Like Tree9Likes
Old 01-20-2011, 09:27 PM
  #166
Ridley's Avatar
Originally Posted by hacker07 View Post
Well, we have looked into that and we have not found the need for other springs as of yet. If we get enough interest for them, we will surely work on those. As for the shocks, they are both 12mm internal, but I have not tried to move the springs back and forth as of yet.
Interesting. I thought the gold(stiff) optional springs are still on the soft side in the front on my identical conversion.....I would like some a stage stiffer actually.
Ridley is offline
Old 01-20-2011, 09:50 PM
  #167
Trader Rating: 41 (100%+)
racerx1920--
Is that a LRP SXX TC ESC? If so,does it work O.K. with that 550 motor?
Thanks,
rifraf is offline
Old 01-20-2011, 09:57 PM
  #168
Casper's Avatar
Trader Rating: 34 (100%+)
I think you should be able to use most higher end 10th scale ESC's with the 550 motors. As long as they have a good amp rating and you will want to use a fan on it. The Xcelorin 10th scale speedo works was well. Again with the higher amp draw you most definitely want to run a fan in most cases.
Casper is offline
Old 01-20-2011, 10:01 PM
  #169
Thanks Casper,I may get the 4x4 losi SC.I am very impressed with the xxx-sct.
rifraf is offline
Old 01-20-2011, 10:29 PM
  #170
big greg's Avatar
Trader Rating: 119 (99%+)
Originally Posted by rifraf View Post
racerx1920--
Thanks,
it, is it runs fine with that motor besides not having reverse lol
big greg is offline
  #171
jsamarin's Avatar
Is the 6.75LB running weight with a novak 550 motor? If it is, since the tekin motor is lighter you would drop some weight off the truck in that aspect. Dare I say a 6lb race weight is possible if you watch what electronics you run, carbon towers and a few other mods?
jsamarin is offline
Old 01-20-2011, 10:32 PM
  #172
big greg's Avatar
i think the lighter you go with these trucks the worse off you are, the body will act more like a scoop and fly terrible
big greg is offline
Old 01-21-2011, 01:28 AM
  #173
stinky4skin's Avatar
Trader Rating: 93 (100%+)
ya hes been runnig that for like over a year in a 4wd short course truck with a 550 can,matter of fact im gonna start using my tc spec just because his works so well
stinky4skin is offline
Old 01-21-2011, 02:58 AM
  #174
Trader Rating: 21 (100%+)
I have to agree that my truck also feels soft in the front. The back feels perfect though.
I have been running a LRP TC spec in my trucks and it has been working great.
Brian L is offline
Old 01-21-2011, 03:26 AM
  #175
CR0SS's Avatar
I would disagree. You can easily trim the body to let it fly just fine.
The weight of the Losi is to high for me to be interested. My Hyper weighs in at 5.25lbs as it sits on the track ready to run. It jumps and handles very well. I have even had it on some very large jumps(30') and it flies very well.
CR0SS is offline
Old 01-21-2011, 05:28 AM
  #176
Trader Rating: 25 (100%+)
+1 on a stiffer spring. I have the golds on mine and I am almost out of threads on the shocks to get ride hight right.
KainK is offline
Old 01-21-2011, 05:51 AM
  #177
Rockit RC's Avatar
Originally Posted by jsamarin View Post
they use the proline protrac offset if i'm not mistaken
Good to know, those wheels will be the first thing I change. They just look cheap and toyish to me. The tires look pretty nice though.
I am very excited about this truck. This is the truck I have been waiting for to jump into 4wd SCT. I did purchase a Slash Roller, to learn on and work out the electronics for this truck. I had converted my XXX-T late last year and love it so much I am not going to get XXX-SCT....yet. I love the ten-t platform and thought that it would make a great truck, so why not convert one of those also. I have been talking with some of the guys (thanks soup) about converting the ten-t, doing research, and was ready to pull the trigger. But not any more.
Thanks Losi, I am a loyal customer for many years. Even through the Strike, which I have tweaked till I love it. I still race it in the spec class, and will continue to do so.
I think the 4wd market is now going to explode. Not that this truck will take over (there are too many variables...like...oh, let me see...THE DRIVER). But that the bigger companies, with the larger R&D and marketing dollars will bring better product (with better support and more value). To this point I just didn't think that the current offerings were quite there yet.
Thanks Losi.
Rockit RC is offline
Old 01-21-2011, 06:37 AM
  #178
hlb14's Avatar
Trader Rating: 28 (100%+)
loving this new truck! thinking of picking one up along with the parts from the ten-t to be able to convert back and forth from 4wd sc to truggy. is the only difference arms, driveshafts, camber links, tie rods?
hlb14 is offline
Old 01-21-2011, 07:00 AM
  #179
All that stuff is the same. Its chassis, motor mount, rear DS, bumpers, body mounts, and axles(you can make the ten-T axles work) that is different.
KainK is offline
Old 01-21-2011, 07:10 AM
  #180
hlb14's Avatar
hmm guess its not as practical as i thought
hlb14 is offline
