Like Tree9Likes
Old 08-17-2011, 07:19 PM
  #17566
Aoh
Trader Rating: 16 (94%+)
Originally Posted by nickypoo View Post
$90 bucks for the 120amp is not a good deal imo when i can get a mmp for $120 and the one i already have is great but i stole it outa my other sct...
xerun > MMP
no contest, the xerun is a WAYYY smoother and better esc
Aoh is offline
Old 08-17-2011, 07:32 PM
  #17567
"Smiley"'s Avatar
Trader Rating: 171 (97%+)
If it gets too warm, Go to a 13t. When I have run on a smaller track, A 13t is perfect.
"Smiley" is offline
Old 08-17-2011, 08:54 PM
  #17568
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Originally Posted by Feint Motion View Post
Thinking about pulling the trigger and buying a RX8. Will I have any regrets?
I have a HW SC8 here, still sealed. Thinking about saving it as a back up, but if I get the RX8 will I even use it as a back up?
added a bold font so i can get herd.
lmao!!
how much for the sc8?
Mr.juarez is offline
Old 08-17-2011, 09:08 PM
  #17569
goehm's Avatar
Trader Rating: 45 (100%+)
Originally Posted by Asharus View Post
RX8, or nothing.
That's what I told the girls at hooters. And shure enough, they didn't have an RX8.
It was a pretty fun nigightigt. I think I spelled that wrong. Damn the Yuengling.
goehm is offline
Old 08-17-2011, 09:29 PM
  #17570
BmainStar's Avatar
Man how do I make it Bold print??LOL..... RX8 FOR LIFE ... F.T.W.!!!!!
BmainStar is offline
Old 08-17-2011, 09:40 PM
  #17571
suby723's Avatar
Trader Rating: 21 (100%+)
RX8 or nothing.
suby723 is offline
Old 08-17-2011, 09:50 PM
  #17572
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Hobbywing xerun 120a $90 bucks Just as good if not better then the rx8. Fo life lol. :
Blitzrockey is offline
Old 08-17-2011, 11:32 PM
  #17573
Originally Posted by ScottKelly911 View Post
New gears on left, old gears right
New Spider Gear on left, old Spider Gear on right
New Spider on Left, old on right
New Sun Gear on Left, old Sun Gear on right
New Spider Gears in place on diff pin
Sun Gears installed into Cup
Going together, perfect fit
Fill'er up!
The ole girl and home to the new diff gears...
I hope that this was a good write up even though it was long! Thanks again to Ryan Dunford (Hacker07) for letting me test these out! If anyone has any questions, I can answer them if it has to do with the build up of them (no leaks!) but if it's a question having to do with anything else like when they'll be available to the public, those are best aimed toward Ryan. Thanks for reading!
it's great to see new gears~~~
does the new spider gears still need to use the extreme small washers at the back ???
Marco926 is offline
Old 08-18-2011, 12:41 AM
  #17574
ScottKelly911's Avatar
This is only my opinin and I'm certainly no pro, but there is so much more contact between the gears that I certainly wouldnt be surprised if people experimented with leaving them out like on the Losi Eight diffs that i believe Adam Drake started building like that with success. But to stay inline with Losi's recommends, I included them. If anyone decides to omit the tiny shims, do so at your own risk and know that you chance ruining the gears. That being said, I'm sure someone will try it and I look forward to seeing thier results.
ScottKelly911 is offline
Old 08-18-2011, 12:57 AM
  #17575
really thanks for your info.~~~~
the tiny shims are eating the stock spider gears........so i changed to use large shims from 1:10 on-road car gear diff., they are perfect fit and have no wear issue at all, the shims are really really cheap.........
0.1mm and 0.2mm for choose
Attached Thumbnails Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-spr010-sh1_m.jpg
Marco926 is offline
Old 08-18-2011, 03:46 AM
  #17576
Cement head's Avatar
Just had 6 cases of Yuengling delivered from a friend that's working in up state NY. No body carries it around my neck of the woods.
Cement head is offline
Old 08-18-2011, 05:18 AM
  #17577
Have you got a part number or know which car the shims you are using come from?
Do you know the ID and OD measurements of these shims?
Star
Starlite033 is offline
Old 08-18-2011, 06:50 AM
  #17578
Star
these shims are from SPEC-R.......they made many gear diff for 1:10 on-road cars and those diff are all using these shims behind their sun gears
the center hole is not perfect fit but only about 1mm gap in between, these shims can fully support the back of the losi spider gears, also hold up more diff oil to reduce the friction between diff case, shims and spider gears.
i ran about 30 batteries and see no wear at all......hope can help all SCTE racers~~~
Marco926 is offline
Old 08-18-2011, 07:37 AM
  #17579
Ridley's Avatar
When you guys quote a post with a bazillion pictures, could you please delete the PICS out of the quote. It makes the thread SOOOOO much easier to read Posts with a half page of pics are GREAT....the first time you see them, lol. After seeing the same ones 13 times......not so much
Ridley is offline
Old 08-18-2011, 08:09 AM
  #17580
The New RTR will be the first to include these new gears in the diffs. And I second what Ridley said unless you are making a reference to a certain pic, it is good to remove them.
hacker07 is offline
