed with saving weight. Make your hop up decisions based on performance or tuning additions and don't worry too much about the weight.
agreed x 1000000, All of ours are stock and my motor temps out at 145 after main. How much cooler does it need to be? Being heavier has more advantages than not...more planted, carry more speed, stability..etc. Can't tell you how many times I get bumped from behind only to send the offender in the pipe while I move along.
Buy stuff for performance not weight. Guys I run with are all stock weight and can turn 16 sec laps right out of the box. You don't need a light truck to be fast. You do need one that will finish the race.
larlev is offline
Old 09-04-2011, 04:41 PM
  #19252
larlev's Avatar
Originally Posted by mxr300ex View Post
I just ran my SCTE with the emulsion set-up shocks just like in the Tim Bump video and man was it planted. I thought it was planted in stock form but this took it to another level. No bounce at all, even over jumping and flat landing it just sticks to the track and takes off. I really noticed the advantage on the rough parts of the track, just sucks up all the bumps like they're not even there.
Feels the same if you run bladders and build with little to no rebound..that's what I have found anyway.
larlev is offline
Old 09-04-2011, 04:48 PM
  #19253
Are you saying compress the shock all the way fill with oil and install the cap with the shock compressed?
mxr300ex is offline
Old 09-04-2011, 04:52 PM
  #19254
suby723's Avatar
Trader Rating: 21 (100%+)
Fill with oil,bleed the shock then compress the shaft all the way and thread the shock cap on. That will allow zero rebound.
suby723 is offline
Old 09-04-2011, 04:56 PM
  #19255
mxr300ex is offline
Old 09-04-2011, 05:06 PM
  #19256
DBL15's Avatar
yeh been running mine now for atleast 4 to 5 months still bone stock and have not finished worse then 3rd place and had more wins then i ever got with my old hyper lol
oh yeh still stock grease in the gears only change i have made is gold and silver springs thats it lol
DBL15 is offline
Old 09-04-2011, 05:10 PM
  #19257
larlev's Avatar
HaHa...sorry, yep that's exactly right. Try it and compare to emulsion. It's always fun to tinker...
larlev is offline
Old 09-04-2011, 05:21 PM
  #19258
stevepowling's Avatar
Be careful with those packs, I picked one up yesterday from my LHS and it puffed on the FIRST CHARGE I put through it. Everything was set up on the charger correctly and it puffed half way through the first charge. It definitely wasn't fun considering how much they cost.
stevepowling is offline
Old 09-04-2011, 05:23 PM
  #19259
larlev's Avatar
I can highly recommend the Team Orion carbon 90c 6500mah for mains. Great lipo
larlev is offline
Old 09-04-2011, 05:32 PM
  #19260
Trader Rating: 52 (100%+)
Check out Speedzone usa. He has got some great lipos for the money. I have been running them for over a year with no problems.
tonyd is offline
