you got pm
I have a set of the 810 axle and hubs, I'm goona install one and do some measureing.
@ MXR300,
Dont know about you but I'm 43 and have ben in this hobby nearly 30yrs, I prob forgot more about RC then you'll ever know.
I might have ben a bit of a smart azz in my post but was only stating I wished you mentioned the rims purchased were "Slash" rims rather than just rattling off the back spacing.
Whats done is done.
The diffs come filled with grease. What you put in them is usually dependant on the type of track you run on. Smoother tracks I would use either 7/5/3 or 5/5/3. Looser tracks I would get into 5/5/3 or 5/3/3. Some have gone as low as 3/3/2 but a lot of power is lost so have really good batteries for this.
Thanks Ryan, I'll give it a shot.
I would try the casey peck setup from the dirt nitro challenge as that is the closest track to what you are looking for. I can tell you I tried what has become are standard starting setup which is the aaron lane setup with the rear bottom shock in the middle and the battery back at revelation and it worked well.
Here is that pic of the axles.
Middle location I found to be a little better going through high speed sweeper type corners. Outside remember to unscrew the shock eyelets 2 turns to maintain droop but I found the outside to be a little more stable on power coming out of the corners under hard acceleration. Tighter tracks I like outside, flowing tracks carrying a lot of speed through the corners I like middle hole.
Awesome, thanks Casper
Hey im still lost on the off backspacing thing.. i know the scte can use a zero offset wheel.. so with a 31mm backspacing.. are you saying the SCte is wider stock?
@ MXR300,
Whats done is done.
Whats done is done.
That said - I've heard term backspacing used in RC as I have lugnuts.
Got my BCE chassis today ! Fit and finnish were top notch and everything fit together with no problems
What's the average delivery time after placing ur order from bce?
