Like Tree9Likes
Old 08-06-2011, 03:47 AM
  #16516
Anyone running the castle 1410 3800 motor with this truck?
BoneDoc is offline
Old 08-06-2011, 05:18 AM
  #16517
Chris K's Avatar
Trader Rating: 46 (100%+)
Pretty much everyone that's totally happy with their motors! This is a rock solid choice for this truck; gear 13 - 14 indoors (depending on size of track!) andd 15 - 16 outdoors and you'll be a happy camper!
Temps always good and power amazing (but for the most part controlable!). It's a NON sensored motor so make sure your speed control supports this type of motor!
Have fun and enjoy a great motor/truck combination!
Chris K is offline
Old 08-06-2011, 05:46 AM
  #16518
Timbulb's Avatar
I run the 1410 with a 14t. Best motor I've seen in all my time doing RC racing. I used an LRP x12 5.5 550, it constantly came off at 190F. Put the 1410 in, with same gearing and everything, and it came off at 130F. Amazing little motors.
Timbulb is offline
Old 08-06-2011, 07:06 AM
  #16519
larlev's Avatar
Originally Posted by hacker07 View Post
If you have the updated aluminum shock tops, you really should try emulsion shocks, cut the center of the bladders out and bleed them, the truck will land much better.
Have a another question. Should the nut on top of the piston be at the same level as the next when shaft is pushed all the way up with no oil in body?
I have a set of fronts that the nut is 2mm higher out of the body than the other..
I'm stumped...if I fix nut issue, then shaft lengths aren't the same. So when I go to push in rebound amount it is different. By a mile different. I took shocks apart and measured with calipers
Hopefully this makes sense to someone...lol
larlev is offline
Old 08-06-2011, 07:23 AM
  #16520
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
Check to make sure they aren't bent. You can drill the arms with a #28 or #27 drill bit to clearance them slightly.
Originally Posted by SCTRacerX View Post
I have some slight binding in my hinge pins what is a good way to make the a arm fall freely?
ChrisAttebery is offline
Old 08-06-2011, 07:26 AM
  #16521
Nice job Salad!
Originally Posted by SaladFork View Post
That would be some of my handy work. Not a print guy, but I can manage.
Old 08-06-2011, 08:19 AM
  #16522
Wldmoose's Avatar
++1. Great motor for this truck....and for $65 bucks on Ebay the value can't be beat.
Wldmoose is offline
Old 08-06-2011, 09:23 AM
  #16523
dirtracer1's Avatar
Can someone fill me in on what the "long" chassis brace is and where to get one?
dirtracer1 is offline
Old 08-06-2011, 09:38 AM
  #16524
Here is the item.
http://www.amainhobbies.com/product_...s-Braces-RC8RS
bustanut666 is offline
Old 08-06-2011, 10:15 AM
  #16525
Doug D's Avatar
Trader Rating: 61 (100%+)
Originally Posted by ScottKelly911 View Post
Steve, your chassis looks great! Definitely lost some heft lol I look forward to getting mine from you tomorrow and putting in some laps with it
Scott - Or those running the SNR Graphite chassis, is the chassis flat from side to side or does it have the sides bent up like stock? Thanks.
Doug D is offline
Old 08-06-2011, 10:35 AM
  #16526
You may want to check and make sure the shim is under the piston on both of those shocks. It sounds like that shim is missing or in two different places. It should go shaft, washer, piston, nut.
No, the chassis is flat on the sides. Laying carbon fiber, you can get really good strength one way and the way he layed the carbon, it gives plenty of strength front to back and the chassis still hs torsional flex which is good.
hacker07 is offline
Old 08-06-2011, 10:44 AM
  #16527
Doug D's Avatar
Thanks Ryan! Great information.
Doug D is offline
Old 08-06-2011, 11:08 AM
  #16528
Default Gearing
I just got a losi and am planning on running a 540 can Orion 6.5 till I can afford some thing else. Just curious if anyone could help me with a starting point on the gearing.
Jason
captainsa is offline
Old 08-06-2011, 11:23 AM
  #16529
stompy's Avatar
Ryan,
Can you please explain how you cut the center of the bladders out and bleed them?
stompy is offline
Old 08-06-2011, 11:25 AM
  #16530
racerx1920's Avatar
Trader Rating: 215 (100%+)
Jason
you are going to burn that motor up. i would not even try it. get a castle 3800 they are cheap and work great
racerx1920 is offline
