My truck handled well out of the box, but it's time to make it better. I pulled it down to the bare chassis last night to freshen up the diffs and check everything out. The front diff case was very full of a clear-ish grease but the rear diff only had a little. Is this grease that has leaked out of the diff or did they over-lubricate the front ring gear from the factory?
I had to scrub them with an old toothbrush
Dish soap will only work on petroleum based oils/grease , the silicone based oil/grease that we use needs some kind of solvent to break it down .
The problem with solvents is most give off harmful fumes so you have to clean the parts in a well ventilated area .
Which aluminium servo horn is everyone using? I ordered this one last night since I was already making an order. Did I make a mistake? Are the clamp style ones superior?
http://www.canyonhobbies.com/CH_Gold...p/ghh01089.htm
I'm not worried about the tooth count, from what I can see the JR horn will work on my Spektrum 6040.
Star
Star
Star
Star
With a 20/40 gear it should be fast enough on 2s to race with. Not optimal, but fast enough. But, as a majority of the buyers are bashers and not racers, it should be hella fast on 3s and 4s. If it really is a reworked/rebadged castle 1415...it should be pretty solid, and in a very versatile KV.
I use the JR horns , mainly because the LHS I go too sells it the cheapest out of the horns they stock , that horn you got looks ok but if it has a plastic insert in it its gonna wear/strip over time . JR makes the servos for Spektrum so yes the JR horns will fit the Spektrum servos .
hey guys got the aluminum pivot supports and went to put them on late last night.
question i have is which fitting do i put in to match stock settings.
is the frt 0-0
rear is ?
is the frt 0-0
rear is ?
After the first race with the SCTE I took the diffs apart to see how the internals held (a bit disappointed since after 6 10min heats even the replacement pins were worn 1-2 tenths of a mm and on of the sun gears had chipped a tooth, as if it had a mold problem; the pins were from the EU distributor and visibly different from the original , I hope horizon EU will take care of these issues as well as Ryan&co does in US) My problem is that to get the front diff out I had to take out 14 screws and it feels a bit too many.
What is the best method to reach the diff more easily?
