#1771
is there any overviews or videos of this truck on youtube yet?
#1772
Thats the 19t pinion. I figured I'd start out there and see where it takes me. There was an earlier post either on this thread or the 1415 thread where a 19t was used on that motor with a 40t spur and they had good results. I will post up later tonight after racing with my impressions of the motor
#1777
Definitely gives it a unique look!
Glad they found your truck, dude!!! I've greatly appreciated your comments and video in this thread
#1778
Do the HB shocks work better than stock? Do you get full travel. Had a set in my box and thought about using them, but the stock shocks seem to do the job.
#1779
just an FYI although the manual recommends a 16t for a 4.5 I would recommend starting with a 14t pinion on a 4.5 I ran a 15 on the big track and it was geared perfect in my opinion. different batteries, motor brands etc can change this but its better to safe than sorry.
#1780
#1782
I see he has the adjustable hinge pins....what settings did he use and do you know his current ride height???
#1784
The Black ones are stock. Look in the Manual, and it gives you the exact part numbers to each shock. Just key in that number in any of the R/C websites i.e., A Main Hobbies and it will show you which spring you are looking. I believe Gold is Hard, Black is Medium and Silver is soft but I could be wrong. Good Luck!
