Like Tree9Likes
Old 09-01-2011, 04:42 PM
  #18961
Ridley's Avatar
Originally Posted by suby723 View Post
I answered that question on the previous page.. There is no difference in the weight of oil between emulsion and bladder.
The air bubbles in the oil typically make it about 5wt lighter when running emulsion.
I still think the whole thing is bunk personally
Ridley is offline
Old 09-01-2011, 05:23 PM
  #18962
wcrase101's Avatar
my sc10 don't use bladders on it, I do like the way it behaves, just not sure if it's the way to go on a heavier truck. but I sorta got to think if the pros are all about it, it's got to be worth a try. I will probaly try it without the hole in the caps and go from there. might have to try it before the next series race, I'm up on second by four points and this will be the last race of the series. got to pull something outta my ###, as I'm making a habit of finishing in second.
would this shock setup be good on a bumpy track??
wcrase101 is offline
Old 09-01-2011, 06:00 PM
  #18963
Ok I have a question. I just got done practicing with my new Pro4 4000kv and after around 7 min I came in and checked temps. They were at 176. I have the RX8 setup with 10deg timing, 65 on the limiter, and 10% drag break. I am running throttle profile 3, motor type 1, and standard RPM settings for timing advance. I have it geared at 13/40 with a 65ft strait. I have a race tomorrow night, and I would like to see if I can get the temps down a little. Any advice?
racert28 is offline
Old 09-01-2011, 06:02 PM
  #18964
SaladFork's Avatar
Think of it this way... If you don't win you can blame it on the shocks!! I remain neutral on the bladder vs. emulsion but leave it up to personal preference. What works for some, might not work for others.
SaladFork is offline
  #18965
Kylesfv's Avatar
im installking my bce chassis right now and for the diff mount screws how much am i supposed to grind off cause i do not need a diff spacer mount thing.
thanks
Kylesfv is offline
Old 09-01-2011, 06:17 PM
  #18966
BmainStar's Avatar
Yes ,remove the timing and the drag brake!!!!
BmainStar is offline
Old 09-01-2011, 06:18 PM
  #18967
wcrase101's Avatar
lmao, at least then I'd have an excuse
I guess I'll give it a try before hand and see how it does.
I guess I can't complain really, leading points is about as cool as winning a race, even if you never won a race in the series your leading in.
Old 09-01-2011, 06:20 PM
  #18968
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
is this nano turnigy battery any good for the scte as it is 2s2p?...
http://www.ebay.com/itm/300582939735...84.m1438.l2649
BDRMBULLY is offline
Old 09-01-2011, 06:23 PM
  #18969
wcrase101's Avatar
maybe go up a tooth, should be similar to the castle 3800, I only ran a 13 tooth pinion on a really small track. I also agree with bmain.
  #18970
BmainStar's Avatar
Man, I use what the pros use..and still cant drive like one LOL
Old 09-01-2011, 06:24 PM
  #18971
Ridley's Avatar
Yeah, thats a great battery, but that price sucks
I bought 4 for 199$ shipped 3 day UPS. I get emails all the time about them coming in stock, if you backorder them it shouldn't take long to get them straight from hobbyking.com
Ridley is offline
Old 09-01-2011, 06:27 PM
  #18972
wcrase101's Avatar
I've tried to use pro set-ups and never really had good luck with that, I usally stay pretty close to stock and change whatever the truck tells me it needs.
  #18973
Thanks guys I will give this a try, and see how it goes.
racert28 is offline
Old 09-01-2011, 06:34 PM
  #18974
BmainStar's Avatar
I am a decent club racer ,but not a tuner by no means.If I ever get good enough at racing, then I can see using the pros set ups.I too have my own set ups very close to box stock.Guys that can run multiple laps within a second of each other..Dang ....(Not Meee) Do benefit from subtle changes .
Old 09-01-2011, 06:45 PM
  #18975
Trader Rating: 86 (99%+)
I'm going to stab myself in the throat with an emulsion shock if I read for the millionth time "where should I drill the hole in the shock cap"
WideOpenThrottle RC is offline
