Like Tree9Likes
Old 08-10-2011, 04:12 PM
  #16936
ScottKelly911's Avatar
Originally Posted by E-Eddy View Post
Who all here gets at least 10 min on relatively big tracks? What electronics do you guys use? I'm still having a hard time on what electronics to get without breaking the bank. I was wanting to try the MMM w/ the 1410 since I already have the esc. But Ive heard around that ROAR made the 4 pole motors illegal in 4x4 SCT. HELLLPPP PLZ
Eddy
The 1410 is ROAR legal. The Tekin 4-pole will also be ROAR legal upon its release.
ScottKelly911 is offline
Old 08-10-2011, 04:13 PM
  #16937
Asharus's Avatar
Trader Rating: 42 (100%+)
Awesome, now I just want them to get rid of that silly rear tail light rule. Would a piece of black electrical tape be good enough to serve as "smoked taillights?"
Asharus is offline
Old 08-10-2011, 04:25 PM
  #16938
Eddy
I can easily get 10 mins on our 1/8 scale track. I use RX8 Tekin 550 5.5 15T MaxAmps 6500 . I can switch in the 3800 and it will go 10 ez as well.
Lon_L is offline
Old 08-10-2011, 04:34 PM
  #16939
SaladFork's Avatar
Originally Posted by x7tristan View Post
I just got a Viper VTX10R and VSTXL 4.5T. I'm running them with a 16T pinion (profile #8, 'practice') and the temps are around 180*F. What size pinion are people running with this type of setup to get the temps below 160*F?
These are the settings Viper recommends with the 4.5/5.5XL and VTX10R.
VST4.5XL-14tooth pinion.
VTX10R-Profile#2
Brake strength 80%
Brake PWM freq 8000HZ
Brake curve linear
Neutral drag brake 10%
Throttle PWM freq 9600Hz
Throttle punch 15%-20%
Throttle curve linear
Deadband middle
no timing- default
no motor protection
esc protection 240 degrees
(esc temp 120-140)-(motor temp 150-170)
SaladFork is offline
Old 08-10-2011, 04:52 PM
  #16940
Trader Rating: 16 (100%+)
Default Suggestions needed
Running a mmp + 1410 gearing 13/40. The problem is every pack I put in it puffed. Turned the up th battery cut off to 3.4 per cell but haven't ran since. Any suggestions. Batteries were 35c don't know if continues or burst rated.
A929ryda is offline
Old 08-10-2011, 05:01 PM
  #16941
larlev's Avatar
What brand lipo? Temps when this happened?
larlev is offline
Old 08-10-2011, 05:26 PM
  #16942
Very low temps. 120 motor 110 esc. Batterys were hobby people brand. They worked well for every othe set up I had.
A929ryda is offline
Old 08-10-2011, 05:30 PM
  #16943
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
If ur interested, either PM or email Steve directly. I'll be installing mine and hopefully running it on Saturday. I got the 3.7mm looks good and feels like a high quality piece.
im debating on getting one myself now just to see. One thing i would like to see before i spend 140 on that chassis. can you post pics of the side guards to see how much they hang out since the chassis is flat on the sides? wanna know if i can live with it or not
Mr.juarez is offline
  #16944
Asharus's Avatar
The SCTE is not really a normal setup, so you can't compare it to your "every other setup".
Asharus is offline
Old 08-10-2011, 05:34 PM
  #16945
larlev's Avatar
Mine puff a little after a qual or main..nothing major, but it puffs. I also have my LVC at 3.4v now. Lipo's shouldn't be ran to LVC all the time, bad for lipo, and hurts longevity.
larlev is offline
Old 08-10-2011, 05:45 PM
  #16946
8ight-e's Avatar
Trader Rating: 58 (100%+)
Originally Posted by Feint Motion View Post
Having some heat issues with my tenshock 4000kv.
I'm running the MMM zero timing geared at 15t on 2s 40c packs. Should I gear down? Or limit the power?
Weather was around 95, and the motor came off at 200+.
Originally Posted by racerx1920 View Post
i ran my tenshock 4000kv motor this past weekend and it was about 92degs and i pulled my car off and temped my motor at 150 with a 13t and clip on heatsink and 170 with a 14 and no heat sink, and i used hobbycity 25c 2s 6000 packs so i agree with ridely the C rating is a bunch of BS my 40c packs had the same results.
my track is 150 x 100
ridley
how are you not toped out at 180 feet? mine fells like its about 1/2 maybe 2/3 down the strat and its toped out and that is at a 150 foot strat
Guys be careful about talking about how the tenshock has heat issues.. you will get lots of crap in here. LOL It by default, according to many, is better than the 1410 ;P At 95' id suggest a fan on any of these motors, even my 1410 geared 15t was around 190 w/o a fan on it. When ambiant drops to 85 I don't have any issues, but at this point for the rest of the summer I plan on just keeping the fan on the motor.
I've had great luck w/ my orion 6500, costly though.. I know the local guys here also run CRC 5800 and 6200 packs w/o any puffing as well and they are under 100ea last I checked.
8ight-e is offline
Old 08-10-2011, 06:10 PM
  #16947
larlev's Avatar
Yep, the Orion is the only one that has been rock solid. Highly recommended if running long mains or just want a really good lipo. Not sure if I believe the 90c rating, but it sure has power throughout the entire capacity of the battery. After a main it still runs like a new pack was put in.
larlev is offline
Old 08-10-2011, 06:21 PM
  #16948
Ridley's Avatar
ridley
I'm not sure how to be honest. All I know is the truck kept pulling the whole way down the straight on the below track...never stopped accelerating...ran right with the Nitro cars running that new novarossi motor. Straight is 180 foot plus, dead away from the driverstand, so I couldn't hear the motor to tell exactly what was going on. Could be because I'm under 6lbs on the track so it takes less load to accelerate that than say, 6.5 lbs or 7lbs, could have been because the straightaway was rough so I wasn't fully hooked I was the only 4x4 sct that could do the big jumps on this track as well. I was running the 4000kv tenshock, rx8, no timing, current limiter at 90, 14/40 and the new Turnigy nano tech 6000mah 65-135c batteries.
I'll be running a 13t at Dirt Hills, since you are familiar with that track. I won't be close to topped out there, prolly not even with a 12t.
http://www.youtube.com/watch?v=gQNs5StJ-t0
+ YouTube Video
Ridley is offline
Old 08-10-2011, 06:28 PM
  #16949
RC*PHREAK's Avatar
Trader Rating: 141 (100%+)
any motor has heat issues if not geared properly.
RC*PHREAK is offline
Old 08-10-2011, 06:31 PM
  #16950
RC*PHREAK's Avatar
+ YouTube Video
so far how do you like that nanotech? mine is in switzerland right now on it's way.
