Like Tree9Likes
Old 08-03-2011, 11:19 PM
  #16366
101 is the man ,,,, thanks im gonna race it first time friday and was afraid i messed up and my truck would fall apart ..
and if anyone knows the best cheapest battery i would greatly appreciate it , i have gens 5000 mah 40c now
pete nice is offline
Old 08-03-2011, 11:33 PM
  #16367
Here are some pics of the new SNR carbon fiber hinge pin holders. Works great and looks awesome. At least 6 track days already, no issues whatsoever.
bustanut666 is offline
Old 08-03-2011, 11:41 PM
  #16368
Fatam's Avatar
What the hell kind of bumper are those? I just bought this truck used on here and it came with the same front and rear whale tail of a bumper.
Fatam is offline
Old 08-03-2011, 11:44 PM
  #16369
Those are T-Bone racing bumpers.
http://t-bone-racing.net/Brand-A-M/L...NA01-p523.html
Rear bumper is from the Ten-T, little smaller than SCTE bumper.
http://t-bone-racing.net/Brand-A-M/L...AC02-p166.html
Old 08-04-2011, 01:15 AM
  #16370
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Originally Posted by dirtracer1
12 grams + "PRE DRILL HOLES FOR DROOP SCREW PLATFORM" + badassed awesome factor = $35.00.
Ok Ryan. The BCE is at 242 and the first run SNR chassis at 4mm thick is at 230. The new run of SNR chassis will be 3.7mm thick so they should be even a little lighter.
What will the new Losi lightened chassis weigh in at?
i dont see whats the big deal about droop screws to be honest. if you dont want the chizzle look alike screw take a file and make them smoother or not run them at all. i used to switch from running those and not running them, but here is a pic of the little scratches they did to the usa t6 aluminum when i used them.
now that we're on the same topic it seems as you guys are in a race for the lightest chassis salad fork, ridley, eight-e just to name a few have said its a perfect balance, even BCE said he can remove more material, but at what cost? making things above the chassis much heavier?
Now same argument that ridley bought a few days ago vs. the losi guys....
Which version will be sold/tested since apparently there is 2 versions now?
ps... bustanut66...
am i blind or do those hinge pins only have 1 e-clip on one end only? wont they move front to back and are those chris a pins? did you notch the stock chassis for the hinge holders? im asking by the looks of the rear chassis.
Mr.juarez is offline
Old 08-04-2011, 01:24 AM
  #16371
Yes, I run chris hinge pins front n back. The front uses eclips. The rear snr holder is captured. Did not modify chassis at all.
Old 08-04-2011, 05:59 AM
  #16372
x7tristan's Avatar
Default 6.2 lbs?
Is it possible to get the SCTE to 6.2 lbs? Thats the limit at my indoor track.
x7tristan is offline
Old 08-04-2011, 06:36 AM
  #16373
stevepowling's Avatar
How is the mmp esc and novak ballistic 4.5 550 combo for this truck? Got an offer to buy a brand new never run TEN with this included for a great price, but not sure if this combo is suited for this truck or not. I know most are running RX8's.
stevepowling is offline
Old 08-04-2011, 06:39 AM
  #16374
Asharus's Avatar
Trader Rating: 42 (100%+)
some run it, can always just get an rx8 if/when it blows up if it's a good deal, warranty repair the mmp and sell it
Asharus is offline
Old 08-04-2011, 06:42 AM
  #16375
BashemSmashem's Avatar
It will work , but you will need an external BEC because the BEC inside the MMP is SHT
BashemSmashem is offline
Old 08-04-2011, 06:43 AM
  #16376
Asharus's Avatar
Depends on the servo he's using though, right?
Asharus is offline
Old 08-04-2011, 06:46 AM
  #16377
IDK , I have 2 and they both will still shut down even using regular servos but work fine with an external BEC . Hopefully those new low amperage servos coming from Hitec will solve this problem ?
Old 08-04-2011, 06:48 AM
  #16378
x7tristan's Avatar
also, does anyone know what the weight of the stock truck (just rolling chassis) with body out of the box is?
Old 08-04-2011, 07:34 AM
  #16379
The stock chassis weighs 286 grams, the new TLR chassis weighs in around 214 but that was before the last small pocket was added. Either weigh, its a good balance of weight savings with still having the strength to it. This is why we tested so long to get it right.
It has been said a few times that you can get it to this weight. However, you really need to talk to your track owner as a weight limit that excludes any 10th scale vehicles is way off.
hacker07 is offline
Old 08-04-2011, 08:19 AM
  #16380
Ridley's Avatar
Mine is at 5lbs 15oz ready to sit on the track....getting to 6.2lbs is rather easy.
A lot of it has to do with your battery and motor choices, There's a huge disparity in weight amongst battery packs in the 6000mah range as well as a huge weight difference between the Tenshock/castle 4 pole motors and the beastly 550 can motors.
With a battery in the 315 gram range, and a smaller 4 pole motor, all you really need to do to get to 6.2 lbs is remove plastic thats not needed...like most of the battery tray, most of the radio tray, most of the rear bumper, etc.
Ridley is offline
