New Ten spring sets are in stock so your LHS or where ever you get parts from should have them or get them soon.
http://www.losi.com/Search/Default.a...m=ten%20spring
[QUOTE=Chris K;9458698]It's ok.... you can have two trucks - paint them alike and hope the wife doesn't notice one got bigger!!!!!!
My Baja
My SCTE
See, in pictures they look the same!!!!!!!
and really, we've been messing with women about size for generations - I think most are confused enough you can pull it off!!!!!!
HAHHAHAHA! Good one bro!
My Baja
My SCTE
Did I miss it, are the new springs only sold in kits?
Yes they are only sold as front and rear sets. This way you don't need to search for the "right ones". You already have them all.
Just to make sure, the HD lightened outdrives will NOT be a part of the TLR kit, right?
Ryan or Casper said a while back that Losi Smart Diff Grease is pretty close to the stock grease, so that's what I've been using.
I'm pretty sure they are off 2.5wt.. but it's the other way. The ae 30wt is the equiv to 27.5 losi oils, ae 40wt is equiv to losi 37.5 etc etc. This is of course with the old versions.. the new oils are by cst.
To All...if you are looking to get the TLR4000 Lightened chassis for the SCTE, you can run the stock rear chassis brace. If you want to remove a little more flex, we are also releasing the LOSB2426 Rear Torque Rod specifically for the TLR4000 chassis. There is a special hole in this chassis just for this rear brace.
Because the Rx8 has proven to be one of the most popular esc's in this application. It has a 5 amp BEC which means no need for a separate one as some others do, has a heat sink and fan if needed, and can run 3s without issue. It will also handle all of the 4 pole motors including the new "Pro 4" Tekin motor which is due out shortly.
I would bet that sooner than two weeks.
An announcement is bound to happen today...
checks in the mail. Tekin's new motor will be here sometime this year. right after tenshock castle and a few others set the price range. slow boat from china,,, lol expect to pay any where form 60 to 300 depending on who you know. J/K
Question. to CASPER ?
when adding grease to the diffs. is there a amount ? or just pack it in. I noticed when I rebuilt , cleaned them up there wasn't very much in them. Thanks
