Like Tree9Likes
Old 09-02-2011, 01:39 PM
  #19036
Trader Rating: 1 (67%+)
unfortunately i had to get the regular tekin 550 5.5 instead of the pro4 4000kv
what gearing should i use for it?
i really just need a starting point
EDIT: i see 14-17 what is the best to start with?
stang is offline
Old 09-02-2011, 01:40 PM
  #19037
Casper's Avatar
Trader Rating: 34 (100%+)
What speedo?
15-16 range for RX8. Might go a little higher for an ESC that does not have any timing advance.
Casper is offline
Old 09-02-2011, 01:43 PM
  #19038
Originally Posted by Casper View Post
What speedo?
for now it will be the mmp. soon i plan on going with the rx8 though.
stang is offline
Old 09-02-2011, 01:51 PM
  #19039
Casper's Avatar
You should be pretty safe in the 15-16 range. No need to run a lot of boost or anything. Motor shoudl run pretty strong without them.
Casper is offline
Old 09-02-2011, 02:02 PM
  #19040
Brushless420's Avatar
Trader Rating: 176 (100%+)
Originally Posted by hacker07 View Post
If you are in an area with lots of mositure, you can keep the box or you can do what he did and just shoe goo around the connectors of your receiver.
Shoo goo is pretty messy. IMHO a balloon works nicely.
Brushless420 is offline
Old 09-02-2011, 02:04 PM
  #19041
Originally Posted by jwemail View Post
i just got my new bce chassis, (oh yeaaa) i have the rc8 rear brace, (i thought it made my scte push on power in corners to much), i have the front and rear losi aluminum braces, (the rear alum brace was to stiff in the stock chassis and bent the chassis due to not enough flex, and piss poor driving skills). and i have the stock plastic braces. with the bce chassis being stiffer, which braces would racers go with, i race on a small indoor high bit track. thanks
I would use the front aluminum brace and the longer rear plastic brace. That seems to be a great combo with the BCE chassis.
Old 09-02-2011, 02:09 PM
  #19042
per4m28's Avatar
Trader Rating: 58 (100%+)
so how are these pro 4's running on the scte's?? thinking about the 4000kv...do maintain the 15-16 gearing? are the temps comparable to the CC 3800kv?
per4m28 is offline
Old 09-02-2011, 02:10 PM
  #19043
Casper's Avatar
I have the 4600 in mine. Runs really strong. Hightly recommend these little motors. I have not tried a 4000 yet but 15-16 should be a good starting point based on my 13 gearing with the 4600
Casper is offline
Old 09-02-2011, 02:21 PM
  #19044
Default Chassis woes
Anyone who has yet to make a decision on which chassis to purchase as an alternate to the lousy stock piece should consider the BCE as a top choice. I still see people here crying after purchasing the SNR carbon fiber chassis which IMHO is not the best option. I do have several SNR carbon pieces on my build but think the chassis for this application is just not the way to go. No disrespect to Steve at SNR in any way. For the rigors of racing, wear characteristics, holding a tune, and just about anything else you could think of the BCE will come out on top. The only advantage to the SNR chassis is being lighter. However only to a slight degree and personally I think it moves the CG up higher in the truck to a fault. The weight reduction of the BCE is more than adequate. I mean the SCTE was designed to be a heavier option than all the others in the SC class in the first place for a reason. Going for an all out light weight SCTE just doesnt make sense for the majority of applications. Anyway without rambling any further.
BUY THE BCE CHASSIS FTW
Old 09-02-2011, 02:28 PM
  #19045
SCUBA STEVE's Avatar
Trader Rating: 89 (99%+)
Any one know why there is only one breather hole in the stock scte wheels?
And is everyone running'm this way?
SCUBA STEVE is offline
Old 09-02-2011, 02:35 PM
  #19046
You have now posted this a couple times...we get how you feel. There are a lot of good choices out there. I will stick with my TLR tested and tried and tuned NATIONAL CHAMPION winning chassis myself.
hacker07 is offline
Old 09-02-2011, 02:47 PM
  #19047
Reeeeally wanna get these tires mounted but would like some thoughts/opinions 1st......
Old 09-02-2011, 02:57 PM
  #19048
Casper's Avatar
The hole is just a vent. you can always poke another hole in the other side but probably not needed. If you run closed cell foams it is a good idea to vent the tire as well.
Casper is offline
Old 09-02-2011, 03:02 PM
  #19049
Default Diff Question
I'm a new guy so sorry if this is a real basic question. I Just started racing with my Son at the local track with our SCTE's, and was wondering when you all talk about changing out diff fluid and say 5-3-3 or whatever...what is the format Rear-Center-Front, Center-Front-Rear?...I'm clueless....thanks!
N2HighVoltage is offline
Old 09-02-2011, 03:07 PM
  #19050
wcrase101's Avatar
Front/center/rear
wcrase101 is offline
