Like Tree9Likes
Old 08-23-2011, 06:20 PM
  #18241
Originally Posted by Feint Motion View Post
Just ran my HW sc8 + Tenshock 4000kv sc401 combo, in 100 degree weather.
Motor only came out at 155-159 degrees/ ESC came out at 125 degrees. Messing around in the street, full throttling straights geared at 15t, no timing. 5000mah 40c packs.
Very happy with this set up.
Did you have any problems with it stuttering from a stand still when you gunned it? I had that exact esc and motor in mine but I had to take out the tenshock and put the 1410 back in because of the stuttering on take off.
mxr300ex is offline
Old 08-23-2011, 06:29 PM
  #18242
Anyone got pics of the shock caps with bleeder holes? I want to drill my own holes. Not sure exactly where they go.
bustanut666 is offline
Old 08-23-2011, 06:40 PM
  #18243
Feint Motion's Avatar
Trader Rating: 24 (96%+)
no problems with shuttering at stand still. I turned my timing to zero to make sure that wont happen. Also turned down the punch at start down to level 4. Still bursty even at lvl 4.
Feint Motion is offline
Old 08-23-2011, 06:54 PM
  #18244
Thanks, I'll have to try that.
mxr300ex is offline
Old 08-23-2011, 07:04 PM
  #18245
KingdomRacer's Avatar
So is the motor in the new RTR for 3s 'cuz I just don't see it on 2s being able to compete on the track.
KingdomRacer is offline
Old 08-23-2011, 07:06 PM
  #18246
Originally Posted by bustanut666 View Post
i have a castle blower too... that broke within 3 days... least the integy lasted a month...
my castle blower NEVER worked. Been using a turnigy fan heat sink combo. Its been solid for over a year on my slash so I figured I may as well give it a try.
LRPO is offline
Old 08-23-2011, 07:29 PM
  #18247
jwemail's Avatar
i drilled holes in my plastic caps, i drilled em in the center location, dont need a real big hole
jwemail is offline
Old 08-23-2011, 07:35 PM
  #18248
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
So just got my snr hinge pin holders , and the offset for the holes in the front and the rear are off by quite a bit if you ask me, they dont really fit that good at all, just shot off a email to them, steve if you read this send me a pm..thanks. Maby just got a bad batch ah well.
Blitzrockey is offline
Old 08-23-2011, 07:58 PM
  #18249
SaladFork's Avatar
I see it as a safety net for the new users, if it's similar to the 1415 on the internal specs it will be a killer motor on 3S (which you know) and fairly indestructible.
SaladFork is offline
Old 08-23-2011, 08:11 PM
  #18250
what ride height are most running for clay indoor tracks? I ran my sc10 4x4 at 24-25mm FWIW. Im having a tougher time coming up with setup sheets like I could with my sc10 4x4
This is the track I race at
barry1me is offline
Old 08-23-2011, 08:41 PM
  #18251
I kind of see it as a spec motor too on 2s which is good for newcomers.
Old 08-23-2011, 08:51 PM
  #18252
Originally Posted by cjm1126 View Post
anyone know which pistons come with the truck stock?
The stock pistons are the #3 pistons.
Originally Posted by jwemail View Post
The new ones do but you have to make sure as the old ones don't. Mine don't but I will be drilling them.
so i take it that the new caps with the bleeders are very new, or have they been out for a little bit. what are the chances that i order a set and they will be the right ones with the bleeders. thanks[/QUOTE]
The first 500 sets we got in did not have the holes, everything after that does. However some of the older stock is floating around. I have been drilling them for those that need it done. Its not hard as long as you go slow and punch a starter spot.
Originally Posted by mjealey View Post
All right, I know Casper or Hacker are not going to say, but when will the TLR chassis be available? I really want one but I do not want to wait a month to get it. Can anyone drop a little hint, if not maybe I will go ahead and go with the BCE chassis.
Why would I not answer this...lol. They shipped out yesterday via air so they should be here within a week and a half or so.
It actually runs great on 2s. It comes geared at a 18 and the motor mount allows more room however you dont need it. It will work on 3s but I suggest gearing it down a lot.
Not a spec motor at all, it runs great on 2s. Its a 2800, not a 2400.
hacker07 is offline
Old 08-23-2011, 09:24 PM
  #18253
ITS ME DAVID's Avatar
Anyone know a site where there selling the ARR scte for cheaper then $299?
ITS ME DAVID is offline
Old 08-23-2011, 09:26 PM
  #18254
R.Bryant's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Casper View Post
Dakotah's setup was posted a few pages back. Basically the same as the Aaron Lane
http://www.losi.com/ProdInfo/Files/L...Lane-JBRL4.pdf
Only a slight ride height change.
What chassis is being used with this set up?
R.Bryant is offline
  #18255
bigb11's Avatar
Trader Rating: 59 (100%+)
try ampdraw hobbies
bigb11 is offline
