Like Tree9Likes
Old 08-14-2011, 06:14 PM
  #17251
godofcable's Avatar
Trader Rating: 37 (100%+)
Originally Posted by Cement head
What motor esc setup you running? Are you using drag brake? I notice with my 4 pole castle 1415 the motor was real tight and caused the same issues for me. The wheels would stop with out the brake when I held it off the ground and throttled up. No more issues with the tekin 4.5!! Flies like superman now.
I'm running the Castle MMP with the 1410 motor. 0 drag brake. Im uploading a video and I'll post it momentarily.
At this point I can't spend the money on the Tekin, not unless I go used, and I hate buying used electronics.
I noticed Dakota was running the Novak 550. Anyone know what ESC he uses?
godofcable is offline
Old 08-14-2011, 06:17 PM
  #17252
Asharus's Avatar
Trader Rating: 42 (100%+)
i bought my rx8 used for $130 (220 w/ T8 motor and sold the motor for 90)
works like a champ. just make sure its the 3 hole case
Asharus is offline
Old 08-14-2011, 06:20 PM
  #17253
Trader Rating: 32 (100%+)
what kind of runtime you getting? what kind of batteriees?
Eddy
E-Eddy is offline
Old 08-14-2011, 06:22 PM
  #17254
goehm's Avatar
Trader Rating: 45 (100%+)
Originally Posted by StPete40
Check the SNR website. A revision was made to fix this problem.
Thanks - I sent him an EMail to see if we can work something out.
goehm is offline
  #17255
godofcable's Avatar
Eddy
for heats, I run Venom 40C 5000 mah, and I get 8-8.5 minutes.
For mains, i Run a 6200 Promatch, 60C. I made the full ten minutes, and im only down to 7.2 volts
Old 08-14-2011, 06:25 PM
  #17256
goehm's Avatar
I doubt your ESC is causing your truck to dive. I think it might be as another posted, that your suspension needs a tweak - IE: you might be slapping the rear of your chassis on the jump causing you to donkey kick your rear up.
goehm is offline
Old 08-14-2011, 06:27 PM
  #17257
godofcable's Avatar
I don't think its my ESC either. Here's a quick video of it. You can see that the wheels arent snapping to a stop, and that all 4 are stopping at the same rate.
http://www.youtube.com/watch?v=okpdvueGYOU
Old 08-14-2011, 06:29 PM
  #17258
Default diff grease
guys,
been out of the forum for a long time. can you purchase the black grease that the diffs come from the factory with? i have tried the diff fluid, but it leaks constantly. i want to put the grease back in so it doesnt leak....i didnt think the truck was that bad with the grease in it.
thanks.
skyler hays is offline
Old 08-14-2011, 06:38 PM
  #17259
goehm's Avatar
You said you had to hit the jump at full speed .. so I assume it's 100% throttle all the way up to the jump. Try easing off the throttle a bit before the jump. then throttle into it to raise your front up for launch. And also look to see if your rear end is bottoming out on the jump itself.
One or both should help you to launch/land successfully.
goehm is offline
Old 08-14-2011, 06:42 PM
  #17260
goehm's Avatar
Originally Posted by skyler hays
guys,
thanks.
I do not believe you can buy the grease that comes with the kit. I'm sure someone will chime in, but I think a close equivalent is Losi Great Grease (LOSA99207).
That said.... I have a big container of synthetic grease in the garage for my real cars that would get slapped in there to try if I needed something for my next diff build and wanted to re-try grease.
goehm is offline
Old 08-14-2011, 06:49 PM
  #17261
Trader Rating: 86 (99%+)
Got my bce chassis installed tonight, everything went nice and smooth. I realized I need two shorter screws that thread into the aluminum mount on the center diff, it was posted here somewhere but I can't seem to find it, I know it's 8/32 but how long, part number would be great? Thanks
WideOpenThrottle RC is offline
  #17262
Feint Motion's Avatar
Trader Rating: 24 (96%+)
guys,
thanks.
When you filled you diffs with oil, did you sand down your diff case? That will fix the leak problem.
Feint Motion is offline
Old 08-14-2011, 06:51 PM
  #17263
goehm's Avatar
Note: SNR graphite responded to my inquiry within minutes and are rectifying the issue. Great customer service!
goehm is offline
Old 08-14-2011, 06:57 PM
  #17264
Jason Turner's Avatar
Trader Rating: 67 (100%+)
Originally Posted by evilllempire
Losi SCTE piloted by Dakota Phend wins 4WD SC Mod at Nationals!
Please explain.
Jason Turner is offline
Old 08-14-2011, 06:58 PM
  #17265
Asharus's Avatar
guys,
thanks.
Ryan mentioned that the closest thing to the stock grease is the Losi Smart Diff grease. That's what I've been using. I'm sure you can google the p/n.
Asharus is offline
