Like Tree9Likes
Old 03-02-2011, 03:57 AM
  #1696
badassrevo's Avatar
Are you guys running the aluminum chassis braces to eliminate flex or just for bling?
badassrevo is offline
Old 03-02-2011, 05:09 AM
  #1697
Feint Motion's Avatar
Trader Rating: 24 (96%+)
Picking mine up today!
Feint Motion is offline
Old 03-02-2011, 05:35 AM
  #1698
Default Silver springs?
Does anyone know where I can find a set of silver springs.
losi b is offline
Old 03-02-2011, 06:12 AM
  #1699
Nighthawk's Avatar
Default +1!
Me too, cant wait!
Will be taking it to.an indoor carpet (with jumps) fri to break it in, then indoor offroad sunday.
Nighthawk is offline
Old 03-02-2011, 06:13 AM
  #1700
Maxxingout's Avatar
Trader Rating: 17 (100%+)
I have not seen or read any info on the shocks but how do they compare tot he 1/8 2.0 shocks Losi has? Same size length wise, dia wise, shaft wise?
Maxxingout is offline
Old 03-02-2011, 06:22 AM
  #1701
pswag115's Avatar
nighthawk, Jims & Bumps?
pswag115 is offline
Old 03-02-2011, 06:23 AM
  #1702
lowroad's Avatar
Trader Rating: 79 (100%+)
so jealous. so so jealous.
lowroad is offline
Old 03-02-2011, 06:36 AM
  #1703
Nighthawk's Avatar
Default .
Richfield raceway, and bumps.
  #1704
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
Originally Posted by hacker07 View Post
Chris, those are a special screw. They come with LOSB3542 and they have a special small head on the screw. Those screws are in there good and you need a really good driver to get them in and out. If you contact Horizon support via phone, they will get you hooked up if youd like.
Will do. Thanks again Ryan.
ChrisAttebery is offline
Old 03-02-2011, 06:59 AM
  #1705
D-money's Avatar
Trader Rating: 31 (100%+)
Originally Posted by pfraser2488 View Post
how is that motor doing i am looking at the same setup?run times?heat issues
and what servo are you using?what size track do you run on? and also what tooth pinion did u start with? thanks
wow thats alot of questions so here it goes
1- motor is great not as fast as the 4.5 top speed wise but it is much more drivable.
2- about 22min on a 5800 40c pack
3- no heat issues after 20 min comes off at 155f
4-im using the hitec 7955tg servo it is over kill but i have found that the stronger the servo the longer they last ive been running this one in my monster trucks for 4 years now.
5-the tracks i run on are revelation raceway(revrace.com)OCRC anmd West coast rc raceway.
6-the pinion is a 17t
hope that helps.
QUOTE)
Today 06:12 AM(QUOTE)
they seem to work quite well for this truck.the ones on my 8-2.0 are nicer though. the upgrade parts for the shocks are coming, cnc caps and adjuster rings.the rubber boots that come on them suck and the springs in the rear rub the shock body a bit but doesnt seem to change preformance.
D-money is offline
Old 03-02-2011, 07:05 AM
  #1706
D-money's Avatar
wow! out of stock every where hmmmmmm...
D-money is offline
Old 03-02-2011, 07:10 AM
  #1707
Peter i should be getting my Losi sat as well so i should be at bumps on sunday also, you coming to the Bowl on sat?
mxfastguy35 is offline
Old 03-02-2011, 07:11 AM
  #1708
hope that helps.
was that an LRP 1/10 scale ESC?
I've got a LRP sphere TC sitting around unused right now.... wonder if I could push a 4.5t or 5.5t 550 can motor on that thing?
artie's liver is offline
Old 03-02-2011, 07:20 AM
  #1709
Cult Racing's Avatar
Trader Rating: 42 (100%+)
im not as good of racers as these guys, I do the socal point series, where its just backyard tracks and the electronics im running is;
mmp
neu 1509 1.5d motor - gonna start with a14t
hitec 7950 servo
spektrum receiver
ya I havent gotten to run my car yet, im putting the upgrades on it and finish putting the diff oils in.
Cult Racing is offline
Old 03-02-2011, 07:59 AM
  #1710
pswag115's Avatar
Mx, I'm going to Austin, Tx for a long weekend, so I'm going to miss the bowl and bumps this week. Hopefully my Durango SC will be here when i get back for next week!
Artie's Liver, Hey Now! ROFL
pswag115 is offline
